15th January 2009 - 02:38 PM
Post |
hi guys, need some help im putting a 25 head on my 30 bottom is it just a bolt on what do i have to do to make it work? -------------------- how do u know a mechanic has just had sex??
1 of his fingers are clean |
180josh
What car is it going into? |
mongrel_cae71
^^that's a very good list. |
pipster11
need to get a specific length belt too as the 25 wont reache with the added block height and a 30 one its only single cam |
09ONE
Decide on what oil pump you will be using before going much further. |
180josh
QUOTE(09ONE @ Jan 15 2009, 09:56 PM) [snapback]1283430306[/snapback] Decide on what oil pump you will be using before going much further. You will need to use oil restrictors in the head and possibly external oil drain back to the sump depending on what pump/how much flow / max RPM. Make sure you also get an aftermarket harmonic balancer. An RB30 one wasn't designed to cope with the higher revs and an RB25 one wasn't designed to be used on an engine with the stroke of an RB30. ATI make a really good one, or Ross also dop a quality one for a good price. You don't have to run the VCT either, it's no real drama to leave it or have it functional as an RB25 would. I would recommend using the stock RB25 oil restrictors (part number is 11036 21U00) Also, I am not too sure on the balancer. . Yes the RB30 block is said to have harmonic issues over and arount 7000, however, many people have run 7000-7500 all day long with a non balanced bottom end, stock balancer, and it is fine. . Personally, I am using the RB25 balancer with a non balanced bottom end. . However this is only a mild build and in about a years time I am hoping to get the whole bottom end balanced with an aftermarket balancer. . Then you can say hello to the 8k range |
09ONE
QUOTE(180josh @ Jan 16 2009, 12:24 PM) [snapback]1283432387[/snapback] I would recommend using the stock RB25 oil restrictors (part number is 11036 21U00) Also, I am not too sure on the balancer. . Yes the RB30 block is said to have harmonic issues over and arount 7000, however, many people have run 7000-7500 all day long with a non balanced bottom end, stock balancer, and it is fine. . Personally, I am using the RB25 balancer with a non balanced bottom end[i]. . However this is only a mild build and in about a years time I am hoping to get the whole bottom end balanced with an aftermarket balancer. . Then you can say hello to the 8k range Seriously why? It's not like balancing costs all that much espically if you just get the whole rotating assembly balanced rather then each individual part. It should be part of your machine work. For the sake of $500-$600 the piece of mind is worth it. Then eventually when the engine does break you can take comfort in the fact that you did everything you could (although this kind of attitude is how my build got out of control...Engine still isn't in the car) Why excatly do you want to do a mild build, only to do a full build later on? You end up doubling up on labour and machine costs and also parts costs like bearings, gaskets studs etc. |
180josh
Well as it is I am only 18 and still on my p plates. . I have a 210RWKW RB30 in the shed with a fully forged and balanced bottom end. . |
