23rd February 2011 - 04:28 AM
I tried searching because I 've read it on here before but i can't be using the right search words??? Can someone please give me the power-to-weight formula for engine conversions. And an example if that's not too much to ask Thanks |
http://www.infrastructure.gov.au/roads/veh...1jan2011_v3.pdf |
skyline r31025
i just thought if you had a mod plate you could put any engine in??...... well thats something new i learnt |
i just thought if you had a mod plate you could put any engine in??...... well thats something new i learnt Definitely has never been the case. Most common example is a 13B turbo into a R100 etc. Closest to the limit I have ever seen is the 800Kg 1974 LB Lancer with a 4G63B turbo engine... |
NURVUS
The national code is not used in QLD. |
ratta tat tat
The national code is not used in QLD. Page 31 - http://www.tmr.qld.gov.au/~/media/b3ea8c53...sreductions.pdf What are you saying? That these rules don't apply? I had been hoping to put a 2.7L hilux motor into a 750kg sedan. Is there ways around it? How do hot rodders get their cars mod plated for big V8's? |
NURVUS
Page 31 of that link is the QLD law. iamhappy46 has posted the national laws that QLD don't currently use. |
Hot Rodders 'used' to get away with it by classing the vehicle as an Individually Constructed Vehicle(ICV) but the loop hole has since closed |
NCOP is -apparently- coming out in June/July - then again they've been saying that for years though. |
ratta tat tat
*Edit TARE is 800kg on rego cert. So if using schedule B 'safety upgrade' it's a maximum 2.4L NA or 2.0L turbo |
The vehicle weight is not what it weighs on a set of scales with a full tank of fuel... it is the weight listed on the bottom of your RTA paperwork. ie my N14 Pulsar is 1100Kg which makes the VQ35 conversion legal |
ratta tat tat
from the actual information from the manufacturer, not a random google search Are you stating that official manufacturer weights cannot be found with google? I beg to differ. As kindly pointed out by iamhappy46, the weight to go by is on my rego cert, Thanks |
