lil_bobby_260
Has anyone fitted a hydraulic handbrake before? Does it plumb into you rear brake lines? that would allow you to have both. You would probably move the factory handbrake to the right hand side of your seat like the old holdens i guess, and mount the hydraulic one where it feels natural. |
lil_bobby_260
OK so i finally got the minispool in. |
51IPP
my first car was an r31, very easy and cheap to mod,mine had minispool, s13 coil overs, double sway bar,r32 lower control arms.and was very easy to slide. s13 stuff bolts straight in.s13 lower control arms will give you 2 or so more degrees camber. |
lil_bobby_260
Just got back from Streetwarz - i was the only skyline (only nissan, even) to get out on the burnout pad and have a go. Was good! I tried to mix it up a bit on not just do static burnouts - but was practising drifting in large circles, trying to use the whole pad. |
natedogg069
nice mate you did really well seen ya today |
lil_bobby_260
Thanks mate i appreciate the feedback! |
lil_bobby_260
I just had a look on youtube and there isnt any footage up of me. there is a guy who has put up heaps of streetwarz vids but there are none from yesterday yet. i know a couple of mates got some footage of my so i'll get it on youtube and post a link - providing its not too much of an embarrassment haha! |
88_VLW
hey, you've really helped me out a bit i recently just bought an 86 rb31 with the rb30 in in too, picked it up for 350 bucks only cause it had the 5 speed in it, but i was also going to set it up as a pure drift car seein tho i my own trailer and all, i was just wondering with the suspension as it is its fully independent but i wanna put coil-overs in it to make it really hard and no body roll and was wondering if you had looked into it to see wat wud fit without to much modification or none if possible, my only problem with the engine is that it has a slight knock in the bottom end i think i may be that 1 of the lifters has shit itself. my enterior is imaculate like it just come outa the shop, i've cut all the rust outa the roof and filled it in, i have painted the bonnet a satin black with some orange stencils that i made up so its called the DRIFT PIG lol original i know but it'll suit it as i am not painting the rest for a while and just spending my $$$ on suspension know i half know wat i need, and an engine conversion l8r on in the year with a rb25det turbo with a new turbo 5spd gear box from a japan import place in redcliffe. to fit front s13 coilovers you got to get S13 lower control arms, hubs and knuckles, brakes all this bolts strigh in make sure you get coilovers with height adjust as you will have to have it adjusted pretty much all the way up. the rear coilovers from a s13 only has 2 bolts so either you can re drill 2 new holes or you can take your r31 rear strut tops and with a small bit of work fit them on the coilovers! have a read of http://wiki.r31skylineclub.com/index.php?t...sion_Conversion it will tell you what you need and how to go about it ![]() Hey mate thats good to hear, got a good buy there i think. An R31 with a 5 speed is getting hard to find in decent condition. Suspension - you can convert the front to the S13 Silvia suspension setup, using S13 control arms etc, and even change the brakes if there is much to be gained there. This will allow you to run coilovers designed to suit a silvia. Make sure you get height adjustable ones, and you will find you'll have to set them fairly high. You can also run S13 coilovers in the rear but you will need to re-drill the rear upper mount to suit the silvias two-bolt setup instead of the 3 bolts that the R31 strut top has. You can also run an S13 steering rack to give you much better steering lock. Being an overhead cam engine, pretty sure it doesnt have lifters, so if you have a bottom end knock you might find that is is big end bearing related...? Im not an engine builder so im not 100% sure there. The RB25DET conversion with the tougher gearbox they come with (in your R33's) is a popular upgrade, and not hugely difficult i dont think, but im keeping mine as a 3.0L, keeping the RB30E and just playing with it to make it more effective. Im trying to keep my car still usable as a daily driver is the main difference, so id like it to have slighty softer suspension than a city train. man you have a really nice mint r31 there and as a frist drifter your going pretty good i would say have a look on www.r31skylineclub.com it has pretty much anything you wil need to know about r31s cheers jason |
mighty-toy-boy
I just had a look on youtube and there isnt any footage up of me. there is a guy who has put up heaps of streetwarz vids but there are none from yesterday yet. i know a couple of mates got some footage of my so i'll get it on youtube and post a link - providing its not too much of an embarrassment haha! Yeah id like to get out to archie on a wednesday - is it every wednesday now...? Til 9pm hey - issue is i dont leave work til 6pm, and im 45min north of brisbane, and the skyline is a trailer car! NEED MORE POWER might be turbo time, or RB25 or SOMETHING but definitely needs more push. wednesdays are every week, 4-8pm. 50$ entry for drivers pfft, trailer cars are for the weak, just drive it ![]() for power, strap an rb25 turbo to the rb30. run stock boost. get a std vl rb30e ecu, it will accept up to 14psi before boost cut so no need for aftermarket comp. a mate has this setup in his 32. comes on boost at 2000rpm and bakes nicely (: |
lil_bobby_260
Yeah might be time to start making a turbo-conversion checklist. |
lil_bobby_260
Like what...? |
lil_bobby_260
Extractors you can have for $80 if i go turbo haha... They are genie's im pretty sure. Lil surface rust but just rub them back, hit em with some rust converter which will just make them black, then wrap them in that fibreglass heat wrap you see on tough engines :-) thats my trick haha... works well and looks tough! |
pipster11
im gonna be home (gold coast) in 2 weeks |
lil_bobby_260
Ive run whiteline swaybars in the past, on my stagea, so will definitely be using them again, was very happy with it. |
pipster11
yer normally but in tas for uni |
lil_bobby_260
meh silhouette schmilhouette haha. I have no need for trip computer and power windows! weighs it down! haha... thinking about stripping the interior out... but i honestly dont think itd weight much in it... its a poverty pack car. |
mighty-toy-boy
interior stripping will kill resale if you intending on changing cars later. |
pipster11
meh silhouette schmilhouette haha. I have no need for trip computer and power windows! weighs it down! haha... thinking about stripping the interior out... but i honestly dont think itd weight much in it... its a poverty pack car. Yeah serIII FTW - trying to buy another one. So two places do it - and you chose TASMANIA?? nutter. i wish i had power windows and central locking!!! but the trip comp is pretty cool and almost seems pretty accurate (but the odo doesn't work lol so not actually sure if its working or not) it was auto and mongrel from the tech section used to own it and he converted it to manual a few years back but yeah tas is kinda gay but its the best place for it cos they have the best facilities in the southern hemisphere (i think) and i still get 3 months off at the end of the year ![]() |
ULOST
First time I've read this thread and can I just start by saying a HUUUUGE thankyou for the job you've done typing your posts! I know it sounds simple but I've just read through 3 pages of boost comments here in about 3 minutes - and I've understood every single word! |
lil_bobby_260
Thank you for the positive feedback! Im trying to make it fairly readible, looks like there are a few guys building 31's so hopefully im helping out. |
pipster11
33 box will be stronger straight up |
lil_bobby_260
you can get rebuilt R31 boxes on exchange for about $600, which is not an expensive way to end up with a new gearbox! |
FLMN HT
hey i just picked up another r31 as a spare parts car for my drifter last weekend, just pulled both the engines out today to swap em, if anyone wants any interior parts it's all stock all there, also the stock auto gear box, the car was owned by a chick in her late 20s, hit me up or pm me, i want the shell tho cause im chopping it into a ute later on |
lil_bobby_260
Pretty sure there is a for sale section for that eh. |
lil_bobby_260
Post #68
off topic - but sad nonetheless. |
