16th August 2011 - 05:33 AM
anyone have any opinions on which is better out of 3sge or 4age? advantages? disadvantages? cheers. This post has been edited by ty.: Aug 27 2011, 06:23 PM -------------------- Cars
82 RA60 Toyota Celica 93 A101 Daihatsu Applause |
blacky83
3SGTE is probably your best bet. Neither of those engines will work well for drifting NA, and if you're gonna be going forced induction then its better to start with something turbo from factory. Gen 3 engine would be the pick, can be had reasonably cheap and is the strongest design once you start boosting it. |
ty.
3SGTE is probably your best bet. Neither of those engines will work well for drifting NA, and if you're gonna be going forced induction then its better to start with something turbo from factory. Gen 3 engine would be the pick, can be had reasonably cheap and is the strongest design once you start boosting it. cheers man, should help alot. also do you know if you can buy them brand new still or not? |
yda55
I had a 4age absolutely loved it. |
dazzazoo
3SGTE is probably your best bet. Neither of those engines will work well for drifting NA, and if you're gonna be going forced induction then its better to start with something turbo from factory. Gen 3 engine would be the pick, can be had reasonably cheap and is the strongest design once you start boosting it. what? D1JP chamion 2005 using a 180hp ae86 beating 500hp silvias and skylines .... skill>power |
Fappy
Beams engines are awesome, you'd be silly if you were going to choose a 4age over one of them. A Beams will out rev, out power and has everything over a 4age. You really need to be in a Beams Powered car to understand This! there used to be a fella where i live that had a 3sge beams ae86 and it went like a bat out of hell. Had such an awesome exhaust note too. |
blacky83
Didn't mean to say you can't use an NA motor for drifting, but you'd need to work it a bit in a reasonably light car. Any of the drift events I've been to have been solely turbo cars. |
jish
Didn't mean to say you can't use an NA motor for drifting, but you'd need to work it a bit in a reasonably light car. Any of the drift events I've been to have been solely turbo cars. 3S into a celica is gonna require a lot of custom work. Mounts, new fuel system, wiring, brake upgrade, etc. Definitely not the thing you can do on the cheap. That's because comps are comps. There are loads of NA car that slide and very well I might add. |
a well sorted 3sgte will be good in an ra60 but i would go a 1j over it every day of the week start off with something that was meant to be rwd and it will work out much cheaper. |
