im wondering ifi can put a winch on any bull bar. its steel, so can i drill holes?? or whats the go? do i need to get a winch bull bar
dobermann90
wat he said... the bullbar need to be firmly bolted directly to the chassis of the 4wd. and the bullbar need to be able to take the load of the winch as well |
smiley
so basically the issue is the way the bar is attched to the car, and the winch attached to the bar? do winch bars have better supports so to speak that connect to the car? exactly mate. winch bars are stronger all round with much stronger mounting points for attaching the bar to the vehicle and the winch to the bar. |
dobermann90
would be the best idea... you dont want the bar to get ripped off the 4wd. could damage a lot of components. |
smiley
probably not the damage really. as it would only damage the old bar. but you will find that you will have no front bar, or only part of one and STILL be stuck in whatever it was that you were winching out of. THEN, when somone finally comes to help. they'll laugh at you. Best save your pride. haha. |
dobermann90
not just going to damage the front bar... the winch is wired to the battery... dont really want the power cable from winch to battery to get ripped out... could be a bit messy... |
dobermann90
if there working properly. only catch is... as far as i know. you cant have air lockers and lsd.. so if the air lockers aren't locked... you got a set of open centre diffs. and if you got them locked.. and turn... you risk blowing the diff. |
slow_eg
im just doing a bit of research... its got the ifs, so its not gonna be insanely tough, but its gonna be fun. so whats the point of having air lockers if u cant turn? sound a bit useless to me, id be better putting shims in the diff and making it a tighter diff?? i dunno, ill look into it later on. i just dnt wanna spend up big on it, saving for a house so i thought ill get a 4wd and get outta the import scene... so far it hasnt been anywhere near as expensive, and i dnt think it will be and ill still be able to have fun.l |
headsense
A proper winch bar is designed to accept a winch cradle or mount. The mount will transfer the load and gain support from the front chassis rails. |
dobermann90
you can turn... as long as the wheels are able to break traction and left the axles rotate at the same speeds. probably best to have a good talk to a 4wd shop and see wat they recommend for wat you want to do. |
gotta_b_a_lux
ah ok then.... and also, its a steel bull bar. well then its possible to fit a winch but not without modifications strong enough to supprt it, if you cant do it yourself there are places out there that will modify the one you have but buy the time you pay them you would have been better off selling the one you have an getting a winch bar, doesnt have to be a brand new one... |
