75 KINGSWOOD
Post #179
Easy fix. Dont weld. Use bog instead. Dont listen to this guy,he's ret..........special |
Be-Hating
Post #181
So today I patched up the rust around the rear window, doors and guttering and started sanding the roof but had to stop do to complaints |
Be-Hating
Post #187
Hahahaha, Didn't think you would actually put the photo of you sitting in it on Boost. OT: Looks mint! Hahahaha even put it in OT. Just waiting for the flat cap stereotypes. Try and be more consistent with your guide coat mate. An even mist over the entire panel is what you should aim for. Coming along well. ![]() Will do. |
Be-Hating
Post #193
Awesome job ![]() Thanks mate. Old holdens are awesome and so basic making it easy to learn from. Especially for someone like me doing their first rebuild. Joel, i realized i got rid of my hubcaps with my purple car, but i do have a few others, they may not all match, but you could polish the black off them all so there all chrome and they would kind of look uniform, they are yours if you want them. Yeah dude, I'd rather hubcaps with a chrome centre and the black stripe. But I'm watching these (http://www.ebay.com.au/itm/Hq-hj-hx-hz-Holden-Hubcaps-Hub-Caps-/180820322443?pt=AU_Car_Parts_Accessories&hash=item2a19bb288b#ht_298wt_60) at the moment so depending on how I go I will probably buy them. |
DeadSled
Post #194
Joel i cleaned up my original caps the other day with a soap steel wool pad (these things are amazing) and it scrubbed the black off. |
Post #195
Joel i cleaned up my original caps the other day with a soap steel wool pad (these things are amazing) and it scrubbed the black off. Anyway, an old trick which i'll do eventually when i redo the caps is to get a syringe with a needle end and some paint of your choice, suck the paint up and use the syringe to spread the paint into all the lowered areas that require paint and it lets you get in random hard to get spots without fucking it. Just think, if you fuck it up let it dry scrub it off and try again! Or just spray the whole thing and rub it back with a pad revealing all the lowered painted parts. |
Post #198
What i did with my rocker cover/side plates is paint the entire thing then wipe over with thinners at it brings it up well. That or masking it works well if you don't use too much thinners on the rag. Though with the detail in the hubcap I don't think it would work. ![]() |
Be-Hating
Post #204
wow Joel, your dad is making good progress ![]() nar man, is looking really good, you should be stoked!! Hur Hur, Team effort. ![]() It's my first time doing a rebuild so obviously he's going to be doing more then me, showing me what to do and what not. But thanks man. Doin good man, keep it up. Get the fucker done for Wintersun! Be thankful you don't have to put the body on its side to finish the rust *cries*. Thanks man. It should be done by wintersun as I said. As soon as it's painted and the exteriors looking good I'll be registering it then finding the bits for the interior as I go along. |
Be-Hating
Post #206
Thats awesome. I'll never put something like that in my car though. If I do end up putting a v8 in it it'll just be something like a 304/308 with vn heads, Small cam, extractors, decent ignition system and a good manifold + carby set up painted in original colours so nothing really looks out of place. That way it'll still be a cool cruiser AND have a bit of power. |
Be-Hating
Post #207
So bought a passenger door ( which was shit and I ended up using my original one ) and 2 guards in good condition without rust. |
Be-Hating
Post #208
Since last update we've done : |
