53XXN_ST80
So mint! I wanted to turbo my Statesman, but didn't wanna do it on a cam only motor |
robbo1
haha yeah took it down the 1/4 with street tyres and running on 7cyl with run in tune ran a 12 ... had the worst day that day with all the problems and couldnt hook up just was smoking half track the way it was with the problems .. so fixed up now and will be going back soon with slicks ... should run a high 9 low 10 after a few runs |
XRA73 NAVARA
Since when has 2x 044s and 60ld Siemens DEKAs been a HUGE fuel system. |
robbo1
Since when has 2x 044s and 60ld Siemens DEKAs been a HUGE fuel system. Good luck getting enough fuel to make it past 800hp. since i have replaced them with A1000 fuel pump and i have 600hp at this point with the deka 60lb injectors and the tuner says there is alot more left in them for my hp goal . |
AGI78-GTO
justin( the tuner ) recons closer to 900-1000hp atw with wot i have .he has tuned std turbo 5.7 to 760hpatw so u tell me . i am just upgrading everything as it needs to be to get the most hp i can will be interesting to see what she makes mate, must be running a pretty damn high base fuel pressure to still be using the deka 60's though ! she's a pretty good sleeper ! |
robbo1
It made a comfortable 726.5 and with 1000cc injectors I borrowed with my new fuel system made a max of 989rwhp and I have been told I need more head work for more power .i would have to say 726.5rwhp is enough considering the big stally and auto unsure of exactly wot he did to get it that far i just wanted to see wot it was capable of.i know it was around in the 15psi mark |
