11th December 2004 - 07:18 PM
Post |
Hey guyz i want to get a 4 channel amp - 2 channels run front splits and the other 2 bridged to run a sub. here are the ones that i have found in the right rms for $$$ JL Audio 300/4 $584 - this one really seems like a bargain but im unsure wut JL are like as amp makers. stats: 75 W RMS x 4 @ 1.5 ohm-4 ohm - bridged 2x150 @ 4ohm with front and rear crossover Eclipse 36401 $699 Precision DCX 300.4 (4x50W) $530 Alpine MRV-F450 $661 Also Alpine Type S sub is dual voicecoil? 4ohm + 4ohm? if i bridge this across 2 channels on one of these amps will it be all good? (ive never dealt with dual voicecoil b4) - however atm i just have a single voicecoil 4ohm pioneer. thx guyz all opinions welcome -except for the "just go to northfield" cause i have been there and im just looking at a cheaper place to do it. cheers. james -------------------- camcrew.com - new evolution of toyota forum <- toyota enthusiasts join now.
4X4 Monkey
JL are a very good brand from wat i have read and seen |
TUN35
well if your looking to go cheaper go for the JL. But if you want the quality you won't go past the eclipse |
forbidden
That Eclipse amp is old school, it is a great amp but it is also a 2001 model. That price is way to high for an amp that old. Any 4 channel amp is going to work for you provided this fact. 99% of them are only stable to 4 ohm mono. The choice of your sub is crucial here, it must be a single 4 ohm coil version or a dual 2 ohm version wired in series to a 4 ohm load. Then you are good to go. A better Eclipse amp is the PA5422 which is a current model, rated at 85w rms x 4 and sells for about $699.00 here in the Great White North. I think our dollar and your dollar are not too far off, have a look for this amp. |
maccab36
Eclipse Australia |
neil_se
I haven't owned any of them, but in the research i've done the Audison SRx3 keeps popping up, its specifically designed to run splits and a sub. |
MuTek
ok i love eclipse speakers but i dont know what you look at for amplifer quality - i was just using name + features + rms/channel. |
MuTek
ok seen |
