Fiberglass Console Construction Begins - Nissan navara console construct
Page 2 of 3
BARKLAY
i had to reinforce my console with sheet steel (from underneath) because the fibreglass cracked along the edges... but then my curve does go all the way to the top of the dash... just my recommendation before you continue on
NISMOgemini
if u lay out the matting under it properly it wont crack.. i made a similare console for my brothers tarage except it had a 12" sub in it and never cracked at all
ratdawg
k, well because i have covered the whole mdf substructure fully in a single piece of material from top to bottom, i dont think it will crack at edges seeing as there is no fiberglass edge.
the fiberglass will be layered underneath with the addition of some cardboard reinforcements?
ratdawg
Just picked up some more supplies for this and some future projects. = sxc lol
Was going to do some more of the console but it looks like its going to rain so ill prob just wait till tomorrow unless it clears up.
93lux
sweet lookin awsum so far man. hows the console gonna get mounted to the floor?
ratdawg
I will remove the flooring whic is like vinyl, tape down a few layers of aluminum foil and then fiberglass the contours of the floor, ill let thi sharden and then this will be the bottom of the console, - its hard to explain, but will mean the conolse sits exactly to the shape of the floor, this will then be mounted through bolts / clips etc - wait and see the pics to get a better ides.
ratdawg
Today i got on with the console, by reinforcing the resined outer fabric. I did this by placing chop strand mat (csm) along the fabric from underneath, this was then resined and left to dry. When dry, i did another layer of csm this time adding some rolled up catalogues for reinforcement. I will do probably a few more layers of csm just to make sure it its strong enough.
Once this is done, i will fill the out side and smooth it all out.
I also have to start building my dash facia which will be added to the end of the console.
NOTE: edges of the csm were shredded (roughed up) before i resined them in place.
ratdawg
Today i began construction of the dash facia which will connect to the end of the cosnole i am making.
I began by removing the original facia and cutting away any of the plastic that potruded too far forward.
I then masked of the surrounding area and work area using aluminum foil and masking tape.
I them fiberglassed the area i wanted - this fiberglass piece will be the backing of the facia and provide a piece to work on.
ratdawg
Just fitted the console to see how it all fits, its getting there slowley but surely, i have to go over the dash facia part a few more times for reinforcement and then stretch material of the surface to obtain the finish i want - shouldnt be too long now lol.
THE RIG
looks great dawg,looks pretty wide too,sitting right next to the seats.can you still click ya seatbelts in easy enough?
ratdawg
cheers, yeah the seats arent as close to console further back so there is a space for seat belt clickers
FromDeeEast
awesome keep up the good work
BND63
That looks great man.
the alfoil is a bitch to keep down ay...
a tip for next time use a paintbrush and some water and wet the area to be glassed and the back of the alfoil - the dull side. Pat it down to the area, use a different brush to run over it to get it to stay down.
i figured that out when i did my sub box for the wagon.
Keep up the good work.
ratdawg
cheers for the tips, will do.
ratdawg
Started to get this dash facia finished, by adding bits of fiberglass and shaping it to the required size. I then covered this in material and resined. After this is dry, i will add a layer or two of fiberglass and fill and asnd the outside.
ratdawg
Now the dash facia piece is resined, i have cut out the back and am reinforcing from inside because i will be sanding the front down a little to make it even with rest of dash.
BND63
What resin you using, epoxy or polyester?
ratdawg
im using polyester because its cheaper lol, and because of the purpose i am using it for it doesnt really matter that much either way.
BND63
Thought so, it hasn't shrunken or distorted?
ratdawg
yeah it has a little, but this will be fixed with filler - it doesnt matter if i use too much filler either as i will be making moulds of these pieces and recasting later to get a fully fiberglass final product.
ratdawg
when thinking of ways to mount console, i decided that it would be best to smooth the whole floor, so today, i took out the vinyl flooring and gave the interior a clean out.
I will make a false floor from mdf and then fiberglass of the top when done, i will remove most of the mdf (leaving a fiberglass shell) and lay down a layer or two of insulation between the floor and the fiberglass.
Note - the pics of console - because i removed floor and did a bit more fiberglassing to the dash piece, these two pieces do not fit properly - will be fixed later.
ratdawg
I started to build the false mdf floor today, which will later be covered in fiberglass to make a shell, the mdf will be removed and replaced with insulation and deadener.
I wanted the design of the floor to have nice clean straight lines as i plan to cover the fiberglass in carpet and dont want too many complex curves etc that require heat and pressure to conform the carpet to.
I have also designed with easy access in mind, so that while the panels will fit nicely together and there will be no gaps, there will be hidden access points for maintenance etc.
Sorry for pics, i locked car and left keys inside and was too lazy to go get them so i took pics through the window
ratdawg
Havent had much time because of gay assignments, but did a little more with smoothing the floor today.
Still have to finish and reduce the size of some pieces as i need to allow for a few layers of fiberglass and the carpet when finished.
I really need to get a shed or workshop lol my truck is filling with tools cause im too lazy to pack away lol.
ratdawg
At the moment just gradually building up the dash facia using a milkshake mix. Just making it all level and so when it it positioned it is smooth and level with the rest of the dash.
The pic below is probably about the 4/5th layer of the stuff - the previous layers having been sanded between coats.
ratdawg
Ive pretty much finished smoothing the dash piece now - using multiple layers of milkshake and sanding between each coat.
I now have to smooth off the sides and sand it back a bit so that it fits properly.
I then will most probably attach this piece to the end of the console and smooth it all down.
EATU4T
thats actually starting to look really good.
ratdawg
Cheers. Yeah dont think its gunna look like it is now when complete - still a long way to go till finished.
ratdawg
Today i mad a bracket for the top of the dash piece so it sits back even with the dash, and also primered it just so i could see and fix any imperfections.
I have now masked off the dash and am applying more filler to this piece to even up the edges and fix any edges etc more pics should be up tomorrow.
ratdawg
This is after i installed the bracket and the dash piece. It was slightly lower than the rest of the dash at the top and some of the edges were not even all the way around.
To fix this, i masked off the dash and applied filler to basically the whole top half so as to fill the edges and make the dash piece slightly higher and hence even with the rest of the dash.
ratdawg
Today, i sanded back the dash piece, and it is looking a lot better and more flush with the rest of the dash, i will just do 1 more lot of modifications to the edges and then ill finish of the sides of it, and hopefully should be ready for a screen and other additions.
With the console, i am just building up the layers of milkshake and sanding between coats in order to get a smooth finish - same process as the dash facia piece.
Ill add some more pics hopefully tomorrow of the sanded console and the near complete dash piece.
ratdawg
Lately ive just been building up layers of milkshake and sanding back, im now at a stage where i am quite happy with the finish of the console and all i need to do now is to make a few milkshake touchups to some small holes, and sand back in fine grade sandpaper. (i also have to finish the front piece once the dash piece is finished).
i will soon complete the front piece by sanding it back to sit exactly flush with the dash, and filling some small holes, this will be sanded back in fine grade sandpaper as well. well all pieces are complete, i will have them sprayed and then get them ready for casting.
87kid
looks pretty sick man well done
harlzkant
Post #68
That look's very good, I had a thought of doing it to my next ute when I get it but didn't know how to go about it smile.gif Thank's for info and stuff.
ratdawg
Post #69
No worries.
93lux
Post #70
that's lookin sweet so far man. done anymore on it? im planning to make a custom centre console in the future for my 93 lux. but atm im still workin on my custom dr trims, ill put sum pics up sumtime soon hopefully. theyre havin rockford fosgate punch splits in em, built in speaker pod, crossover pod and built in arm rests. next project to do on it too is to make custom A-pillars with a built in tweeter. watcha think? hows ya floor comin along now?
Page 2 of 3
