Hey, a mate of mine has a gq ute with leaf springs, He is interested in doing a cab swap with a gq wagon so he can have the luxury of coils. So I want to know if a gq ute and gq wagon chassis are the same and will the ute cab just bolt straight onto the wagon chassis, assuming the chassis are the same the ute cab should just bolt right on? Thanks |
tonka hilux
Hey, a mate of mine has a gq ute with leaf springs, He is interested in doing a cab swap with a gq wagon so he can have the luxury of coils. So I want to know if a gq ute and gq wagon chassis are the same and will the ute cab just bolt straight onto the wagon chassis, assuming the chassis are the same the ute cab should just bolt right on? Thanks u may find the same issue i had when i did a single to dual cab swap on a hilux. the ute can may be missing all the rear mounts for the body of the wagon. chassis is probably the same but just missing mounts. |
no more holdens
The CENTRE rear cab mounts ARENT on the wagon chassis |
janth6
hi mate, i used to fit genuine ute trays to alot of patrols, with the new models, i know that the mounting points of a coil spring are further in than the leafs, we used to have to offset the mounts to get them to fit,. |
lil_bobby_260
why not just strip the suspension and mounting points off both and runt the wagons coil setup on the ute? |
no more holdens
Nah cab swaps pissa piss |
lil_bobby_260
ummm plus all the fitting and fuel lines and brake lines and electrics and so on? and the pain in the arse of having to move them? |
no more holdens
Disconnect the booster, yes |
lil_bobby_260
It's only rear suspension being swapped... Seems like less of a job and much less hassle but ok. |
Davo812
The ute cab is a direct bolt on to the wagon chassis. Nothing needs to be cut or moved just unbolt lift off and bolt back on i have done this with a GQ before and now ive owned 5 gq's and it is easy only hard thing is lifting thecab unless your lucky and have the use of machinery to do it. BUT ZYOU WILL HAVE TO GET WAGON FRONT GUARDS THEY ARE SPACED DIFFERANTLY THE LEAF SPRUNG FRONT DIFF ID FURTHER TOWARDS THE FRONT OF THE CHASSIS |
Masdarati
you cant legally put a GQ body onto a GU chasis, well you can but it is THE BIGGEST FUCK AROUND. need engineer reports, documentation from nissan saying it is safe to put that body on that chasis etc. |
no more holdens
you cant legally put a GQ body onto a GU chasis, well you can but it is THE BIGGEST FUCK AROUND. need engineer reports, documentation from nissan saying it is safe to put that body on that chasis etc. Think the OP, is putting a GQ ute leafy cab on a GQ coil wagon chassis |
