24th May 2009 - 11:54 PM
Post |
is some sort of approval needed to swap from an alloy tray to a styleside tray of the same model?
Dan_The_Man
Would also like to know, and where the best place to get one would be? for a 2004 hilux dual cab 4x4 |
that_rodeo_guy
That's a good question. I would also like to know haha. |
luxxy101
there shouldnt be legalities with it dosent say on the engine bay plates 2wd tray blah blah blah , so u should be alright but if u do change it make sure u ring up ur insurance 2 tell them ur car has changed as they will be like hang on ur car didnt have this on it before blah blah blah shit storm occurs |
wolverine89
As lickme stated, no you don't have to get it mod plated. As it has nothing to do with the load rating, of passenger seating. |
ModMasterPaul
would it be much harder to put a space cab style side on instead of a single cab longer style side on if you guys no what i mean wot, shorty or gappy? on topic, wolverine89 is spot on with how to. there also shouldn't be any legalities involved however my id plate says toyota hilux rn25 c/c. assuming c/c means cab/chassis and asuming cab/chassis means factory trayback not tub then technically i would probably need some sort of certification saying i have "modified" my vehicle, sorta in the same manor an engine needs certification if it differs from the one on the id plate? ps if u have access to an A frame and block n tackle then it's heaps easy to lift off n drive out |
heathy003
wot, shorty or gappy? on topic, wolverine89 is spot on with how to. there also shouldn't be any legalities involved however my id plate says toyota hilux rn25 c/c. assuming c/c means cab/chassis and asuming cab/chassis means factory trayback not tub then technically i would probably need some sort of certification saying i have "modified" my vehicle, sorta in the same manor an engine needs certification if it differs from the one on the id plate? ps if u have access to an A frame and block n tackle then it's heaps easy to lift off n drive out Like a shorty |
ModMasterPaul
yes a shorty would be MUCH harder than just swapping a tray unless you are adept at swinging the electric axe and applying the electric glue. n i think a shorty is only legal when the length is taken from behind the rear axle n not cut n shut to make a shorter wheelbase tho i could be wrong. pretty sure there was a topic somewhere on boost bout shorty. |
5EX4A1
omg! people you do not need any sort of approval to change ure tray to a tub or visa versa... cab chassis is exactly what is says...has nothing to do with the rear, hence why it's all removable.. |
5EX4A1
no_fear_609
ive wanted to do this for awhile was thinkin an 08 cab chassis tub or just an 05 model i think you should stay with from 97 i think it is till then end of your model, i think it would look much nicer. |
