10th June 2009 - 01:45 PM
Post |
ive got a wb kingswood styleside ute and it had a 202 in it ive removed it now and want to put an 8 in it most likely a 253 so its not too bad on fuel do i have to change the k frame or anything else in it also does anyone know where i can get a celica or supra 5 spd cheap ive got a 4spd but dont want it and what sort of shit do i need to do to get it registered do i need a mod plate thanks for your help guys. |
eh-buddy
ive got a wb kingswood styleside ute and it had a 202 in it ive removed it now and want to put an 8 in it most likely a 253 so its not too bad on fuel do i have to change the k frame or anything else in it also does anyone know where i can get a celica or supra 5 spd cheap ive got a 4spd but dont want it and what sort of shit do i need to do to get it registered do i need a mod plate thanks for your help guys. to put a 253/308 in it you will need v8 engine mounts and a hq style sump as the chassis are the same your wiring will need to be lengthend for your starter motor and you will need a wb v8 radiator as the 6 cylinder radiator has the out lets on the wrong sides for a 253 also your motor should be a "blue" motor to be easy on a mod plate if you need one but most inspection guys realy dont care you may need v8 springs and your 4 speed needs to be out off a v8 or it will not fit as the input shaft is different the diff will be strong enough even if its a borg warner style diff compared to the salisbury 10 bolt style |
carlover333
Hey mate. |
carlover333
yea i was also thinking about stroking a 308. |
"The 253 is an amazing engine - it has the fuel consumption of a big 8, yet the power of a small six" |
VKGRP3
to put a 253/308 in it you will need v8 engine mounts and a hq style sump as the chassis are the same your wiring will need to be lengthend for your starter motor and you will need a wb v8 radiator as the 6 cylinder radiator has the out lets on the wrong sides for a 253 also your motor should be a "blue" motor to be easy on a mod plate if you need one but most inspection guys realy dont care you may need v8 springs and your 4 speed needs to be out off a v8 or it will not fit as the input shaft is different the diff will be strong enough even if its a borg warner style diff compared to the salisbury 10 bolt style Hit the nail on the head mate, but as far as i know you have to get the bigger brake booster aswell just about to do similar conversion |
eh-buddy
Hit the nail on the head mate, but as far as i know you have to get the bigger brake booster aswell just about to do similar conversion the brake booster is the same in drum rear end theres no differance in 6 or v8 brake booster/master cylinder the only differance is a dual diapham brake booster for disk brake rear end |
eh-buddy
253's aren't that bad. Don't use much fuel. Depends on what it's being used for though. I have a 253 blue motor for sale. It's much easier to change k frame and all that at the same time aswel. That's what i do, cheers k frame???? hate to brake it you dude but hq/wb utes are full chassis cars and as for the conversion 6 cylinder and v8 chassis are the same its just the engine mounts and sump that are different |
