Slide_thats5
Post #217
we where all young once, ot bought a new after market set of gauges, even mounting the eboost the cluster now |
B Unit
Post #226
looked at the fresh paint on the ke =) received lowering blocks in the mail for the datto drove the daily to uni and back Xc wasnt touched =( I saw a mint XB 4 door, red with black bonnet around the Holland Park area on Sunday. I miss seeing those sorts of cars on the road. OT drove my van to work, to the gym, back home. |
drunkn snail
Post #227
QUOTE What did you do on your car today put it in [L] and unleashed the lost 50kw from the shitty auto trans lol |
High Boost Hero
Post #229
Spent 4hrs detailing the exterior. Typically I need to spend another 1/2 hr doing odd bits here n there. Engine bay polish and interior are next on the hit list. ![]() I can see where you missed buddy, because everyone forgets this place! Also tradies in the backround, is miss bec lurking? My day I got creative, I blew off my blocker plate and couldnt get another. So off to bunnings to buy 4 pack only needed 1x 35mm door stopper ![]() And le hose clamp = blocked off! |
High Boost Hero
Post #235
I'm thinking the lower lip? RHS as we look at it? I think I see wax but not polished off. OT: Drove it to a house and drove it home! yeh front lower lip, and along the creases |
DAL32
Post #236
Attempted to make my headunit work again (after I pulled the switched live out because it was attached to a connector that I needed but disconnected and forgot about). Didn't work. Hmmmmmm fail. |
Rileys
Post #240
Attempted to make my headunit work again (after I pulled the switched live out because it was attached to a connector that I needed but disconnected and forgot about). Didn't work. Hmmmmmm fail. That'll be tomorrow's project now, I want music to drive with on the weekend lol. Hopefully complete sub installation tomorrow also. if you for some reason cant use the accessories wire you can always put it to constant power so you can switch the unit off and on as needed to get you by for the weekend last night i did a few things to the work car - led dome lights in the cabin and canopy - leds in the door lights - scotch guarded the interior going to buy some rubber matting, seat covers and few other bits and pieces today |
DAL32
Post #241
if you for some reason cant use the accessories wire you can always put it to constant power so you can switch the unit off and on as needed to get you by for the weekend last night i did a few things to the work car - led dome lights in the cabin and canopy - leds in the door lights - scotch guarded the interior going to buy some rubber matting, seat covers and few other bits and pieces today I really want to avoid that because I used to have to do that with my 156. Pain in the ass turning the stereo on and off manually every time. Especially with an aftermarket one because of course they combine the power button and the band button so you need to hold it for ever for it to turn on and off. There is no accessories wire in the Alfas either, as the position on the ignition doesn't exist. |
02GZM
Post #242
I really want to avoid that because I used to have to do that with my 156. Pain in the ass turning the stereo on and off manually every time. Especially with an aftermarket one because of course they combine the power button and the band button so you need to hold it for ever for it to turn on and off. There is no accessories wire in the Alfas either, as the position on the ignition doesn't exist. Does it have a cigarette lighter? How about splicing a relay into its power wire to trigger the radio's power? |
DAL32
Post #243
Oh I have the wire, it's just that there's clearly something else that's come apart while I was stuffing around back there.. so I'm going to have a look at the whole lot. The cigarette lighter is switched live anyway. Well, actually it depends on the year model of my car. The older ones have constant cig lighter power. |
Akshunhiro
Post #245
Changed the battery after finding it had a lead acid in the boot. Put my Optima D34 in. Was also surprised there wasn't a fuse at the battery... |
