i have a vs statesman 5L, looking for a performance shop that are good with them..would like some help..i have called a dozen places and they want nothing to do with them..
vk134
It really depends what you want to achieve, your power and rev range limitation is the original manifold, but by doing a basic reco, 355 stroker kit, reco the heads, 3 angle valve job, port and polish, free flowing exhaust, roller rockers and a larger hydraulic cam. It should easily be in the 300 -350 hp range, this matched with a stall converter and rebuilt auto and lower diff gears should get the Statseman going ok. |
gottboost
im not so much looking for big power. i was thinking of putting a cam package and rockers,memcal but i just want the thing to last and be reliable. in the last 2 weeks its been idling rough when started. goes away after a few mins. around 2000 kms ago i had it serviced. |
vk134
im not so much looking for big power. i was thinking of putting a cam package and rockers,memcal but i just want the thing to last and be reliable. in the last 2 weeks its been idling rough when started. goes away after a few mins. around 2000 kms ago i had it serviced. the stato only has 166600 kms on it, doesnt burn oil and stays pretty clear.just had the gearbox rebuilt corvette servos,performance bands etc stage 2 shift kit. also put a lsd from a series 3 stato (not sure on the ratio) got a full twin 3' exhaust.. .looking for a honest shop that won't beat around the bush. Ok easy job then, get a compression test, bottom end should be fine, they rarely wear out if serviced, then heads off, 3 angle valve job, new springs, k-line guides, shaved to increase compression ratio, roller rockers, crane Compucam H268 and lifters, new or reco injectors. It will bring it up to around the 220kw and still have great economy. |
vk134
All I could recommend is for about $400 in quality tools and a few books, you could do it yourself. Removal is straight forward, drain coolant and oil, remove fuel rails, electrical, label as you go. remove manifold, then heads, keep all in order in cheap plastic storage bins, then radiator out, front of engine apart, it would be due for new waterpump and prob harmonic balancer by now, remove lifters and cam (they are bin jobs). |
