Type R Vs Type S - who wins????
masofasn8r
  • masofasn8r
  • Regular User
Post #1 post 23rd November 2008 - 03:56 AM
Doing some research lookin at a next car..
i've been on ozhonda and from what i could find the type S sits at like 154kw or so and the type R is 145kw.
Was wondering what people think would like to hear from owners of the vehicles which is better.
which generation..?
the DC2 Type R is the more focused the DC5 type S is easier to live with
51MPL
dont think dc2 come in type s only dc5. i do believe however that both being stock type s will juuuust win? (even though type r is like the sporty based car)
edit -
type r and type s ; do they both have same k20?
Street Tuned
while im not a honda expert from a not too distant journal article i remember the Type S DC5 being faster than the Type R DC2
and when you add how good a DC5 looks i think it is a pretty open and shut case
masofasn8r
both dc5 series and the Type r from what i know has K20A2 or something and the type S is k20 ( something with a z)
51EKA
The type s is supposed to respond better to mods, therefore make more power. However it's more of a luxury car and it is abit heavier and less focus compared to the type r. The DC5S would be a pefect daily driver, power wise (with minimal mods) and luxury if you don't plan to track your car.
The DC5R is more of a track car, not as much as a dc2r is, but it is still harsh for daily driving. I know of friends that sold the dc5r because it was not a comfortable daily driver.
masofasn8r
not necessarily track it but i'd like to have a quick n/a but with decent driveability
45SET
Type R
K20a2 - 147kw
6 speed manual
1160kg
LSD
Recaro's
2001-2004
Type S
K20z2 - 156kw (Same exhaust cam as JDM K20)
6 speed manual
1230kg
no-LSD
Leather trim
Has revised suspension making it slightly stiffer then the pre-face life DC5
2005-2006
Basically, if you start modifying the engine or suspension, throw all the reviews out the window because they'll basically be on par with each other and it'll come down to which one you prefer the look off... or if you want a slightly newer car (type S)
One thing to look out for with the Type R is the notchy 1st-to-2nd gear at high revs... you'd think Honda would fix this with a revised model, but the notchy gear just moves to 2nd-3rd.
masofasn8r
DC5 Integra Type R
Release: 2001-2004
Engine: K20A2 2.0L DOHC i-VTEC, 147kW@7400RPM, 192Nm@6000RPM
Specific: CR 11:1, Redline@7900RPM, Cutout@8200RPM
Drivetrain: 6 Speed close ratio, 4.764 FD, Helical LSD (same as JDM)
Weight: 1160Kg (without Air Conditioning - Optional)
Brakes(F/R): Ventilated discs 300mm, sold discs 260mm rear, large single piston calipers/Discs, ABS
Suspension(F/R): Macpherson Strut/Double Wishbone.
Handling: Rear sway bar (19 mm), front sway bar (23 mm), front upper strut brace
Standard features: 2 Airbags, power windows/steering/mirrors, Recaro buckets seats, Momo leather steering wheel, aluminium shifter
Additional: Bridegstone RE030 205/55/16, Enkei alloy wheels (16x6.5), JDM bodykit/chassis
DC5 Integra Type S
Release: 2005-2006
Engine: K20Z1 2.0L DOHC i-VTEC, 154kW@7800RPM, 194Nm@7000RPM
Specific: CR 11:1, redline@8100, Cutout@8600RPM
Weight: 1230kg (including Air Conditioning - Std)
Handling: Rear sway bar (xx mm), front sway bar (xx mm), front upper strut brace
Standard features: 4 Airbags, power windows/steering/mirrors, leather seats, sunroof, 6 stack mp3 cd player
Additional: Bridgestone RE050 215/45/17, Enkei alloy wheels (17x7), same kit as JDM DC5S, also same as JDM DC5R minus rear wing. DC5S has upgrades to suspension geometry, stiffer sway bars both front and rear, thicker rear cross member, rear strut brackets have 3 extra connecting points on each side, revised front strut/chassic brace is bigger and stuffer, cams similar to JDM DC5R, stronger crank, revised spring and damper rates, additional engine bay reinforcing, quicker ratio for steering, larger brake master cylinder, larger diameter exhaust, lower NVH due to more sound deadening.
(*thanks to ozhonda.com*)
45SET - overal how do you like your type R what are some ups and downs to it?
45SET
ups:
Looks sporty out of the factory
Interior is perfect... I have changed the headunit and haven't touched anything else.
Basic mods does a world of difference (Coilovers, swaybars, intake, exhaust)
Responds to mods very well.
Puts a smile on my face every time I drive it
downs:
As my car currently stands I'm not sure I would like to use it as a daily... as it can be quiet... harsh (suspension, clutch)
I want to keep spending money on it every 6 months
But when it was stock it was a very nice car as a daily... had power, and was interesting to drive.
masofasn8r
im assuming with the Type R having the LSD it would make it the quicker option (from factory) as it would be more able in putting the power to the tarmac???
45SET
To tell you the truth... in stock form you really aren't going to know the difference on the street... and you probably won't on the track either. Its not until you add intake, exhaust and ECU that you would really need the LSD. But if you set up the suspension correctly (Coilovers, swaybars, tyres/rims etc) the cars corner VERY well.
masofasn8r
to be completely honest the aim for the S/R would be be low on nice wheels and enough balls to say run a high 12...
not too phased with cornering or going around a track... although decent handling would be good but not looking for something spectacular
like that...
45SET
high 12s... hmm... you'll need
intake
larger throttle body
intake manifold
cams (And parts to go with the cams)
full exhaust system
ECU (Hondata)
so that's around... oh... 7-8k... its not cheap
But as i said before, it'll be up to you one which one you prefer the look of.
You attachment doesn't work.
masofasn8r
sorry bout the attachment... not the best with computers but whats the big diff in looks?
im not too keen on the spoiler so i'd keep it withot spoiler and i'd get some offset wheels
keeping it Jap styled... more of a race theme more then a show pony
45SET
DC5 pre-facelift- note bumps on the bottom of the headlights
DC5 post-facelift - note flat bottom headlights
http://www.clubitr.com.au/forums/attachmen...mp;d=1219301356
My DC5R as it currently stands
Wed sport SA90, 17x8 +ET35.
hydie
I currently own a DC5R and last night worked on a DC5S (intake/coilovers).
Difference in looks is the upgraded lights both front and rear aswell as missing the Recaro's on the Type S.
With the Type S having no LSD, it was very noticeable trying to put the power to the ground.
Yes the DC5S has more power on paper, it didn't seem noticeable. My R and the S had the same intake and exhaust mods.
masofasn8r
im assuming you can obviously buy an lsd for the S?
....and nice teg 45SET
45SET
QUOTE(masofasn8r @ Nov 24 2008, 11:14 AM) [snapback]1283196271[/snapback]
yep. Either find a LSD from a Type R (can be found on Ozhonda or other Honda forums for around the $300-500 mark) or get an aftermarket item... which is closer to the $800-$1000... and is less daily friendly.
Thank you.
masofasn8r
yea theres some pretty cool stuff on ozhonda.com
a little bit of a rougher ride i suppose is an okay price to pay to have a nice and quick type R / S
now the finding of one for a reasonable price is the hard part lol
hydie
QUOTE(masofasn8r @ Nov 24 2008, 03:03 PM) [snapback]1283196971[/snapback]
masofasn8r
hahaha subtle mate lol.
i've seen your F.S. ad but not what im looking for if it didnt have the leather interior maybe...
plus gotta sell mine first...
got-vtec
If it aint a TYPE R
IT aint a Tight car
MYB16
I would get an R. Lighter, LSD, amazing seats!!!
But, really the 2 Type-r's and the Type-s are only really seperated by a few tenths, there is nothing in it at all. Therefore it comes down to the opitons list and which model you prefer the look of.
I know I would go an R, but thats just because I love the ideals behind the red Honda badge, even if it is a fair bit softer then the Bremboed 220hp JDM DC5R.
masofasn8r
yea i'd agree i'm leaning toward a type R because of the raw feel of them (went for a test drive in one today) feels like a go cart compared to what im driving now lol prefer the headlights and the spoiler can be removed ....
MYB16
Type-R's in my opinion need a big fuck off wing, they always have (well the Integra's).
02GZM
QUOTE(MYB16 @ Nov 24 2008, 06:44 PM) [snapback]1283198399[/snapback]
/agree
the stock typeR wing should stay on the car. They just dont look as good without it
hydie
The Type S that i was referring to earlier, he bought a R wing because the S one is shit...
masofasn8r
wilson's Type R is the sex and he has no wing... its his car that made me fall in love with the DC5 series... [wilsons car is that black Dc5 with the turbo kit famous front mount on a slant (/)]
TypeR
QUOTE(45SET @ Nov 23 2008, 11:21 PM) [snapback]1283195208[/snapback]
why is your front and rear bar a way different colour?
masofasn8r
lol just noticed that... u must be one of those compulsive types lol
HotMirage
No need to comment about your brothers old car Ian...
Pretty lame if your implying something given Tony swore black and blue it was never in an accident or had an re painting done.
Mr X
QUOTE(masofasn8r @ Nov 24 2008, 05:48 PM) [snapback]1283198005[/snapback]
are you normal?
type r, type r spoiler simple and easy. don't touch it. they are a tight fit with the seats aswel. ohhh i miss mine rolleyes.gif
masofasn8r
if i could find a picture of wilson's then you would all see that it looks hot wingless everyone to their own i guess
DR1FTER
i would honestly molester these fine young amns vehicle. p.s chris, just give me the damn thing thumbsup.gif
