Sat Sprints At Qr - In circuit we trust
Page 11 of 42
garlic_s5rx7
Post #351
QUOTE(GTRVspec95 @ May 17 2007, 09:00 AM) [snapback]1281066252[/snapback]
You forgot to tell him to spin down in the dipper and off the final turn Garlic huh.gif
hahaha cheers,
never going to live that down... actually not going to try!
(in the wet, it is just fun)
jezza323
Post #352
spinning off turn 2 just puts a big flat spot on your $240 semi slick sad.gif
GTRVspec95
Post #353
QUOTE(lil_mike @ May 17 2007, 09:40 AM) [snapback]1281066359[/snapback]
you shouldnt need them on the hardest setting. have you upgraded your rear swaybar?
Camber arms, sway bars and coil overs ...
But looking at the photo's I'm sure it was because I hadn't set the coilovers right and the car still has a full interior ...
But I'll be selling it soon to get something which I won't have to worry to much about the interior smile.gif
QUOTE(jezza323 @ May 17 2007, 10:16 AM) [snapback]1281066458[/snapback]
Consider yourself lucky you have the semi slick ...
jezza323
Post #354
well those semi slicks are only 185/55R14........aint the widest tyre around thats for sure laugh.gif
once i am rich i will get some 195/50R15's smile.gif
lil_mike
Post #355
QUOTE(GTRVspec95 @ May 17 2007, 10:23 AM) [snapback]1281066472[/snapback]
if your sway bar is adjustable, stiffen it up more and put your shocks at a moderate setting. that should help out a bit.
superdave
Post #356
Wasn't to sure if you two (the other Corolla) were part of the forums ...
And body roll just shows who are the manly drivers which think strut bracing and stiffer suspension are for sissies tongue.gif
The other Corolla is a member. And now I am (obviously tongue.gif), does anyone know who takes the pics out at the test n tune nights? I went a few months back and saw pics from other cars that night and wouldn't mind knowing if any pics were taken of my car.
Also, I have strut bracing. Suspension is too expensive for me at the moment dry.gif
Mase
Post #357
I've been reading up a bit lately that people are removing their rear sway bars to gain a bit more 'give' in the rear which i can only assume would give more traction.
in saying this i recently put a rather large 27mm rear sway bar in the back of my S13. it came from a Laurel which is a much bigger vehicle. Since doing this the car just spits the ass end out predictably but still spits it out nice and easy........
Many people heading out Saturday? I wanted to but didn't get my engine back in quick enough!!
lil_mike
Post #358
QUOTE(Mase @ May 18 2007, 12:19 AM) [snapback]1281068963[/snapback]
your sway bar is there to minimise body roll. how you tune these things all comes down to personal preference really. the way i set mine up was to stiffen the rear sway bar and to soften up the rear shocks. so when i accelerate out of a corner i get a lot of squat in the rear giving more traction, and much less body roll. again though, everyone will have a different way of going about things. find what works best for you.
jezza323
Post #359
my car has off the shelf "low" springs, KYB Excel-G shocks and big swaybars front and rear. those who have seen it on the track will be able to confirm that there is almost no body roll. it has a very pliable ride on the crappy brisbane roads (IMO) but handles very well.
if you have a look in the suspension forum on performanceforums you will see a very large thread about stiff sway/soft shock vs soft sway/stiff shock combos, gives some good info and comments, worth a read
Fleet
Post #360
QUOTE(lil_mike @ May 18 2007, 07:48 AM) [snapback]1281069199[/snapback]
I agree, its up to experimentation and personal preference to determine what works best, also what works well on one car may not work at all on another car.
lil_mike
Post #361
also, you dont need to be at a race track to see how your setup is. just take it through your local twisties (at the speed limit of course) and see how it reacts to the changes you make. stop, make another adjustment and keep going. one thing you must remember though, is to ONLY EVER ADJUST ONE SETTING AT A TIME! if you make numerous changes at once you could upset you current setup, and not know which part is causing the problem. follow this and you should be fine. experimentation is the key
GTRVspec95
Post #362
Just checked BOM ( http://www.bom.gov.au ) for Saturday ...
Forecast for Saturday
Fine. Moderate to fresh W winds.
Precis: Fine Min 14 Max 28
jezza323
Post #363
cavey
Post #364
QUOTE(fearlesss @ May 16 2007, 09:01 AM) [snapback]1281063118[/snapback]
i just dont think your gona get any shots of jezza on saturday cause hell be behind my car most of the day smile.gif
QUOTE(jezza323 @ May 16 2007, 09:10 AM) [snapback]1281063136[/snapback]
hahahaa, you wish josh! im gonna make sure i keep ahead of u........somehow........maybe steal your semi slicks tongue.gif
PHATCORE
Post #365
cant wait till tommorow biggrin.gif hope it stays dry so i can hopfuly crack into the 59's
GTRVspec95
Post #366
RWD and wet ...
I don't know what fun your talking about blink.gif ...
Honestly ...
Clearing the memory cards and getting the batteries charged atm
neil_se
Post #367
I've pre-booked but can't get out there til about 1-1.30, will i still get a few runs?
GTRVspec95
Post #368
QUOTE(neil_se @ May 18 2007, 11:15 PM) [snapback]1281072214[/snapback]
9krpms
Post #369
neil se, last time I did that the organiser refused entry and told me that they are too busy to run another orientation...even though I've been there more than a few times. Unless you want to try ur luck, it's best to call up and get them to reserve your credit for nxt time.
fearlesss
Post #370
fearlesss
Post #371
bloody hell how long does the sun take to come pu these days !
neil_se
Post #372
QUOTE(9krpms @ May 19 2007, 01:05 AM) [snapback]1281072360[/snapback]
I called up earlier in the week and they said it would be alright.
jezza323
Post #373
woohoo smile.gif time to start prepping and loading up the car.....
GTRVspec95
Post #374
Today's weather report for Ipswich according to BOM
Ipswich
A little rain clearing early morning. Moderate W'ly winds.
Precis: Becoming fine
Max 28
UV Index: 5 (Moderate)
Track temps look like they will be effected in the morning but with any luck conditions will be good to go for the Sprint session thumbsup.gif
neil_se
Post #375
Arg, now i'm thinking i might just skip the towing and drive the silvia straight out so i'll be out by 12.30.
Psi
Post #376
anyone know what time this finishes today?
superdave
Post #377
Finished about 4:30, but I somehow think that that doesn't help any more tongue.gif
neil_se
Post #378
I had an awesome day. Was lucky to get the car home with some severe overheating problems in sessions 2 and 3.
GTRVspec95
Post #379
QUOTE(superdave @ May 19 2007, 06:09 PM) [snapback]1281073734[/snapback]
Alot of mechanical failures it seems and people going out and playing in the sand pits tongue.gif
Most of them weren't to long but man there was alot of them today
QUOTE(neil_se @ May 19 2007, 06:42 PM) [snapback]1281073841[/snapback]
Well your car is allowed to get a bit hot under the collar after all the hot steamy love you just gave it on the track tongue.gif
How did everyone go ?
Temperatures seemed just about perfect for good track times so tell us how everyone is going biggrin.gif
jezza323
Post #380
my front left tyre started to fall apart (delaminate) after the 1st session and was understeering a bitch....chickened out of the last session after the warm up
GTRVspec95
Post #381
QUOTE(jezza323 @ May 19 2007, 07:38 PM) [snapback]1281073995[/snapback]
Thats when you chuck the shitty one on the inside wheel on the rear of the car tongue.gif
Mezevenf
Post #382
I went ok, low 64's as usual. Tyres have had it.
Was stuck in traffic first session, and my tyre pressures were all over the joint! 2nd session was great until I started choking because my fuel was getting low and it wasn't picking up from the tank on right hand turns, so couldnt get the power out of corners.
Last session was pretty good, caught in traffic behind the Junior Zagato though he was just as fast as me in the corners.
Thanks for the piccies GTRVspec95
neil_se
Post #383
If anyone got pics of car 52 (black silvia with white roof and steam coming out of the bonnet) it would be much appreciated if you could email them to me at neilesplin(at)hotmail.com
cheers!
GTRVspec95
Post #384
QUOTE(neil_se @ May 20 2007, 10:36 AM) [snapback]1281075183[/snapback]
cheers!
I'll have a few more on offer when I post the main picture thread in the events section thumbsup.gif
neil_se
Post #385
Great shot, cheers mate.
Page 11 of 42
