Probly A Stupid Question But I Have To No
KatieFTO
  • KatieFTO
Post #1 post 27th February 2009 - 05:34 AM
I have a mitsubishi fto and I no that it fits magna wheels becasue that's what it has on one tyre atm the rest are chromies but one got stolen,so if it fits magna rims what other ones could fit?
[email protected]
mosport
I guy bought some ford BA falcon wheels off me to put on a late model magna, at least thats what he said, so dont blame me if its wrong.
SAM
find your PCD, i think there is the list in the wheels and tyres section?
then you can have a look to see what type of wheels will suit.
https://www.boostcruising.com/forums/index....howtopic=331472
Remove the existing FTO rims, on the inside of the rim will be some numbers like 16x7 +35 or something similiar. You need rims that have similiar numbers.
57OMPA
if it's magna it will most likely have a Pcd of 5x114.3
So that means falcon nissan and mitsubishi
57OMPA
MITSUBISHI
COLT 4 X 114.3
CORDIA 4 X 114.3
EVO MK 1, 2 & 3 4 X 114.3
EVO MK4 ON 5 X 114.3
GALANT 4 X 114.3
GRANDIS 5 X 114.3
LANCER 1992 - ON 4 X 100
LANCER CG - CH VRX 5 X 114.3
MAGNA 1990 - ON 5 X 114.3
MAGNA PRE - 1990 4 X 114.3
MIRAGE 1996 - 2005 4 X 100
OUTLANDER 5 X 114.3
VERADA 5 X 114.3
3000GT, FTO & GTO 5 X 114.3
Tha is the pcd you are after i also did a search and it shows that you can run a rim with a offset of +35 to +40
hope that helps you
Jae
TuffVC
QUOTE(iamhappy46 @ Feb 28 2009, 10:29 AM) [snapback]1283655196[/snapback]
Then all you have to worry about is the centre bore (size of the hole on the centre of the rim)
This needs to be the same or you have to use rings (you can buy) to make sure its a snug fit onto the hub on the car...this is IMPORTANT
W1NT3R
