7th June 2010 - 11:42 PM
Post |
Hi guys, I have recently bought a 5-stud conversion (5 x 114.3) for my 180sx project car. With this conversion kit I have received R34 turbo front brakes, and R33 rear brakes. In order to put this kit onto my car I need to get some wheels that will suit the brakes. I have been looking at getting 17 x 8s, however I am unsure of the offset I will require so that the rim does not hit the brake calipers . Can anyone tell me what offset I will require to fit 17 x 8s to this conversion? Cheers |
pipster11
you will have to modify the mounting brackets to take the r34 brakes as they use a 14mm bolt thread as opposed to nearly every other nissan that uses 12mm |
35NIK
17" is the smallest you can go on the front, if you want to run R34 breaks, It's more the spoke shape to the offset on what will fit. |
s1y180
Thanks very much for the replies guys. |
35NIK
If a full R33 break set up is used, trial fit aset of R34 GTT wheels before you buy, They may not fit. |
s1y180
so i guess your gonna modify your mounting holes for the brakes then your stock brake bolts will have a 12mm shaft which is the same as r33 brakes the r34 ones you have are 14mm so you will either have to drill them out or use a full r33 front brake setup Thanks for the offer mate, but I'll give the R34 brakes a go. If I have any hassles and don't want the front brakes, I shall PM you. Cheers |
s1y180
If a full R33 break set up is used, trial fit aset of R34 GTT wheels before you buy, They may not fit. I gave a friend aset of R34 wheels for his 180sx with the break converstion, He went to all the effort of fixing the gutter rash and re painted them. He went to bolt them up and they did not clear the caliper, Even though they are a stock nissan wheel, He had to use spacers. I was happy, I got my wheels back fixed up & painted for free. lol Haha thats bad luck for him. Thanks for that advice, I shall definitely trial fit some different wheels before I buy. The last thing I want to do is put spacers on due to the wheels not clearing the caliper and get defected. Cheers |
