Best Dyno Place In Gold Coast - ?????
VL.full lock
  • VL.full lock
Post #1 post 11th April 2010 - 05:56 PM
hey guys what is the best dyno place in the coast?
need as much power as i can get hahaaaa
Kai
What type of car?
Matty Spry @ Pits if you want Goldcoast.
or
EFI performance at stapylton.
20VGT
So you want maximum power? and not really concerned about engine life, then just go anywhere.
Any tuner can get good power........... in most cases you just won't have it long.
rotor_head_83
QUOTE (Kai @ Apr 12 2010, 12:19 PM) *
What type of car?
or
He'd be pretty overworked surely? Everyone recommends him if you live in SEQ.
SHERIF
DYSON ROTARY Craig is the man
Strudel
Gavin Wood, Matt Spry and EFI
20VGT
QUOTE (rotor_head_83 @ Apr 12 2010, 01:12 PM) *
Yeah, but keep in mind there are always the percentage of people that don't go to him, then there is the percentage that go see him when he is cranky and never go back, then the rest caught him on a good day and reccomend him to everyone smile.gif
RetardedMonkey
efi.
Shnydes
P.I.T.S
matmarhar
What type of car?
or
yeah if u want max power go to matty spry but dont expect ur engine to last long
if u wanna be told u have bad earth on everything go to EFI performance
if u want ur engine to last go to hi torque
familia
Matty Spry all the way he gets in and gets it done without any crap and no's his stuff.
Efi are rip offs
Innocent_Commuter
Gavin Wood
hmm yes. Had my tune done there..... Felt somthing was up. Took it to another workshop down my way who ran it up, and it was an eye opener.
Ill just say this. You want your engine to stay in good health?.. its wise to keep looking around.
Matty spry is good. Ever considered a short trip to brisbane? Have some decent tuners down this way.
dyno king
dyno hire service at slacks creek
PSIcotik_Soarer
QUOTE (matmarhar @ Apr 12 2010, 05:02 PM) *
Had this myself. My plug and Play ecu somehow turned into a large re-wire of alot of things
Also came out down about 100hp. Previously trapping 121mph and prior to cam install making 389rwhp and trapping 118mph. After Efi's tune and even more boost it came out making 300hp.
2months of them trying to sort it out (nothing changed except the ECU, Emanage unplugged and wolf plugged in), they tried blaming boost leaks, cam timing, exhaust, leaking BOV. All these things were fine and not touched since the 121mph run, but they charged me to check them anyway.
In the end i ended up with 330 hp and they could not get more out of it. The tune was ordinary and a car was making less power than what a mildly modified setup would have made with a standard ecu and injectors..
In the end i got over it, as i was sick of the car being in the workshop for so long that i sold it.
On the other hand I have heard good things from nissan owners. I would just be reluctant to take a toyota there again.
Ask HiTorque about the wonderful customer service they provided(along with a shit tune) in the red VX SS one of my mates owns. He got a basic 22x cam fitted, the engine barely ran and would not idle at all after they had the car for 4 hours on the dyno. As soon as he started the car, it stalled. Drove out the driveway, it stalled. He turned around, drove it back where they told him that it must have a faulty oil pump and it would need to be replaced. He went through a tank of fuel between leaving the HiTorque and Ballina with another full tank between Ballina and Coffs. After being told numerous times that it was not their problem the engine only made 263rwKw(it made 250 before the cam!) with a worked LS1 with cam/higgins head etc and that it had to be an oil problem. I plugged in my PLX Scan Gauge and data logged the tune. Called Oztrack, got sent a custom mail order tune and sure enough, engine idles fine, drives fine, shifts fine but it was down a little on power compared to what it could have been. My mate goes to Sydney and gets Oztrack to complete an onroad tune where the engine with exact same mods as the 263 HiTorque tune makes 318rwKw with safe AFR's and perfect timing tables. Funnily enough, no oil pump was needed smile.gif
Sure, 237rwKw 'might' make the engine last but I am sure the current tune being the correct tune will make the car a LOT more fun to drive and last just as long. The guys at HiTorque would know the car well wink.gif
51KVN
QUOTE (iamhappy46 @ Apr 20 2010, 06:51 PM) *
I know the car! yes had it back quiet a few times but thats exactly what you have to deal with when a customer does the work in his own shop or mates shop. and wonders why the car doesnt make 300 like every one else! . Firstly the car came to me with out the heads on it so 260rwkw is a normal figure for your mods correct me if wrong?. The customer was adviced to remove airflow meter and mafless tune car but had a ss inductions airflow meter that had paid good money for tune around it also had a std stall convertor on std diff gears the car is always going to be on the edge of idle.
Oil pump? the customer wanted to know why there is a lifter noise in the car when driving! in some cases the lifter become noiser when fitting the fast manifold because its made of polymar plastic not think GM material it generates more noise. If wanting to fix this noise change the oil pump which gives more oil pressure at low engine rpm therfore quiter operation, not rocket science.
318rwkw well done bring it by for a free dyno run but sounds a bit high( but you did say you road tuned it so it might feel like 318rwkw) 2nd gear chirps?
11SLI
iamhappy = SNAP! You are a fukn Fool...
Go see the guys down at Hi-Torque...
They have a crazy amount of knowledge with all types of cars/setups/custom jobs...
Awesome guys to deal with and straight up no fuss!
Timmyp34
This is way you pick a workshop and stay with it so thry know what has been done to the car since they do the work and fix your own fuckups on the car. But jumping from work shop to work shop to try save a dew pennys doesnt work well at when something does go wrong with the car and the "new" workshops has noidea about whats been done so they have to go and check everything on the car.
EFI will be tunning my car.
SkiDMaN
pits
matty wont fuck u around.. will tell u how it is straight up no dicking around
this makes me laugh.... if any thing... matty is one of the safest tuners around... ur engine is bound to last the longest cause he doesnt tune them to the verge of popping unlike other workshops already mentioned
MuchDa-Bogan
ive been to matty spry and another few tuners. i have to say out of the lot dyson was the best priced best tuned and more customer care than the rest. and no i dont own a rotor. a big +1 for Craig at dyson
s13viper
You will find good and bad stories about all workshops. Trick is to seperate the bs from the truth. There IS some good workshops around here, im getting a fair amount of work done at one of them shortly so we will see how it goes.
You get what you pay for
JuStDaVe
What type of car?
or
these 2 are my recomendations for any decent tuning .
skyline stuff - mark at godzilla his mapping is awesome.
hi torque know there stuff with v8 turbo combos seen a few beasts come from there
QUOTE (51KVN @ Apr 20 2010, 08:29 PM) *
So what happened when it was stalling, not idling and the knock sensors were going off constantly though after it left? It did not 'feel' like it had more than 260rwKw when he got smoked by a stock VX auto with a mafless tune. Surely the red VX was taken for a road test at some point? The Fast manifold was already on before the cam went in, had no lifter noise and now that the new tune is in the car, the rattling noise is completely gone and no need for a new oil pump at all. A maf tune is not that hard to get right but using fuel trims of up to 25%? Stock intake manifold is polymer as well and even when it was temporarily refitted, it made no difference to the noise.
Sure, the customer had no complaints from the original tune before the cam went in(the original tune was fine with the FAST 92 as well) but after he got the cold shoulder when it was running like shit after the cam was installed and the guy on the phone he spoke to NUMEROUS times who said he would call back and NEVER did(alright, I believe he called back once ut M logged every call and the guy never called back when it counted) He never ever bothered replying when the rocker covers were lifted and one of the valve locks was only being held in by the roller rocker... I was there when the call was made, overheard the convo but no call back on a customer who had a major issue
Funnily enough, it idles fine now with a small lope, drives fine and shifts beautifully. 3rd chirps wink.gif
As for 300+rwKw: http://www.ls1.com.au/forum/showthread.php?t=129510
Oztrack tuned a car a few weeks before that was 'similiar' so sent up a mail order tune that was near perfect.
Happy to take this to PM if required,
QUOTE (11SLI @ Apr 20 2010, 08:45 PM) *
Where is the SNAP?
Micko
Hitorque have done awesome work on my car and a lot of mates cars. +1 HiTorque.
51KVN
QUOTE (iamhappy46 @ Apr 20 2010, 10:33 PM) *
Where is the SNAP?
"The Fast manifold was already on before the cam went in, had no lifter noise and now that the new tune is in the car" I noticed you have put new lifters in it on the other forum yet you blame the tune for creating lifter noise! A LS1 airflow meter becomes a restriction anything above 280rwkw because of it physical size.
We can argue about this all day but i can't keep every customer happy, i try to! but can't because some won't listen or won't take your advice!
TUFF VZ
dont worry about "die tourqe" go to powertourqe really goood service and very helpful
51KVN
QUOTE (TUFF VZ @ Apr 21 2010, 08:03 AM) *
Nice spelling fuckwit tourqe is spelt " Torque"
bf_jet
Its funny u know how some fuck wit can bag Hi torque, what do u clowns drive?
I own a car they have built and it makes over 600rwhp and is drive every day, and driven hard, its NEVER ever missed a beat! So shut the fuck up and stop being a key board warrior and go and crawl back under that rock u came from... hsdance.gif
dont see any other people building VE uts running 140mph+ into the 10's street driven also and many many other cars..
take ur red heap of shit SS and get it tuned else where.. see u @ power play if u wanna see how a real Hi Torqur car is tuned and driven!
Happy Days Bitchs!
autech_s15
Pro Torque Performance - Pete is pretty amazing on the dyno.
Hell he got an extra 30kw out of my RB25DE R33 just from a good tune laugh.gif
autech_s15
QUOTE (bf_jet @ Apr 21 2010, 08:48 AM) *
Happy Days Bitchs!
Hey Muppet,
How about you drive your 9001hp shitbox into a brick wall for all we care, this was a civil debate before you came in here rattling off insults and swearing like a lowbreed.
Cheers.
TUFF VZ
bahahahaha people get angry so easy hahhaa u clowns amuse me
51KVN
QUOTE (TUFF VZ @ Apr 21 2010, 08:58 AM) *
No point advertising a company you like if you can't spell there name right!
Power torque do great work not a bad comment from me on that!
ONN20
+1 for Matt Spry.
RIPGTR
dont know y the guy wouldnt just call them back if hi torque didnt call him first?? if it was a warranty on labour issue im sure the boys would rectify it asap.
i own a hi torque built car and as bf_jet (hey maddicks tongue.gif) said cars that are built down there are done right. havent had a problem with mine and ive had it nearly a year now. i seriously cant see how kent or dallas would fuck up on a holden when its the car that they specialize in.
just my 2c\
JuStDaVe
QUOTE (SHERIF @ Apr 12 2010, 01:13 PM) *
Craig is no longer there . And due to hard times and slow business unfortunatly Dyson Rotary and Performance will be closing too.
So much hanging shit wow
In my time in the industry shooting cars, majority of them have been tuned and or worked on by hi torque, matty spry, godzilla motorsports, and quite a few of late from ben hunt at rotary motorsport.
I have dealt with all of the companys and would have no hesitation in sending anyone to any of the workshops mentioned.
