2jz Ge Missing Very Bad? - help help
rowansupra
  • rowansupra
Post #1 post 16th February 2009 - 11:16 PM
well i gave my engine a tidy the other day hit it with degreaser and and washed it down i covered tho pod filter thru out hole prosess used as lil water as possible
started car ran fine then let it idol for 10 min took it for drive and after about 5 min it started running very slow and missing rele bad i took it home
and blew hole enginebay out with air compressure hit ever lean or connection with contact cleaner and also air so they were all dry we checked all my leads spark plaugs distributer everything everything looks fine but it is still missing rele bad and running very rich on fuel what could it be and does any have the owners manual of specs for the 2jz ge
please help
sig image removed - exceeds forum size constraints
max size is 600x100
mongrel_cae71
the cam valley will have water in it, the water will be sitting around the plugs, arcing them out.
rowansupra
yeh thanks man i will have a go at that 2moro any more ideas guys for me to check this is seriously a pain in the arse and no one in mackay has the plug to do a dianostic sucks dick sad.gif
QUOTE(rowansupra @ Feb 17 2009, 07:41 PM) [snapback]1283596303[/snapback]
Read above - I can almost guarantee that's where your problem is.
rowansupra
okay fair enough thats first thing i will check when i get home from work the sarv i will let you's know how i go 2nite cheers
Mikey D
yeah def sounds like the plugs are arcing
rowansupra
yeh thanks heaps guys the cam valley was full off water cheers
