Hq Ute Build Thread. - Another one!
Page 1 of 3
Be-Hating
  • Be-Hating
  • WTB: Aussie pride sticker. Lulz
Post #1 post 5th August 2012 - 04:26 PM
Hey all,
Now my hq sedan build is nearing its end with a few minor things left to do I went out and bought my self a ute for the next project!
So here it is, A 72 hq ute ( Previously a PMG car ) with a 179 and 5 speed celica box. The interior isn't too bad but the dash has been re-done with VDO guages and a hj steering column, which i'll be removing and replacing with a hq monaro dash and steering column hopefully. It has close to no rust besides in the sills ( which someones already tried to patch ) but other then that theres no rust. It's been respray in some ugly purple colour and the original " Mercury Red" is visible all over the car and a sun roof has been installed. ugh.gif But yeah overall it's not that bad and should be done a lot sooner then it took me to rebuild the sedan.
The plans are as goes; White respray and take the hz front off and put a hq kingswood front back on, Tidy the interior and colour it all black with a monaro dash and some bucket seats. Lower it 2" in the rear ( fronts already been lowered) and dump it on some 5x7 pursuit rims with maybe some red walls. I may also be buying a pretty hot 186 that's meant to have been fairly worked and is running a 650 holly. ohmy.gif
Heres some photos of it looking pretty dogish.
1972 Holden Hq Kingswood. - Restoration thread
1972 Holden Hq ute - Restoration thread
gutless
IN!
you're a boss.
Edit:Why would anyone put that front on a HQ and you should totally put a Q Prem front on oopsie.gif
CAM-327
Lol @ prem front.
Single headlight front will look neat man. With the future plans i think you should make the engine bay as standard looking at possible, but have it go like a shower of sh!t (but it's still a Holden 6). Would track down a better power steering bracket too... ugh.gif Also, i'll sell you my wheels before you go putting commodore pursuit wheels onto it too, eve if you picked up some standard steelies etc..
Can't wait to see you dig into this!
75 KINGSWOOD
Something like this would be mint -
Edit: If your going pursuit rims, im hoping your changing you hubs otherwise its an accident waiting to happen
gutless
QUOTE (75 KINGSWOOD @ Aug 5 2012, 06:30 PM) *
Now we're talkin!
Nice hat!
75 KINGSWOOD
QUOTE (gutless @ Aug 5 2012, 07:31 PM) *
Now we're talkin!
Nice hat!
your weird tongue.gif i wear a beanie..................
Be-Hating
QUOTE (gutless @ Aug 5 2012, 04:28 PM) *
IN!
you're a boss.
Haha I have no idea man, Hence why I'm changing it back.
QUOTE (CAM-327 @ Aug 5 2012, 05:43 PM) *
Lol @ prem front.
I was thinking about this, Just sticker it up like the motor in the sedan but I also wouldn't mind dressing mine up like your's with the finned covers and what not. Still undecided.
I'm putting pursuits on or if I find a good set of convo et's cheap i'll slap those on.
I saw that on ebay and can say I'm not really a fan, Maybe if it were a single light front and no visor haha. smile.gif
Won't need to change the hubs if I run spacers. Pursuit rims fit on the back fine, It's just the front.
tonneroffun
commodore to hq stud pattern is not the same man,its not the offset that is the problem its the stud pattern
2tonhq
i have a couple of hq single headlight nosecones here if you want one and will have a set of guards and a bonnet available soon too cause ive picked up a hq statesman front for the 6 wheeler
Be-Hating
QUOTE (tonneroffun @ Aug 5 2012, 07:26 PM) *
Not sure if serious. I think the stud pattern is slightly different but they still fit, There's a picture above to prove it. I can run pursuit rims on the rear and they fit, But on the front I can't because the it doesn't clear the hub. Easy way to solve this it just to die grind the centre of the rim and then it'll fit but then the rim hits the ball joints when running 15x7's
QUOTE (2tonhq @ Aug 5 2012, 07:29 PM) *
Definitly put me down as buying it, Especially that bonnet. How long until you'll have it all off and want it gone?
tonneroffun
oh im serious man,even you just said that it is slightly different,that slight diifference is enough for the wheel to start breaking studs off
gutless
QUOTE (tonneroffun @ Aug 5 2012, 07:50 PM) *
Woh. even i knew this. Damn Joel, i assumed you knew this. I remember ben and a few others talking about it ages ago.
Be-Hating
I know, If you read though I said i'll be using spacers. The spacers i'll be using are hq stud pattern and they bolt to the hub then there's another set of studs on the actual spacers that are commodore stud pattern in which the rim bolts to.
QUOTE (gutless @ Aug 5 2012, 07:53 PM) *
I know this, As above^
If anyones confused see here: http://www.ebay.com.au/itm/280921098696?ss...#ht_1736wt_1163
gutless
Word. Illegal but who cares.
75 KINGSWOOD
QUOTE (gutless @ Aug 5 2012, 08:53 PM) *
Do you know what a carburetor is?
QUOTE (Be-Hating @ Aug 5 2012, 08:00 PM) *
that works okay, just be sure to use the right spacers man (hub centric i think all the proper adapter spacers are?)
i hate going that way because it eats into the amount of dish you can have haha
Be-Hating
QUOTE (clutch-monkey @ Aug 5 2012, 08:12 PM) *
Yeah, they'll be hub centric. I don't mind about the dish though as I'm not chasing anything other then standard sized dish. Well that's if I end up running pursuit rims. Convo et's will be a different story. haha
Be-Hating
HAHA funk off bitch. Finish a car and then you can have your opinion!
But yeah, No hq steelies. Every kingswood has kingswood steelies and it's funking boring. I like utes with pursuit rims so that's the go. If you find and buy me some convo et's I'll gladly put them on and burn the pursuits.
fisky82
75 KINGSWOOD
If it comes out anything like your sedan, it will be an awesome ride
Be-Hating
eh spacers are safe...ish. Dad ran spacers on his stato for a few years before he had the rims he currently has and had no problems with them.
QUOTE (Be-Hating @ Aug 6 2012, 11:34 AM) *
spacers from factory, lasted since 1978 through some ..rigorous... use.
so yeah on the street i think you'll be fine!
Be-Hating
Haha that's cool!
I'm also curious, If spacers are illegal why are they used from factory?
And also if they're unsafe why are they used in racing?
Draven
I dont mind the look of the Prem fronts on kingys, good luck with the build...
CAM-327
Just sayin' Joel..
75 KINGSWOOD
mint
that is just porn.. what kind of hp could you get out of that?
75 KINGSWOOD
QUOTE (clutch-monkey @ Aug 14 2012, 02:10 PM) *
200-300
CAM-327
300hp ATW at the very max. But thats after 15k worth of work.
Mine will look something like that once done. Minus the 4k worth of webers....
Be-Hating
Mine will hopefully resemble something like that but less tripples and more 4 barrel ( if I end up getting this 186 ).
2tonhq
[/quote]
sorry for the late reply,google chrome had a virus and wouldn't let me onto boost i have a single headlight front sitting here ready to go now from one of my sons tonners not sure how long before the rest will be ready cause im toying with the idea of a flip front so not sure if i want to use the other bonnet or just put a scoop over the hole in the one ive got and i will be using the other guards so have to do the swap before they will be available but i guess if i was to get offered the right price i could make a quick decision as its a daily driver and time is not my friend atm
Be-Hating
So i've been jumping around the cars this weekend but what I did get done on the ute was;
Picked up a single headlight quee front off 2tonhq ( Thanks again ) and sanded,primed/puttied and guide coated the bonnet to go onto my sedan and then picked up ANOTHER bonnet today and bare metaled/ primed it to go onto this. and then quickly bolted it on and grabbed a photo. Bad photo know....
And during the week I stripped the interior and removed the hole front end and go rid of it.
Also bare metaled the cowl panel and found there's no rust or signs of repairs so thats a plus.
Paint stripped the bonnet:
After the first coat:
And after the second coat and then hitting it with a rapid strip disc:
And a coat of primer:
I'll need to smooth it out and lay a few more coats of primer on before its ready. The next move will probably be lifting the motor up, spraying the chassis and the engine then slapping it back in.
2tonhq
jeez ! you don't funk around do ya i only dropped all that sh!t off 24 hrs ago good work man
Be-Hating
Haha thanks. All the front will be coming back off to attend to it's ruff bit's but yeah. Coming along good.
I really want to get the motor, Chassis and fire wall sprayed and out of the way then start on the body work but eh. Haha.
julio_vasquez
I like the twin headlights better
Page 1 of 3
