Post ![]() |
Im looking for some like this but for an rb20. Anyone know someone who has one? Are the rb20 and rb25 the same? http://cgi.ebay.com.au/NISSAN-RB25-INTAKE-...=item3a5865d241 Cheers Guys |
roy-ceffy89
Yeh i just what to get a cheap one which be good enough for me, Cheers guys. |
JET_RB25
just be aware roy that most of the china plenums out there tend to leak coolant Exactly why you do it once and properly. They cost around 900 which is not that bad as the greddy ones are around 700 if not more and on top of that the china ones as you state suck balls. And they are still 300ish. The plasma man ones promise 20bhp and retain the stock runners so you dont lose any low down torque. |
JET_RB25
THat is right. For the posibility of spending 300 and it leaking or not fitting i would save up and buy a good one. Like i said on the phone dude best to just leave it as my intercooler got the air temps on a drift day back to around 28 degrees so around 7 below ambient which is dam effective. |
JET_RB25
No you cant as the runners are designed to get even distribution from air flow coming in from the centre of the plenum. Nissa would not spend x amount of dollars on designing something when they could have just welded a TB on the front of it to be so much better. Its a cheap option and has and does end up with a blown motor from not enough air getting to number 6 piston. |
frcefed
well first of all you dont know me.... |
roy-ceffy89
LOl cheers guys, I srs didnt know thoses cheaps one would really be that bad. Ive used a lot of ebay stuff and never had any issues with them, i just google the brand name and make sure people have used them before to see the problems if any. |
JET_RB25
Some info i found |
roy-ceffy89
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT |
HASHIRIYA
No you cant as the runners are designed to get even distribution from air flow coming in from the centre of the plenum. Nissa would not spend x amount of dollars on designing something when they could have just welded a TB on the front of it to be so much better. Its a cheap option and has and does end up with a blown motor from not enough air getting to number 6 piston. depends what your doing, for forced induction its not really a concern, look at a 26 manifold, all the runners aren't the same length from the opening of the plenum chamber, cly 6 is the furthest from the opening. and it then goes on to how big the plenum volume is. NA motor would be a different story. and would cause an imbalance. |
roy-ceffy89
depends what your doing, for forced induction its not really a concern, look at a 26 manifold, all the runners aren't the same length from the opening of the plenum chamber, cly 6 is the furthest from the opening. and it then goes on to how big the plenum volume is. NA motor would be a different story. and would cause an imbalance. See i thought the same thing its a pressurised system. So the air is force in. I dont know, ive heard of people stuffing engines and good things about doing a cut and shut. |
paddles7
We've got an ebay greddy copy for an rb25det. Haven't run the engine yet, but everything seemed to bolt up fine during dummy fitment (we heard that was a problem with an older batch of copies). If you're looking at the greddy copy the throttle body opening is 80mm not the stocko 62mm or whatever it is so you need a bigger throttle body or an adaptor. I think it's worth it for the $$ saving over a genuine manifold, and I like the advantage of straight(er) runners over plenums that bolt to stock runners. |
frcefed
We've got an ebay greddy copy for an rb25det. Haven't run the engine yet, but everything seemed to bolt up fine during dummy fitment (we heard that was a problem with an older batch of copies). If you're looking at the greddy copy the throttle body opening is 80mm not the stocko 62mm or whatever it is so you need a bigger throttle body or an adaptor. I think it's worth it for the $$ saving over a genuine manifold, and I like the advantage of straight(er) runners over plenums that bolt to stock runners. I imagine the coolant leak would be between head and manifold? We got ours machined so I can't see it being a problem (I don't know why anyone would buy a cast manifold and not get the faces machined) Hope it works for ya , i know first hand of these manifolds as i built a engine for a guy who put one on , the problem wasnt the manifold faces the manifold was actually poures (spelling?) and coolant leaked straight through the metal. this was on a darwin car , screamr. then changed to a genuine greddy and no problem. we never ran the car with the copy so dont know if there is a power or drivability difference between the two. But hopefully we just got one of the shittie ones and yours is fine |
VLCT WALKY
bj's on the right track, |
VLCT WALKY
from the man i brought my plenium off |
