Rda High Performance Disc Rotors - GSL RallySport
Page 3 of 7
_Jas_
Post #71
Yep positive
gslrallysport
Post #72
Sorry, I read your post as Civic, not CRX... my bad!
Front Standard $39 each
Front Slotted $165 for the pair
Rear Standard $39 each
Rear Slotted $165 for the pair
Regards,
Greg
180sxgold
Post #73
hey
how much for a front pair of 300zx blank rotors and also how much for a pair of slotted rotors for 300zx
moomaniac
Post #74
how much for a pair of series 4 rx7 slotted front rotors, and pair of standard rear rotors?
gslrallysport
Post #75
QUOTE(180sxgold @ Aug 9 2008, 01:33 PM) [snapback]1282714462[/snapback]
hey
Hi mate,
Z31 or Z32? Turbo or NA?
Regards,
Greg
QUOTE(moomaniac @ Aug 10 2008, 06:07 PM) [snapback]1282718425[/snapback]
Hi mate,
A front pair of slotted is $205 for the pair, and rear standards are $90 for the pair. Shipping to SA metro is $28, or else swing me a post code if you're outside of metro.
Regards,
Greg
filofaith
Post #76
how much a set of slotted EvoI-III/VR4 rotors front and rear posted to 4128 ??
jamienumber9
Post #77
Hi greg,
I'm after some new rotors for my 1987 MR2 NA aus-delivered. How much for slotted vs standard replacement?
Thanks very much.
Jamie
gslrallysport
Post #78
QUOTE(filofaith @ Aug 17 2008, 02:01 AM) [snapback]1282745651[/snapback]
Hi mate,
EVO/VR4 fronts are the same, and are $195 for the pair in slotted. The rears between VR4 and EVO are different, but both are the same price, at $175 for the pair in slotted. Postage to 4128 would be $8.
Regards,
Greg
QUOTE(jamienumber9 @ Aug 17 2008, 12:51 PM) [snapback]1282746515[/snapback]
Hi greg,
Thanks very much.
Jamie
Jamie,
Is your AW11 a series 1 or series 2? Either need an exact build date, or need to know if you've got 243/240mm or 258/258mm front/rear rotors.
Regards,
Greg
jamienumber9
Post #79
I believe it's a series 2. It was built in october (10/87 Build)
gslrallysport
Post #80
QUOTE(jamienumber9 @ Aug 20 2008, 06:40 PM) [snapback]1282762477[/snapback]
Ok no dramas. The cut off I've got is 11/87, but it could still very well be a series 2, so we'll go with that. Just have to check rotor diameter first thought if you wanted to go head.
$189 for either pair front or rear.
Regards,
Greg
jamienumber9
Post #81
Sorry Greg, was that $189 for slotted? (10/87 Build AW11 MR2)
Post #82
price delivered to 7011
mini cooper s front slotted - 276mm
s13 rear slotted - 258mm
thanks
sleeperfc3s
Post #83
biggrin.gif How much for front slotted and dimpled rotors for an 86 turbo rx7 s4 posted to 4503 brisbane
thanks james
gslrallysport
Post #84
QUOTE(jamienumber9 @ Aug 26 2008, 02:23 PM) [snapback]1282785897[/snapback]
Yep, provided it was series two (258mm F/R) size rotors.
QUOTE(delazy @ Aug 26 2008, 06:43 PM) [snapback]1282787624[/snapback]
thanks
Hi mate,
Price on those fronts is $289 for the pair in slotted, and $235 for the rear slotted S13. Shipping to 7011 $25.
Regards,
Greg
QUOTE(sleeperfc3s @ Aug 26 2008, 08:02 PM) [snapback]1282788170[/snapback]
thanks james
Hi James,
A front pair of Gold Passivated Slotted and Dimpled to suit is $379, shipping to you $8, or else pickup from Brendale as we're local.
Regards,
Greg
victory
Post #85
hey Greg,
can u PM me the price for front and rear slotted rotors for an S14 delivered to 4207 QLD?
troy_98vt
Post #86
hey mate a price for a vt 99 v6 front rotors only
chasem
Post #87
price for slotted fronts for s15 shipped to 4000
gslrallysport
Post #88
QUOTE(troy_98vt @ Aug 27 2008, 07:39 PM) [snapback]1282793125[/snapback]
Hi mate,
$189 for a pair of front slotted suit VT.
Regards,
Greg
QUOTE(chasem @ Aug 31 2008, 06:28 PM) [snapback]1282809378[/snapback]
Hi mate,
$215 for a pair of slotted, free shipping to you.
Regards,
Greg
HUN51
Post #89
are the soarer and supra rotors (sloted) interchanable? are the different sizes?
whats the biggest you can go on a soarer without changing calipers? and if supra ones are changable whats the bigggest you can go without chaning callipers using supra rotors and callipers.
thanks.
MXHEVN
Post #90
hey mate,
what discs have you got for a 2000 NB8A mx-5 and how much?
thanks
gslrallysport
Post #91
QUOTE(MXHEVN @ Sep 5 2008, 06:16 PM) [snapback]1282837210[/snapback]
hey mate,
thanks
Hi mate,
Between 98-02 the MX-5 gear becomes a bit of a blur. Would you just be able to double check that your rotors are 255mm front diameter and 250mm rear diameter. Otherwise they'll be 270 and 276mm respectively.
Just let me know and I'll fire up some pricing.
Regards,
Greg
175_bpt
Post #92
hey greg how much for a front slotted pair for a kc tx3 laser? 1987 4 wheel disc.
MXHEVN
Post #93
QUOTE(gslrallysport @ Sep 9 2008, 05:13 PM) [snapback]1282852859[/snapback]
Hi mate,
Regards,
Greg
would be 255 & 250mm, 94-00 july (iirc) are 255 & 250, after july 00 - 05 are the bigger rotors.
also how much would it cost shipped to sydney 2165
MXHEVN
Post #94
get a price yet?
::EGGMAN::
Post #95
anyone got this product fitted? im after a set of front & rear rotors how much for an lexus is200 ?
also what size are they?
gslrallysport
Post #96
QUOTE(175_bpt @ Sep 9 2008, 05:18 PM) [snapback]1282852892[/snapback]
Hi mate,
Sorry about the late reply. We're currently in Melb looking at the possibliy of opening a store down here, and am only just getting around to catching up on internet inquiries.
Your TX3 has it got the larger turbo brakes in your conversion? ie. the 260mm ones?
Assuming it does, then a pair of slotted to suit is $215.
Regards,
Greg
gslrallysport
Post #97
QUOTE(MXHEVN @ Sep 9 2008, 07:39 PM) [snapback]1282853773[/snapback]
Hi mate,
Again, sorry about the late reply.
Slotted rotors to suit your car are $185 for the front pair, and $179 for the rear pair. Also available is the EBC Gold Passivated Slotted and Dimpled, but these are a fair bit more expensive if you wanted a price on those. Shipping to Sydney would be $20.
Regards,
Greg
QUOTE(::EGGMAN:: @ Sep 15 2008, 06:55 PM) [snapback]1282880284[/snapback]
Hi mate,
Slotted rotors to suit the IS200/300 are $205 for the front pair, and $325 for the rear pair. The rotors are 296mm and 307mm front and rear respectively.
Regards,
Greg
toiletduck1
Post #98
hey mate...
is it possible to get EBC Turbo Groove Rotors and Redstuff pads for a VY SS commodore?
HYN21
Post #99
price on slotted front and rears on a r33 series 2, also ebc yellow pads
thanks in advance, hyn21
gslrallysport
Post #100
QUOTE(toiletduck1 @ Sep 17 2008, 09:47 PM) [snapback]1282890767[/snapback]
hey mate...
Hi mate,
EBC Gold Passivated Grooved rotors are $345 for the front pair and $330 for the rear pair.
The Red Stuff pads to suit are $275 for the fronts and $215 for the rears, but I would personally take the QFM A1RM pads which are cheaper, locally made, and a better performing pad. The A1RM's are $119 each set either front or rear. Checkout www.qfmperformance.com for more info.
Any other questions just let me know.
Regards,
Greg
gslrallysport
Post #101
QUOTE(HYN21 @ Sep 17 2008, 10:53 PM) [snapback]1282891070[/snapback]
Hi mate,
R33 what? GTS, GTR etc.?
Regards,
Greg
HYN21
Post #102
oh shit sorrry mate, 1996 r33 series 2 gtst
gslrallysport
Post #103
QUOTE(HYN21 @ Sep 18 2008, 02:21 PM) [snapback]1282892536[/snapback]
Too easy.
A pair of front slotted is $395, and a pair of rear slotted is $215. EBC Yellows to suit are $395 and $305 front/rear.
Regards,
Greg
turbofreak
Post #104
hi buddy
How much for a set of slotted cross drilled front rotors and slotted rear rotors for a 1988 mazda mx6 turbo with 4 wheel steer
gslrallysport
Post #105
QUOTE(turbofreak @ Oct 19 2008, 08:44 AM) [snapback]1283020393[/snapback]
hi buddy
Hi mate,
In terms of the cross drilled rotors we've all but stopped selling the DBA gear just because its so ridiculously overpriced, and RDA/EBC are equal on terms of performance and quality, and half the price. In place of the cross drilled rotors (which also suffer from cracking issues) we recommend the EBC Gold Passivated Slotted and Dimpled:
http://ebcbrakes.com.au/images/uploaded/newgolddiscs.jpg
These are $315 for the front pair, and $379 for the rear pair.
RDA slotted rotors are $169 for the front pair, and $235 for the rear pair.
So for front slotted/dimpled and rear slotted you'd be looking at $550.
Regards,
Greg
Page 3 of 7
