anyone know for sure what the stud pattern on an ej holden would be? i think its 124.3, thats what i got told but not sure, also a good place to get decent wheels to fit?
aussiemk2
i thought the ej was same as torana and it was 5x108?? this is correct they are indeed 5x108, which is also the same as rwd volvo QUOTE FE - HR: PCD 5 on 107.95 mm (4.25"), Offset 6mm positive.
HK - HG: PCD 5 on 107.95 mm (4.25"), Offset 30 mm Positive (except HK and HT GTS which had an Offset of 13 mm Positive, HG GTS went to 30 mm Positive) HQ - WB PCD: 5 on 120.65mm (4.75"), Offset 30 mm Towards the inside of the rim for standard offset wheels. Torana LJ/LC, LX/LH: PCD 5 on 107.95mm (4.25"). Same stud pattern as HK-HG. Torana LH with option L34 and LX with option A9X: PCD 5 on 120.65mm (4.75") with -1/4" Offset. Same stud pattern as HQ-WB with a different offset. |
tomscott91
alright sweet, wheres the best place to get wheels in that pattern without having them drilled? |
Juju beans
old school forums mainly wide small wheels tho there is a eh forum or torrie forum u could search on |
tomscott91
just plain dragway style, 5 spoke sorta thing, but big 18 or 19. i know its not origianl so dont bother saying that, nothing else on the car is either. |
