Perfect Sized Wheels
luxxy101
  • luxxy101
  • Budding User
Post #1 post 27th February 2009 - 12:37 AM
ok before u say use the search buttom u twat u did i have the proof (at end of post)
ive been looking for a DEEP DISH , LIGHT WEIGHT , PEDIGREE wheels for my 180sx
its going 2 be a big investment so i need them 2 be perfect,
i need maximum power(lack of weight) and handling as much as possible
im not going 2 be a knob and get 20s so they will be 'fully sick tuckin' n shit becuase thats just fail
my question is im intending 2 get a nice dish and still keep it light weight what is the PERFECT SIZE
i dont want 2 big and change rolling diameter and get arse raped by the popo and i dont want them ridiculously small
i hope ive made it simple and easy for u 2 answer me
just wondering can u possibly hit vtec in reverse??
bahahaha lol
Medic_01
deep dish and light weight ? i didn't think these two were in common
the smaller they are the lighter you are going to get them, but how small are you willing to go ? 16" -17 " ?
how much are you willing to spend ?
pedigree ? you mean you want a top brand name wheel ?
45SET
I think this is a good place to start.
Do you know what "offset" means?
MR 3KGT
17 inch with good offset simple as that
VRV6T5
Link didn't work...
blacky83
Smaller rim will weigh less, but then you need bigger tyres so add weight there. I wouldn't really know where the optimum point is though.
I might suggest go looking at what sorta tyres you can get for a certain rim size in the profile you'd need. Tyres are much more important than rims when it comes to performance, so no point having the best rims if you can't get tyres to match.
I'd say 16 or 17 inch would be the go.
Streeter
what are you going to do with the car? is it just for the street?
as ppl have said multipiece deep dish rims generally arent that light.
and as for tyres 17" would be the go, but they are also a compromise with the higher performance rubber costing alot more and wearing alot quicker.
so really need to find out what the main use of the car is.
random_ben7
17" TE37s
Get negative offset, works gaurds around wheels lol
antonio
How much money do you have? Do you want guard work? What do you want to use the car for?
I could give you a million recomendations but it really depends on what your going to use the car for, if you want virgin guards but phat wheels your going to need some camber work, but maybe you want to flare the guards so then you could go a different set.
fitment is everything.
Innocent_Commuter
anything in 19*10" or wider and no greater than a +5 offset should be perfect. Should be a big enough investment for ya..
random_ben7
Not 19".
57OMPA
17x9+17 offset smile.gif thats what i was runnin on my sil at qr last night, rears stick out a lil but hahaha
luxxy101
smallest would be 17, largest 18
im willing 2 spend about 5-6 grand
the car will be both for street and track , i wont be doing drastic mods like rollcages, interior stripping etc tho
atm i have about 5 grand i dont really want 2 do guard work as the paintwork is brand new i want 2 use the car for both street and track (not drifting)
also i have become quite fond of these i know a little bit of guard work is done and camber aswell but i could live without the flared guards
Innocent_Commuter
QUOTE(random_ben7 @ Feb 28 2009, 10:14 AM) [snapback]1283655150[/snapback]
Not 19".
tongue.gif Well thats the current trend in japan my friend.
antonio
QUOTE(luxxy101 @ Feb 28 2009, 04:27 PM) [snapback]1283656168[/snapback]
Those are bolt on guards, 25mm by Origin afaik in GTR Style.
imo, youve got a few diff types to choose from.
18x9.5 +5 is a great fit and a pretty popular size, then just look around and play around with the offset vs width, but since you have that much money to spend get a perfect rim to suit your application and you wont need cheapy spacers.
18x9.5 +9, Could do with a spacer in the rear and then heaps more lowering biggrin.gif
Also PM Streeter on this forum, he's in Japan and get the BEST deals when it comes to buying rims, Especially for the rare types biggrin.gif
luxxy101
the stance on the sil with the camber will be perfect for what im wanting except im not that sure about the wear on the inside of the tyres how many ks normal driving per set ?
cappakazi
You mentioned that you didnt want to attract the police, those rims would because they stick out past the guard.
Some people get away with it some dont.
luxxy101
i mean the rim size plus that is a good point they would pick on a bright green 180 with mass tyres
antonio
QUOTE(luxxy101 @ Feb 28 2009, 05:44 PM) [snapback]1283656456[/snapback]
you'd still get alot of use out of them depending on how you drive you would only loose a few thousand km off use, but then if you do a track day youd loose ALOT more use out of them anyway, as i said with a 10mm spacer you would be able to reduce the camber but then you would need to flare the guards to accomidate.
It really is a push and shove battle, Virgin Guards = mass camber, Flared Guards = Less Camber.
45SET
Question.
What kinda suspension do you currently have in your car? Because if you don't have adjustable (Height, camber etc) it'll make it a little harder to fit some of the rims (IE, low offset/wide rims that need a far bit of camber.
As for tyre wear. If you don't do burnouts/drifting, and get them rotated ever couple thousand K's and you'll be sweet.
luxxy101
Question.
Atm i only have jic coilovers
45SET
are they camber adjustable at the front and rear? Or would you have to get some adjustable rear camber arms.
Sorry, I don't really know much about suspension on the S13. But if you are looking into getting some rims like the above, you'll need a fair bit of adjustable so they fit perfect.
TRY TOO
On my 180 i have front 18x9 +35 (with a 20mm bolton spacer) and 235/40s
Rear is 18x10 +12 with a 235/40 and with about 3.5 degrees neg camber and a pretty big pole roll the fitment is pretty nice!!
But dish etc doesnt happen if you want them light...
17x9.5 + 10-20ish is pretty nice with a small roll.. xd9s p1s crkais (are getting very popular/cheaper) all relitively light, good quality wheels!..
All pending what look you want really!
And i know i need to bring the front down abit, just waiting on abit of time to pull wheels and roll gaurds some more!!
Timmyp34
IMO the Perfect wheel and tyre combo is different for every set up car and driver.
luxxy101
[/quote]
yes they are camber adjustable
btw this is my car
as its green i dont really know what colour i should go for chrome is a safe bet and they look awesome with some dish whats a safe offset , neg camber that wont pump out the tyres as much without flaring
ohh btw im getting new tailights
Streeter
yeah the SSR proffessors look nice, I prefer the meisters but they both look pretty similar. Both arent super light but arent too bad for a multipiece wheel. If its a street car you arent going to notice a huge difference to a set of te37s anyway so you should go with what you think looks good.
getting low tolerance fitment is trouble with the cops and usually needs a little guard work to get it nice and close with out fouling.
I would recommend 18 x 10 +20 rear and 17 x 9.5 +12 on the front. These sizes will fit with minimal guard work (should be able to use a guard roller with out having to redo the paint) If you run stretched tyres. fitting `recommended` tyre sizes to these rims will cause hassles with clearance.
If you dont have rear upper arms get some.
luxxy101
jesse do u have a site where i can look at some wheels/ tyres is there much of a dif that u can c with the different rim sizes compared for the rear 2 the front and how much neg camber would be reccomended for the front ?
i prefer the ssr professors with dish how much would 18 x 10 +20 rear and 17 x 9.5 +12 and stretched tyres cost all up?
Streeter
QUOTE(luxxy101 @ Feb 28 2009, 06:58 PM) [snapback]1283656791[/snapback]
I dont have a site for rims. I can supply what ever is in japan (which is a fairly large range)
there are a few forums with fitment threads that might be worth looking at?
eg this one...
http://www.nissansilvia.com.au/forums/inde...t=0&start=0
camber will depend on ride height, tyres used and how much clearance you have. probably about -2~3 degrees on the front and about -1.5~2.5 on the back. for a street car I would run as little camber as possible as tyres do wear uneven if you run too much camber. Its not a huge problem but if it can be easily avoided why not. On my s13 (which is a no compromise track car) I run about -4 degrees on the front and around -2 on the back. If you dont care about tyre wear there is advantages to running more camber.
main problem with parts from japan is shipping costs. So tyres would be best sourced locally.
Used rims help lower the cost alot but with multipiece rims there are so many different sizes available its very rare you get exactly what you want pop up for sale second hand.
rough costs for new 18 x 10 and 17 x 9.5 SSR proffessors landed in Aus on a rate of 62.3 yen would be ~$3750
FromDeeEast
QUOTE(antonio @ Feb 28 2009, 05:13 PM) [snapback]1283656583[/snapback]
that is the worst peice of advice i have ever heard.
How is making the wheels stick out more going to fix up the camber???
i'd suggest getting some like 17x10 +30, might run about 1 -2 degrees camber (which is perfectly fine and wont wear out ur tyres too much. To fix camber, u need rear camber and toe arms. Please dont listen to what some clueless people are saying..
QUOTE(antonio @ Feb 28 2009, 04:37 PM) [snapback]1283656431[/snapback]
i am willing to pay u to fit 18x9.5 +5 on a standard 180sx guard, with just a roll and no more then 3 degree camber.
Cant be done mate, pls dont give people misleading advice when there putting big money in..
Lazer_Spec
antonio
QUOTE(FromDeeEast @ Feb 28 2009, 11:51 PM) [snapback]1283657866[/snapback]
With a flare you wont need as much negative camber, without the worry of hitting the guard.
Also 18x9.5 +5 is an easy fit with a roll sometimes a very slight pull makes it a touch easier, then with the right tyre 215/40 its all good
18x9 +10 Virgin Guards, just a roll.
So dont say it 'cant be done' until you've done it, 17x10 +30 LOLOLOL seriously go buy a Lancer.
FromDeeEast
^lol... i cant believe ur serious, u posted a picture with about 4-5 degree of camber with 18 x 9 +10, u want him to go to 18x 9.5 +5.... thats a whole 11mm more out, i cant see how u would be able to fit a rim that stick 11mm out more, and dail out the camber to 1-2 without a flare.
he specifically said he doesnt want any flares since he just got a new paint job. If he just resprayed the car, if he does flare it, it will be very prone to cracking.
He also said that he doesnt want much camber.
On my s14 i test fitted 17x10 +15 and they JUST fit, with a few degrees of camber with just a roll. The s14 have the largest guards out of all the silvias, there about 10 to 15mm bigger then the 180sx, so if he wants to fit wide wheels with low offset WITHOUT CAMBER AND FLARE, 17x10 +30 would be perfect.
antonio
Im running 18x10 +12 on my S14 FromDeeEast, And i want to put a spacer to get it even lower, With a tyre change aswell to 225s.
Also that car only has -3 camber, not 4/5, If he doesnt want flares thats fine, But if hes got 4-5k to spend then he may aswell go all out pull the guards which is a less chance of crack(we flared my guards factory paint no cracks)
TRY TOO's fitment is perfect from what the picture shows theres a minute flare, a pulled guard would of worked just aswell.
Ive got some pics of S13/180s ive played with over time but cbf, seems like QLD has no idea when it comes to fitment.
FromDeeEast
keep in mind s14 guards r bigger then 180's, also the spacers r for u clear coilovers haha tongue.gif
GTRVspec95
Deep dish and light ...
Try Gram Lights
57S PRO
57 PRO
57F PRO
57 Maximum PRO
RAYS ENGINEERING -GRAM LIGHTS
