2016 Chevrolet Silverado Fuse Box Location - Chevy Silverado fuse block locations
MrJobun
  • MrJobun
Post #1 post 4 weeks ago
When there are many electrical components installed in a car, there is a need to control all the electricity flow using the safety of a fuse. As such fuses are important in a vehicle, and if one of them burns, you could experience problems with your vehicle.
The Chevrolet Silverado has two fuse box locations. The main fuse box is in the engine compartment on the driver’s side. It should be easy to find since it is quite large. Once you find it, pull the lid to open the fuse box.
On the inside, there are two fuse boxes, one on the right and one on the left of the instrument panel. You can access the fuse box by pulling on the access door on the extreme right and extreme left of the dashboard.
You can see the pictures for a visual explanation below:
The Chevrolet Silverado Owner’s manual has more info on the topic. Make sure to check it out!
