xwgtman1970
Post #77
There are some guys at Ebbw Vale near Ipswich that can do red walls or white walls for about $150 for 4 tyres. They are at X-Kote Paint Restorations. Shop 1/45 Brisbane road Ebbw Vale 3282 2118 |
cm_whitewalls
Post #81
Sorry mate. QLD orientated thread. $80 Dollar walls special in gold coast or other on request, colours consisting of red, pink and blue these colours are $80 limited time, call at any time check out my website at cmwhitewalltyres.webs.com for pictures also selling water based tyre shine and whitewall tyre cleaner thanks call 0401971932 |
FCCOOL
Post #85
proper whitewalls are not painted on, it is white rubber in the tyre, usually more expensive whitewalls have a wider whitewall, upto 3 or 4" wide, in the early 60's the narrower whitewalls became popular and later some of the sportier tyres had a red line, after this the trend was highlighted white writting, these tyres like whitewalls contain white rubber inside the sidewall and where used alot in the 80's whith the sidewall shaved as a wide radial alternative to whitewalls on older cars. many young guys on a tight budget painted whitewalls on cheaper blackwall tyres, this worked ok on older tyres but with the amount of flex you get in the sidewall of a radial it cracks and flakes off, what you need is a coating with elasticity and the sidewall will need a good scuff up and clean before you paint them, also new tyres or tyres that have had a lot of silicone tyre shine applied will be a problem, porta walls or flappers look good but they still also are not real white walls and if they dont fall apart after a few runs on the highway they will end up chewing into your sidewall, i am running a set of narrow whitewalls by khumo on 13" wheels wich cost around $100 per tyre but the sizes are limited in these cheaper whitewalls and once you go to 15"wide whites your starting to look at $300+ per tyre, i have a supercharged 6 and find these kuhmos bite in alot better than the same size firestone blackwalls i had before but i still prefer the look it had when i painted on wide whites but atleast apart from cleaning real whitewalls are maintanance free and wont scrape, flake or crack off. iv eseen the new low profile tyres with the sidewalls buffed and painted, they seem to hold up pretty well if you dont touch the gutters but last year i was pulled over and had a cop tell me my tyres were illegally cut into and painted, he said it was defective but i was able to show him how the white was raised from the rest of the sidewall, turned out that copper didnt know you could still buy whitewall tyres but i reckon even if they were buffed and painted what would be the difference between that and some sh!t driver who scrapes the sidewall all the time on the gutter or hits big potholes with large diameter rims and gets around with bubbles and fractures in the sidewall. |
street_cosmetics
Post #86
We do whitewalls in Brisbane And Sunshine Coast. Special Formula Paint created by us. We can do them on Tyres that have done just 1000km's and they last the length of the tyre if cared for properly! |
VCV666
Post #87
We do whitewalls in Brisbane And Sunshine Coast. Special Formula Paint created by us. We can do them on Tyres that have done just 1000km's and they last the length of the tyre if cared for properly! Our White paint doesn't go yellow Our red doesn't fade Every Colour Available, if we don't have it we will make it up. $150 a car. Mobile service 0411 378 478 Gday mate, Im just curious, do you make clients sign any sort of waiver prior to doing the work for them just to cover your ass? Obviously as per this thread, it can deem your tyres illegal. Cheers mate Dan |
