Dog Box - how much
hershwon
  • hershwon
Post #1 post 6th August 2006 - 04:42 PM
just wondering i have a stock pulsar box in an n14 with a gti-r front cut n just about to work it a bit and know the current box will not hold up. any thoughts on wat to do had a couple thoughts if anyone can help. putting the gti-r gear box internals in my current box or getting the 1st 3 gears dogged any how much that would cost roughly.
Thanx Guys
Past Cars:-
79 Toyota Carona R.I.P (RalPh)
97 Vs Commo R.I.P (Kenny)
93 Vr Commo (Clarence)
93 N14 Pulsar Full GTI-R Front Cut
95 EF Falcon XR6 T3/4 Turbo
01 SRI Barina 1.8l rims, zorst, extractors, pod (girlfriends weapon)
Anyon wanting Air Conditioning (cashie) Northside Bris
ducted/splits send me a PM. Great Prices
Tom Tucker
Dog boxes generally cost upwards of five grand man. It might be cheaper if you only do the first 3 gears, but I doubt it, mainly due to labour costs.
hershwon
do u know were i can get a closer cost at all
Tom Tucker
http://www.ppgearbox.com.au/
MAX452
either ppg or
http://www.par-engineering.com/
SWIFTY
as MAX452 mentioned....they are your cheaper dog gearsets. There's also Modena, Hollinger and Albins gearsets but the price goes up considerably.
What use for the car? drags? As far as i know, GTi-R boxes are pretty tough...it's the selector forks that are the weak link in them.
Mine cost just under $7K for PPG 1-4 including billet forks, a few bearings and interlocker kit.
Nvious
$5,000. or near so for Straight-cut gears for the N14 2.0L gearboxes.
hershwon
only want 1st 2nd and 3rd
flyline
dont u need to get a clutch with it?
hershwon
need new clutch anyway its fried
12NVI
PAR is the best for the SR20 fwd gearset. They have a 1st to 4th straight cut gearset retaining the synchros for easy shifting. Still uses standard 5th gear. I paid about $4500 installed for mine and it was the best money i spent.
On top of that you can get billet selector forks, 5th gear, and crown wheel. So it all depends how hardcore you want it to go that will determine the price.
They do have a Dog engagement gearset but if its a street driven car i wouldnt recommend it as the dogs need regular maintanace as they wear out after time.
hershwon
i dont have a gti-r box its a standard pulsar box will this be cheaper or will they not even touch it. its just for normal driving with a little street racing i guess. all legal of course tongue.gif laugh.gif tongue.gif
SWIFTY
QUOTE(hershwon @ Aug 8 2006, 02:05 PM) [snapback]1280134151[/snapback]
A dogbox is definitely overkill for your needs then.
12NVI
i blew 4 standard boxes by just normal driving with the occasional midnight run. that was over $3000 worth of boxes plus labour if you cant do it yourself. thats almost the cost of a PAR gearset!
with the stocko box it WILL blow... its just a matter of time.
Nvious
What boost did you blow your gearbox at?
Also, any u13 parts left over?
SiL8E
preety sure the gti-r internal's in ur std box will do the job good, straight cutting 1-3 is heaps more exxy
Ahmad
12NVI how long did it take for the PAR gearbox to be made and fitted
hershwon
do u know of anyone that has put the gti-r internals in standard box or were can possibly get a gti-r box. coz that was first thoughts but dog box sounded like a phat idea but costly
12NVI
QUOTE(Nvious @ Aug 9 2006, 04:34 PM) [snapback]1280138230[/snapback]
sorry have no parts for the U13... did the U12 swap. boost was around 17-18psi...power was around 210kw
QUOTE(Ahmad @ Aug 9 2006, 09:07 PM) [snapback]1280139409[/snapback]
from memory it took a while but i think they have the parts on shelf... depends how busy they are. best thing would be to send a broken or spare box for them to build so your car isnt off the road.
QUOTE(hershwon @ Aug 10 2006, 01:37 PM) [snapback]1280141062[/snapback]
the GTiR gearset cant be done as far as im aware of. it is alot of money to dish out, if you plan on keeping the car for a while and plan on putting over 200kw of power into it id get it done... id rather put money into a straight cut gearset than the replacement of broken gearboxes!
i wouldnt even think of dog boxes man... unless you want to be matching revs each gear and grinding the teeth alot. go with the straight cut synchromesh gearset if you do upgrade it thumbsup.gif
