18th January 2007 - 06:39 PM
Post |
I've got a pod filter in my R33 skyline, was wondering if it's legal? or does it need to be separate from the engine bay? Thanks |
Rookie ROX
QUOTE(51NGL @ Jan 19 2007, 02:01 PM) [snapback]1280687460[/snapback] long as its sercured by a proper bracket (auto bahn now sell these in capalaba) and doesnt require a heat sheald, then u will be fine also i hope u dont have a front mount....cos then ur fukd lol Not quite sure how you can sell a bracket when each car is different And front mounts are completely legal if you haven't removed any of the crumble zone of your car, nor put your piping through your battery tray. Otherwise a simple mod plate can legalise that. If it's secure, you shouldn't have a problem. If you're concerned, stick the stock airbox back in. Edit: Despite the fact this question has been answered umpteenth times, why ask the question now and not when you put it on? ROCK ON R~R |
sick_sr20de
QUOTE(Rookie ROX @ Jan 19 2007, 02:57 PM) [snapback]1280687757[/snapback] Not quite sure how you can sell a bracket when each car is different OMG ROOKIE doesnt know something!!!!!! First time.. Well the bracket is simply a 25cm piece of steel about 1mm thick and 25mm wide. Its got a hook at the end. U hoseclamp the hook to the pod and u bend the metal out to fit to any bolt in ur engine bay |
51NGL
QUOTE(sick_sr20de @ Jan 19 2007, 05:40 PM) [snapback]1280688625[/snapback] OMG ROOKIE doesnt know something!!!!!! First time.. Well the bracket is simply a 25cm piece of steel about 1mm thick and 25mm wide. Its got a hook at the end. U hoseclamp the hook to the pod and u bend the metal out to fit to any bolt in ur engine bay BINGO!!! they're adjustable fitting. and as for the FMIC. i was under the impression that u were not allowed a pod AND front mounted inter cooler. nothing bout 'pertruding or what not' |
Rookie ROX
What relation does a pod filter and intercooler have for safety? |
Stuit
QUOTE(51NGL @ Jan 19 2007, 10:42 PM) [snapback]1280689318[/snapback] and as for the FMIC. i was under the impression that u were not allowed a pod AND front mounted inter cooler. nothing bout 'pertruding or what not' no such rule. as long as the front mount fits without cutting anything and doesnt protrude outside of the car its fine. a pod filter has nothing to do with a front mount either. |
BozzA
QUOTE(51NGL @ Jan 19 2007, 10:42 PM) [snapback]1280689318[/snapback] BINGO!!! they're adjustable fitting. and as for the FMIC. i was under the impression that u were not allowed a pod AND front mounted inter cooler. nothing bout 'pertruding or what not' Are you from VIC? I think thats the only place that has such rule, something about only being allowed to have 1 intake mod. |
jeffers1987
i think singl was referring to the topic starters avatar pic when asking about having front mount. |
TAINTED180
can anyone recommend a place on the Gold Coast to get a mod plate for a FMIC that goes through the battery tray? |
15uzu
QUOTE(ro7ang @ Jan 19 2007, 12:40 PM) [snapback]1280687127[/snapback] You will pass roadworthy, depending on how it's done you can still get defected for it though. I'm assuming you're one of those people who accept the coppers bullshit excuses for defects If your vehicle is passed as roadworthy with a modification, there is nothing the coppers can do or say - they can write you out a ticket, & you can say to them see you in court & the magistrate will nullify it (the ticket) as the vehicle was deemed roadworthy with the modification. If you are worried about it, have the roadworthy inspector specifically write the brand & type of filter on the certificate & carry it around in your glovebox. Don't ever let a cop try to bluff you into accepting a ticket. |
