Rb25/30 Build. - Help and Support.
Page 2 of 3
gutless
QUOTE (Slideways_master @ Sep 29 2011, 10:03 PM) *
yeah true mate i hate the things, re the wanker that abused me fuck off dickhead i own a vy and i work on many of them just because they say on paper what they will doesnt necessarily mean thats it the be all and end all and no the ls2 and 3 burn the oil black as dirt within 5000kms quite regulary. and to compare a AMERICAN CHEV to an cast iron rb is fucken just as stupid! rb is smaller engine less cylinders and can make the same amount of power and still beat the AMERICAN piece of crap down the quarter, around the track and up a fucken hill whilst being far more reliable, and while we are on this note the thread is about 25/30 so fuck you and fuck ya holden commodore shit of fuckhead i never asked for your insults.
SO in regards to cost and stuff gtr injectors will run it but not high on power. spend around 6k on everything biggest thing though is the machining i've been doing alot of research into this and paint the inside of the bolk, knife edge it and take out the burrs and get a good oil pump
Naturally aspirated engines just don't seem to last very long hey?
That's funny...
Cause working at Holden I can a sure you that it was the VT / VX LS1's that had oil issues with regards to the pistons.
I have seen MANY LS2's including a VZ R8 6L in my family that has no sign of black as dirt oil.
Now going by your username (i know i know, a lame thing to do) I can only assume you are a typical low life drifter scum and have some obsession with RB's (mainly RB20's cause most drifters are broke scum) and refuse to accept that there is bigger and better things out there.
But you aren't that silly, you just posted all that stuff to give us a laugh, well done chap!
But one thing I will point out regarding a blatant error you made regarding the same power output...
The worst de tuned LS1 with pistons slapping harder than a black mans cock in reapers vagina put out 225kw.
What did the RB25 put out again?
09ONE
QUOTE (hella r32 @ Sep 29 2011, 07:35 PM) *
ok thanks mate, i definately wouldnt take the cheap option of making a slapper, anyone know what a rough figure would be to build a 25/30?
i have a motor out of my old vl calais factory turbo-the donor block which only has 46000ks on it.
i also have a haltech e6x and a garret gt3540, set of gtr injectors- are these up 2 the job?
The figure depends on your budget mate. What I spent on my entire engine someone was spending 1.5 times that on their head alone (was at the engineers picking mine up when I spyed the masterpiece lol) and I spent ~ $20K on my engine not including bolt-ons.
You won't be able to use a RB30ET bottom end with a twincam head as the RB30ET has combustion chambers of about 52cc where the 25head has about 78cc so your compression will be too low ~6.5:1. GTR injectors are too small and wont fit a RB25DET head anyway, the GT35R will be alright but you would want the 1.06A/R rear housing if your going to be driving it hard because anything smaller will cause too much restriction and a bottleneck resulting in very high turbine temps and ultimately cooking the bearing cartridge.
T4 flange turbo with correct sized rear housing it best option.
QUOTE (09ONE @ Sep 30 2011, 06:07 AM) *
Correct me if I am wrong, isn't the way around the silly low c/r with the RB30ET to use the series 2 RB30E bottom end?
QUOTE (Slideways_master @ Sep 29 2011, 06:20 AM) *
work on them mate and they burn oil like shit, and yes as i said my missus has 04 hsv and unless they are fully build with forgies and oil cooler etc they are shit! ford ftw. and until holden even have the remote racing heritage that ford due they can fuck off on quality.
Disregarding the fact you know absolutely nothing about LS engines, the second part of your quote amuses me the most.
QUOTE (HSV @ Sep 30 2011, 07:56 AM) *
+1
for someone who works on them he knows fuck all, so to the OP; be wary of his advice on any other engine
gutless
QUOTE (TwinCam16 @ Sep 30 2011, 07:51 AM) *
AFAIK cant use ET spec pistons in any of the blocks as c/r will be too low. Also you can use a series 1 RB30E block, just needs oil and water galleries drilled for the turbo as series 2 already has the galleries.
QUOTE (gutless @ Sep 30 2011, 08:06 AM) *
ORLY?
He already mentioned that!
Not the question I was asking.
Slideways_master
QUOTE (wbtonner @ Sep 29 2011, 11:00 PM) *
No i'm not....
I'm a smug little asshole.
lol
Slideways_master
yeah ok i know nothing about them yet i work on them in a work shop with a qualification. fuck off get back to the subject\
Rancher
You heard it her first folks. RB's are better then LS's. I guess we've all be wrong this whole time, and people who put them in their cars are stupid. It must be true, sideways master said so. That reminds me. How much torque and hp can you get out of a built RB20/25 with a stock bottom end? How much do those motors weigh again?
gutless
QUOTE (TwinCam16 @ Sep 30 2011, 08:13 AM) *
ORLY?
Apologies good sir, i was/is/am confuse about the question. sleep.gif
Carry on.
QUOTE (Slideways_master @ Sep 30 2011, 08:49 AM) *
Diploma in clerical administration doesn't help your case.
gutless
QUOTE (Rancher @ Sep 30 2011, 08:53 AM) *
If you have any "qualifications" it's running your mouth off at the wrong person, not mechanical.
So help me god if you are employed in the mechanical trades industry with your "knowledge".
Goddamned lowbreeds............
09ONE
Both series 1&2 RB30E's have the same CR, the only difference is the water and oil fittings already on the block with the series 2 RB30E's which are esentially the same block as RB30ET's but have different internals. So either N/A RB30 engine is suitable for RB25/30 on stock internals.
someblackguy
this made sense
QUOTE (09ONE @ Sep 30 2011, 01:12 PM) *
Fair enough, the point i was making was, using the Series 2 NA bottom end gave you the higher static C/R as well as the oil fittings.
Where as the Turbo, like you said, made the C/R way to low.
Slideways_master
QUOTE (gutless @ Sep 28 2011, 10:28 PM) *
Well if you want good Torque and Power made down low and want to stick to a budget, i would go with a 25/30(as a 26 head is considerably more expensive). Put Aside another 4k on top. prepare to spend around 5.5k on getting the bottom end properly prepped and built with forged internals(this figure is a quote for bottom end ready to bolt a head straight on from last year). Get the head checked,decked,prepped and VCT Welded up and rerouted(would recommend retaining VCT). Get a good quality Turbo,Exhaust Manifold,Plenum,Injector Set,Fuel pump,ECU and get a decent tune. All in All get ready to spend more than this in the end(considering that there may be a cheaper price for building the bottom end) but none the less when you build a Hybrid 30 you should always go 1 of 2 ways:"Completely dodgy" or "Do it right, do it once!". Picking option 3 where you cheap out in certain areas will just leave you with empty pockets and a fucked engine in most cases.
For a completely dodgy build buy a standard running RB30 and a Full non-running RB25DET long motor. swap all the externals parts over like water pump,oil pump etc. move the tensioner for the timing belt(of which you need a new one with more teeth because of the twincam head),grind off the top bits on the side of the block that would obstruct a twincam head and weld up VCT in the head(may have missed a few little mods to do in this process but you get the jist). whack on the head and hey presto you have a 25/30 with conrods that are rated to an average of 300RWKW.
so then you can have some fun until it blows up or you crash smile.gif (would like to try this some day just to see what i could get out of the engine before it blew up)
These are my opinions and my current knowledge, if i am wrong about something i am more than happy to retract said information.
hope this helps.
Post proof or STFU. IIRC LS1 weighs less than an RB25DET.
I Love RB Engines but i am not closed minded and thick. Don't go rubbishing engines just because you can(My personal quibble with LS engines is i much rather a more oldschool sound to a V8 of which in my opinion an LS is lacking as opposed to say even the note of a 304 but i don't go saying they are shit terrible engines because its quite apparent they are not).
My biggest issue with the LS engines that come into the shop are fucked out valves and springs and retainers, burnt oil, fucked rear main seals fucked cams and cam bearing fucked bottom end bearings and mains primarily all from the engine burning the oil black so quick. AND when the missus bought the HSV NEW
it went back to the dealership Several times in the first week, blowen valley gasket warped heads leaking aircon broken valves, mind you the car was NEW UNMODIFIED. So my comment is nothing to do with being thick my personal experiences have showen me that they are shit and several HSV enthusiasts that i know have hated the LS series of engines aswell also having problems with them and the higher maintenance over the 304 and 308, personally i agree with you with all comments in regards to engineering ie displacement and weight but the engines just cant do what an rb can without some serious issues in my personal opinion. so in high sight i really dont appreciate people calling me thick just because they have a different view i merely said that the engines where shit based on my experience i would like this topic to get back on subject as it is about nissan not folden.
Slideways_master
QUOTE (HSV @ Sep 30 2011, 10:57 AM) *
mind the low breeds comment bogan
Slideways_master
QUOTE (gutless @ Sep 29 2011, 11:16 PM) *
depends but i'm over this folden shit get back on topic please people.
Rancher
QUOTE (Slideways_master @ Sep 30 2011, 07:49 PM) *
Then you got a lemon. I dare you to post that on LS1forums. Mates and I with LS1's have not had any of these drama's, and I no idea what the hell you're on about with the black burnt oil. None of ours do it. Neither do we have a problem with valves/springs/retainers. What happened to your HSV could and DOES happen to many cars. You're still thick, and short sighted. Saying they are shit, unreliable RB's are better then the LS1's is just stupid. I also disbelieve you about the "my mates have HSV's and hate the LS's" These motors are popular, and for great reason. They are reliable. They are strong. They are light. There's a reason people take out the shit house RB motors, Rotors, SRs, CAs, and replace with a LS. THEY ARE A BETTER MOTOR.
My LS1 is sitting at 232thou, not one major failure. Not be rebuilt, nothing.
Gutless, how many KM's before your 25 shit itself? I know my 20 died at 140thou..
You're not going to get any more help. Not with the attitude you've shown thus far. You're just a clown, and honestly. I'm surprised HSV hasn't moved this to OT, and suspended your ass for insulting a mod.
jimmyprodrift
rb26 cams will fit in a rb20/25 head they just have to be re-ground , i have 2 mates who run them both on 25/30's and they both make over 700hp , i have a set i can sell u pm me for more info
i also have a 26/30 450hp on standard bottomend, good luck with the build
gutless
QUOTE (Rancher @ Sep 30 2011, 08:13 PM) *
186thou. Someone gave it a beating and then i bought it lol. Of course they can last ages if you drive them granny styles but who is going to do that? lol. My quibble with RB owners is the need to bash/hit/touch/go near limiter... its just not needed nor good for the engine. This is why 26s blow up cause idiots thinks that a rev limit means you should live there... Epic reason why building a 30DET is good as it makes its Power and Torque much lower in the rev range giving less stress to the engine as there is no need to rev it off its fuckin tits!
I love and am fascinated with Nissan Turbo Straight 6 engines. If it was just straight 6s i loved then bam! i would be down on JZ like that, but as much as i know a JZ is better i have no want for one at present. I wish to build an RB that lasts with all the little problems eliminated, IE:Overoiling and such dramas. Har Har Har at oldmate thinking RBs are more Reliable than an LS laugh.gif get real buddy and when you say an RB can make the same HP as an LS, Hows the Torque figures looking? smile.gif
NTG78
QUOTE (Slideways_master @ Sep 30 2011, 07:50 PM) *
your barking up the wrong tree there mate so if I was you i'd back-pedal and fast before you get the Hammer thumbsup.gif
and as previous posts state, the LS1's that I have seen don't burn oil nor is it Black as Dirt (you do know dirt isn't black right) so keep your useless thoughts from escaping that big mouth you have as your mouth seems to be in gear while the brain is stuck in neutral.
gutless
QUOTE (jimmyprodrift @ Sep 30 2011, 08:22 PM) *
Rancher
other prob ive notice is that the intercooler is same side feed and delivery, p.s. I'm a bit of a mechanic i usually build rb25's, 26's and 30det's, how ever i have never done a 20 and dont know much about them and would porting the head help? Aswell as a tuned lenght manifold. The ecu is a hks rb20 item too, what would a good but safe power output level be for the gts4 manual box??
i said if us fucking re read i'm a bit of a mechanic, i never said i am a mechanic, so call me what yous want im not the ignorant @#$! that cant read. Another thing just because an engine is of the same family never judge its character to be the same, like how the rb25 vs the 20 is less reliable etc hence the reason i asked whats the point in assuming and possibly fucking shit up and yes an rb30det otherwise knowen as a 26/30 or 25/30. So how do i go about making an rb24
So. In two threads. You've contradicted yourself pretty well. If you build 25's, 26's, and 30's. Why do you feel the need to come on to here to ask how to build one. Surely you should already know how to do this.
Second. How is it, you've gone from a "but of a mechanic, not a real mechanic" to a qualified LS1 mechanic.
Third. If you're poor enough that your mum and GF have to buy you an RB30 block. How does your GF own a new HSV?
You're a liar mate, and I'm calling you out. You're a nobody. You're not a mechanic, never mind one that works on LS's (I didn't realise that there was a specific job that JUST works on LS's) You own an RB20 powered vehicle. You think RB's are better then LS1's. Your "GF" doesn't own a HSV.
BAM.
NTG78
and that would be Snap bitch you got caught out talking from your arse ... Love your work Rancher ... I own a RB20 but I have driven a VY man ss and I loved the power, it may not have a boost power hit but fuck it moved for a fairly stock one
Slideways_master
QUOTE (Rancher @ Sep 30 2011, 09:15 PM) *
BAM.
Rancher maybe you should up load the rest of the thread dickhead and show people what was really said, second the rb30 was a birthday present as i said before you dumb @#$! and third @#$! i got photos of the car i can upload for proof so fuck off dick cause your trouble but your wrong what if i uploaded my old thread and showed the people what kinda dumb arse you are for showing only half the info cause you a stupid @#$! now fuck off and go back to kindergarden wanker.
Slideways_master
and second if your a jdm hater why the fuck are you in my thread fuck off again im over you and your shit dont like me piss off dont talk to me. fuck it i'll just get a moderator.
Rancher
QUOTE (Slideways_master @ Oct 1 2011, 07:27 AM) *
I dont need to bring up that thread. I've summed up you intelligence in my post up there. The only person swearing, and generally acting like an idiot in the other thread was you. Sure, you can "load up the old thread" But I never posted in there. Other people did, and they ALSO showed how little you know in regards to mechanics.
The only person acting like a liar here is you. You're still wrong. You still have no idea, and you haven't added anything to what I said, except a few swear words, and some strong threats I'm sure you cant follow up on.
QUOTE (Slideways_master @ Oct 1 2011, 07:28 AM) *
Oh. You own this thread do you? Bloke, you have no idea. I've built more motors then you, and I certainly dont need to ask how something is done. LOL at you biting at my JDM hater, that is aimed at people like you buddy. Not the cars. Its also had another person bite. Thanks.
PM HSV. He'd be happy to help.
002plz
Post #68
"reaches for the popcorn"
Mini71
Post #69
QUOTE (Rancher @ Oct 1 2011, 07:43 AM) *
Lol at this dumb OP. Pm HSV he loves pms on a sat morning also my 20 died at 108tho if i could afford it (give me a payrise @#$!) i would have a LS series motor in my skyline.
NTG78
Post #70
QUOTE (Mini71 @ Oct 1 2011, 08:47 AM) *
lol HSV would also love some bacon and eggs with his pm from OP amiright ? and my 20 didn't die as such just had a water leak at 170k and was still going strong before that so hoping now the leak is sorted it goes til 200k then it'll be amongst the leet 20's but I agree on the LS swap would be an awesome power gain over the RB's
Page 2 of 3
