Drove Through Flood Waters And Now Car Wont Start?
Page 2 of 2
Eltnot
If the air filter is wet, chances are the water got inside the engine. And if that is the case, most likely the engine is stuffed.
Suggestions:
Get it briefly checked by a mechanic. It's probably screwed, but it's probably worth the money for a quick inspection to make sure it isn't something simple.
Buy a new car.
Don't drive through water higher then the bottom of your car's body unless you're driving a car with a snorkel.
SIK 31
QUOTE (iNfLuEnCe @ May 25 2009, 05:52 PM) *
i lol'ed...she has an excel and decided to go through flood waters wtf...ok how high did the water come up, it could be millions of different things hence why when a car is flood damaged it cannot be re registered because of all electrical components.....check the dizzy and plugs, also check no water got in through the intake...if water came as high as where the ecu is that might be fried, your best bet would be go to a mechanic cause no doubt something is beyond you flexibility to fix
This info is based on?????
geminiv6turboute
QUOTE (SIK 31 @ May 29 2009, 05:56 PM) *
in queensland it depends on your insurer as to wether your flood damaged car is a statwrite off or a repairable write off. general rule if the water has entered the headlights its usually a stat.
they can still be repairable write offs if water has entered the cab even if it has damaged the electrics as long as it is fresh water.salt water = stat no mater how minor.
i know this as i worked for manheim fowels auction house in the damaged car department,they auction all major insurance company damaged cars.
dan.eric1227174
QUOTE (WattsyLX @ May 27 2009, 12:01 PM) *
Yeah, you could try to say that the car was parked in the carpark and got flooded when the water came up i suppose. If you told them you drove through flood water they'll probably just laugh and tell you to go away.
I was listening to flood updates on ABC local radio on Sunday arvo and some lady got on whinging about how her car got flooded, and that the government should buy her a new one because she didnt have comprehensive insurance! Same goes with the derro's living in a caravan park in Lismore who didnt evacuate when told.... they want the government to pay for their vans to be fixed! Why does everybody expect the government to bail them out because of their own stupidity? rolleyes.gif
I drove through some high water and it is doing the same clicking. I called allstate and TOLD THEM I DROVE IT THROUGH WATER and they are going to cover. Your insurance should cover it under a natural disaster. It will still be a comprehensive claim, like an accident and therefore your deductible will be the same, but they are supposed to cover. Tell your mom don't pay attention to the jerk on here. I'm sure they've made their fair share of mistakes too.
1992 r32 gtst
this is a 7 year old thread dude. but good info all the same
kaylaknowles88135
QUOTE (chopper87 @ May 25 2009, 05:23 PM) *
Ok, so my mum was on her way home from work in her hyundai. atempted to drive through the underpass, Was to flooded the car stalled and she had to get towed home. No the car wont start, it just clicks like the battery is dead, But i know its not. What could the problem be. I dont know shit about cars but my mahs freakin out cause he neighbour told he it could be the engine.. Any help would be appreciated..
Hi my name is Kayla I drove through a puddle today and it stalled my car now its doing same as yours please tell me your car turned out ok I'm scared its done for cause all it does is click when I try to turn it over
Flash635
That sounds like a big puddle if it stalled your car.
2 things it could be: The engine sucked up water and the cylinders are full. Take the spark plugs out and spin the engine, by hand if you have to to expel the water from the cylinders. Your air cleaner will be no good now.
The other is that your starter and solenoid are full of water and won't operate. Remove and strip the starter and clean it out.
It could be a relay that trips the starter that's full of water too. That would be the best outcome.
Page 2 of 2
