25 Neo Head On An Rb30? - can it be done?
KammdUP
  • KammdUP
  • Senior User
Post #1 post 4th January 2011 - 05:02 PM
hey guys just wondering if an rb25 neo head can be made to fit on an rb30 a8 block and what sort of gains would be achieved n/a and turbo
cheers
QUOTE (autech_s15) *
I once pooped a hammer
Current rides:
Cooled and cammed L67 manual VS on 18x9s
gutless
Yes it fits and has been used
n/a is too expensive unless ur obsessed
turbo is the way
Rancher
QUOTE (gutless @ Jan 5 2011, 11:09 AM) *
turbo is the way
Wait. Wat? How is going the N/A route more expensive? That makes no sense at all.
gutless
QUOTE (Rancher @ Jan 5 2011, 11:13 AM) *
too expensive for the gains you are making
Rancher
QUOTE (gutless @ Jan 5 2011, 11:13 AM) *
... You getting more torque then a standard RB25DE, and much more HP then a standard RB30E. Its not really that expensive to build an RB30DE or DET. If you spend a $1000 and get an extra 100RWHP and a couple hundred torque.. Thats money well spent. Its probably exactly the same gains as DET as DE. You know, you dont have to spend the extra money on the turbo charger/lines/manifold/intercooler/piping to suite.
gutless
Well Im under the impression
that if you just fit a 25 head to a 30 it won't last
especially if you turbo it
KammdUP
how much power theoretically could you get out of a n/a 30/25 with bigger cams and porting and head work and hi comp pistons? with a forward facing plenum and good exhaust
gutless
Just look through the r31 skyline club forum
all the info is there
na and turbs
Rancher
A guy on SAU built an RB30DE 5 years ago, using the VVT head. Made 123RWKW. Standard cam etc. Did a 15.1 down the quarter.
http://www.skylinesaustralia.com/forums/to...0540-my-rb30de/
gutless
QUOTE (Rancher @ Jan 5 2011, 11:42 AM) *
pretty cool
and that's using the old 33 Vct head
only had 10 degree lift under 4700rpm
neo head has proper vvt
Err no it's not
There is no such thing as a RB with VVT.
Do you realise what an RB neo is?
gutless
QUOTE (TwinCam16 @ Jan 5 2011, 12:21 PM) *
Err no it's not
ok can we settle for it having a better version of vct?
It's the same VCT.
Ill ask again.
Do you know what is different on the 34 and 33 motors?
gutless
Solid lifters
I was told the turbo was ballbearing but don't know
can't remember where I read that vvt thing
but yeah don't know too much about neos
and not gunna go research right now to prove I know things I dont
my bad.
All good.
It's just like the S14 / S15 SR20's and people thinking they have VVT as well.
sanchezz
lol..
it is a lot more complex then simply screwing a 25 head onto a 30...
if you were spending the money to do that i would be going all out with steel rods/crank etc..
zacy-g
I've heard it's well worth the money spent putting a twincam head on a 30 block, whether its N/A or turboed..
There is a guy on 31club who is nearing the end of a 26/30 N/A build and has spent something like 10 grand doing it, but he hasn't cheaped out on anything..
dirty turbo
good gain vvt oil gallery has to be modified extra cam belt tensioner differnet pistons small things really big write up on sau forum about twin cam heads on rb30 blocks
QUOTE (Rancher @ Jan 5 2011, 12:42 PM) *
15.1 is still slower than a stock SR20VE swap into an N14 Pulsar.
I did 15.2 with a stock SR in an N15
matmarhar
do u have a 25 neo head sitting around or something? i have just finished 2 years of building my silvia and the rb2530 fitted in it. I have not had it tuned yet so cant help u with gains and stuff but i can tell u it was a very costly excersise. granted everything on mine is brand new and theres no cheap shit on it atall
silver31
QUOTE (Rancher @ Jan 5 2011, 12:19 PM) *
But you don't get an extra 100rwhp or a couple of hundred ??s of torque.
Bang for buck its a losing game UNLESS you are just using your head and supporting mods from a car which has a blown up bottom end (i.e. GTS-T/GT-T/to some extent a GT-R).
Otherwise, if you have an R31, a RB30E+T will dollar for dollar be a better powerplant. If you have a GTS-T/GT-T with a healthy engine you'd be far better off spending the thousands it will cost to make it all work on other supporting mods to the original motor.
Ra ra in theory its better, in real life the gains aren't there. If you go through the SAU thread most of the engines either make the same or slightly more power than the alternative, just at considerable cost and slightly lower boost.
09ONE
QUOTE (Rancher @ Jan 5 2011, 11:19 AM) *
Oh so you have built one have you? Please do tell how you were able to build one which was "not really that expensive"
QUOTE (sanchezz @ Jan 5 2011, 02:13 PM) *
lol..
it is a lot more complex then simply screwing a 25 head onto a 30... Amen to that!
QUOTE (matmarhar @ Jan 5 2011, 04:41 PM) *
Took me ~18months to build mine, no expense spared either (didnt go dry sump though) and had to re-adjust my budget 3 times. Very costly exercise. Have had mine for a bit over a year now and the gains are kinda insane compared to a RB25. Full boost 1000rpm earlier and the fattest power/torque curve!
Jive Turkey
pretty sure I saw one for sale in the classifieds neo rb30et
but I don't believe in this whole very expensive approach to it, you can spend as much money as you want on an engine, but this can be pretty cheap if you know how to shop.
matmarhar
QUOTE (09ONE @ Jan 6 2011, 07:50 AM) *
what car did you put yours in? only asking because i am still trying to sort out a bonnet option that isnt rediculously ugly for my car because it doesnt quite fit under my standard bonnet unfortunately
PandaSil
QUOTE (matmarhar @ Jan 6 2011, 02:24 PM) *
Use bonnet spacers under the hinges.
matmarhar
QUOTE (PandaSil @ Jan 6 2011, 03:27 PM) *
its a fair way from clearing cause i have a high volume sump i couldnt mount the engine to low diddnt want the sump the lowest point . and because of the extra height of the rb30 block there was just no way of making it fit under unfortunately.
PandaSil
QUOTE (matmarhar @ Jan 6 2011, 02:46 PM) *
Is it an s13?
matmarhar
QUOTE (PandaSil @ Jan 6 2011, 03:52 PM) *
Is it an s13?
yeah
PandaSil
QUOTE (matmarhar @ Jan 6 2011, 03:01 PM) *
yeah
Thought as much, How much room do you need to clear? in mm?
matmarhar
QUOTE (PandaSil @ Jan 6 2011, 04:02 PM) *
have u done one b4 or something?
PandaSil
QUOTE (matmarhar @ Jan 6 2011, 03:08 PM) *
I've seen it done before and I know someone that has done it.
They used the same sump as you mentioned but built a protection plate for it under the car.
Also raised how the bonnet sat, I'll see if I can find pics. as it is with a 25 in an s13 you need to raise the bonnet a tad so it can fit.
AssViolator
Dont waste your money.
The sohc rb30 goes well with bolt on turbo kits. The money wasted on fitting a rb25 head could be spent on turbo kit for what you have.
matmarhar
QUOTE (PandaSil @ Jan 6 2011, 03:15 PM) *
if it was a 25 it would have fit in its just due to the extra 30 odd mm in the rb30 bottom end and the sump screwed me a few mm havent measured exact clearance needs yet but at a guess its probably somewhere round 40 to 50 mm needed at the front of the engine
KammdUP
not for my car, just thought it would be a cool project, saw an n13 pulsar with a vct sr20 kick out 135kw at the front wheels almost sounded like it had vtec :bowrofl: was BLOODY quick too hahah so i thought maybe the same sorta thing could be done with an rb30/neo and make a nutty atmo 6
