Sc14 Supercharger Rebuild
Ryanator
  • Ryanator
  • From: Brisbane - Somewhere - Me no stupid 2 tell you!
Post #1 post 15th April 2011 - 02:30 AM
Hi all,
Is there anywhere I can buy bearings and seals for a SC14 Supercharger, looked everywhere but cant seem to find them anywhere...???
Cheers Ryan
If its anything like the SC12 then you're outta luck. There's a thread on toymods regarding those, rear bearings have been unavailable for years, front bearings recently unavailable, lobes cannot be replaced, and seals can't get either. Start saving for a new charger.
Ryanator
Has anyone ever had these apart? could one pull it apart, inspect and re assemble as is?
Cheers Ryan
The following is copied directly from a Toymods thread, from a guy named Terra Operative who is THE guy for SC superchargers.
This is what I have found re. the SC chargers.
The lobes are made from extruded aluminium in the shape required. The outside surface is grit blasted and cut to size then it appears the lobes are re-extruded through a slightly larger mould that applies the teflon (or similar) coating. (sort of like icing a cake all the way around at once).
Spraying a new coating on is not really an option because of the tolerances involved (which run to as close as 0.25mm) and the thickness needs to be about 0.5mm or so, much thicker than most spray coatings. Also the teflon profile doesn't follow the aluminium profile exactly so even if you sprayed the right thickness perfectly, it wouldn't be the proper shape.
Ie, you can't recoat these things.
What about buying new ones? Well Ogura will sell them (with their universal mounting points, not the Toyota style) but you need to order a pallet of chargers as a minimum............
As for bearings, you CANNOT get the front bearings at all, unless you commission Koyo or KYB to manufacture a production run of around 1000 bearings of each type.
You can get the rear bearings, or could, until I bought 2 of the last three in Australia for my rebuild, and have the last being held at the local bearing place pending my discovery of a last one overseas.
If anyone finds a source of rear bearings, let me know, the manufacturer has no plans to do another run in the foreseeable future.
The two rear seals are still readily available, but to replace them (you know they need replacing if your supercharger uses oil) you need to heat the rear bearings to melt the epoxy that holds them in to remove the bearings to access the seals.
Unless you have precise control of the temperature, you risk stuffing the bearings so you really need to replace them anyway.
So, basically, if your supercharger needs front bearings or new lobes, get a new supercharger. If it needs new oil seals or rear bearings, if you can find the rear bearings, then you can extend it's life.
Also, to prolong the superchargers life, keep the supercharger speed below 10,000RPM and the boost below a ratio of 1.8, or 2.0 short term (or 12PSI, and 14.7PSI short term)
VersionR
How do you tell if the bearings in the SC14's are stuffed? Are they friction type or roller?
Also for anyone who would know, what's the standard boost pressure that the SC14 puts out, and is it safe for an engine with 8.7:1 compression?
Ryanator
So theres NO way to rebuild them>>>??? surely there has to be, what about using different bearings and seals to suit, a 12000rpm bearing would be suffecient (c3) surely.
Cheers Ryan
QUOTE (VersionR @ Apr 16 2011, 01:08 PM) *
Pretty sure they're roller bearing. If they're stuffed you'd be getting grinding noises. SC14 puts out 1.4L of air per revolution, I think its about 9.5psi on a standard application. Whether its safe all depends on your management and tune, you could easily max out the supercharger before the engine with a good safe tune.
QUOTE (Ryanator @ Apr 16 2011, 06:11 PM) *
There's nowhere to get replacement parts. The bearings have to be rated to over 10000rpm, yet small enough to fit inside the charger. There's no standard bearing that meets all the requirements, you'd have to commission a custom batch. These chargers are 15+ years old, and there isn't much support anymore. Also, the modern designs are much more powerful and efficient. Start saving for a twinscrew.
Ryanator
I can rebuild these with slight modification as I am a Fitter & Turner by trade. Would many people be wanting to get theres rebuilt if I can?
Cheers Ryan
I've pulled a few apart, cleaned them, refilled the oil, new liquid gaskets, etc. Pretty easy job. Boost is dependant on the engine size and how fast you spin them - they are great on smaller engines for adding some decent meat to the torque curve for cheap but aren't very efficient.
1000 bearings to get a production run.
That's not such a bad thing considering how many of these things are floating around.
BoostedVW
I never pulled my 14 apart but I would bet they use the same size bearings as the 12s which have dicky sizes both OD and ID
Cant remember the OD but ID is 23mm, I was thinking of turning the shafts down abit to suit a more common size but none of mine were bad enough to need new bearings.
Unless you got one with elebenty billion KMs the bearings hold out for ages.
It's bullshit the money these are selling for these days.
Slightly off topic anyone got a dead SC12? need a clutch center.
