Fleet
Post #106
QUOTE(ThunderBolt @ Feb 18 2007, 08:20 AM) [snapback]1280775928[/snapback] Yeah I have coilovers in it, and was running 36psi in my front tyres and 32psi in rear (cold pressure), which I have found good from experience. The main problem being is that I can't power down as early as I would like and the tail won't try to kick out until coming out of the corner. Oh well, it will give me something to work towards next time. so then to correct understeer if you have coilovers, you need to stiffen your rear shocks and/or soften your front shocks. also you are running way too much tyre pressure if you are running semi slicks. those kind of pressures are ok for street tyres, but not for semis. as Jezza said you should be running something like 28psi cold. |
S15_Clint
Post #107
QUOTE You wouldn't want too much camber up front? only 2-3 degrees??? I would of thought any more than that and would want to start looking for some bigger sway bars?? Correct me if i'm wrong but too much camber reduces the contact with the road and thus reduces the braking ability?? yes of course there is a limit, depending on tyre size, tyres, tyre pressure, stiffness of the chassis, suspension settings and brakes you should run camber to suit really. For example with the Hoosier tyres it is recommended to run a good 3-4 degrees of camber or more. Have a look at most of the alfas and some of the other regulars you will notice they run at least -3 and some alot more. Personally i run -3.5 front with 3.5mm toe out overall, i have found this is a pretty good setting for me, with no understeer experienced, but just a little oversteery. Theres alot to play with really! All about testing it out ![]() |
spazz
Post #109
QUOTE(S15_Clint @ Feb 18 2007, 08:46 PM) [snapback]1280778060[/snapback] yes of course there is a limit, depending on tyre size, tyres, tyre pressure, stiffness of the chassis, suspension settings and brakes you should run camber to suit really. For example with the Hoosier tyres it is recommended to run a good 3-4 degrees of camber or more. Have a look at most of the alfas and some of the other regulars you will notice they run at least -3 and some alot more. Personally i run -3.5 front with 3.5mm toe out overall, i have found this is a pretty good setting for me, with no understeer experienced, but just a little oversteery. Theres alot to play with really! All about testing it out ![]() That seems like a very aggresive toe setting ? A rear wing and front canards would probably help ... I know having some down force makes turn 1 ALOT more friendly to negotiate ![]() |
Rookie ROX
Post #111
QUOTE(ZENNON @ Feb 19 2007, 10:24 AM) [snapback]1280779076[/snapback] (ps. DS2500's are awesome) ![]() Just get annoying if you also run them on the street...everyone looks when I squeal to a stop ![]() ![]() Sounds like it was another good round, April here I come! ROCK ON R~R |
Rookie ROX
Post #113
QUOTE(ThunderBolt @ Feb 19 2007, 11:24 AM) [snapback]1280779214[/snapback] I don't get any squeal from my DS2500s. How old are they? I only get it at slow crawl - as in at a set of lights. They're about 2 months old ![]() ROCK ON R~R |
ThunderBolt
Post #115
Close to a year old, however having said that, my car dosen't get much mileage. Only comes out on the rare occasion. |
GTRVspec95
Post #116
QUOTE Driver Make/Model Category "17/02/07 Fastest" "17/02/07 Points" Adam Disney AUDI Road 6 68.10 1 Adam McLeod Pugeot 206 Gti 180 Road 4 67.88 1 Adam Parker Toyota MR2 AW11 Road 4 68.03 1 Aidan Murphy Alfa 75 Road 8 67.02 1 Alex Chambers VX SS Commodore Road 8 65.31 3 Alf Del-Brocco Alfa Romeo 1750 Road 4 70.03 1 Alvin Sham Honda Integra Type-R Road 4 65.86 1 Andrew Tewes Alfa Romeo GTV 2.0 Road 4 68.26 1 Andrew Tremeer HSV VS Ute Road 8 65.55 2 Andrew Wilson Alfa 105 GTV Race 1 62.84 12 Anthony Goulding Honda Integra Road 4 59.94 20 Arron Bentley Nissan 300ZX Road 6 63.59 1 Ashley Duff Charger Road 6 67.14 1 Barry Beehag Nissan S14 200 SX Road 6 62.61 1 Bernard Mangelsdorf Alfa Romeo 75 Road 6 64.13 1 Bill Hoffmann Renault Clio Cup Road 4 66.71 1 Bob Whitehouse Alfa Sprint Race 1 62.42 15 Cameron Dyal EVO 8 MR Road 6 57.12 20 Charles Webb Alfa Road 4 64.84 3 Chris Hall Mazda 929 Race 2 69.72 7 Clint Palmer Nissan 200SX Road 6 60.53 7 Colin Clark Holden Commodeore Road 6 68.75 1 Colin Roberts Birkin S3 Road 4 62.78 9 Damian Reardon Westfield SE Road 4 63.02 8 Daniel Washburn Nissan R33 Skyline Road 8 69.64 1 Darren Lockhart Holden Torana Road 8 62.95 7 David Dickson Porsche GT3 Road 6 60.99 6 David Kutschkau Nissan Skyline Road 8 68.87 1 David Morris AUDI A4 Road 6 70.09 1 David Palmer Porsche 911 GT3 CS Road 6 59.39 9 David Phillips Mazda RX4 Race 2 76.61 5 David Shaw Subaru Impressa Road 6 63.93 1 Dean Lettfuss Honda S2000 Road 4 64.04 4 Dick Veenhof Alfa Romeo Road 4 71.95 1 Dwayn Taylor Holden Torana Race 2 58.55 20 Eddie Lapienis Birkin Road 4 62.06 15 Glen Wex Subaru Sti Road 6 60.27 8 Glynn Pointon Datsun 240Z Road 6 61.69 5 Greg Murphy Alfa 75 Road 8 64.62 5 Hamish Richmond Subaru WRX STi Road 6 57.87 17 Ian Morten Road 8 66.99 1 Ian Noffke Ford Capri Race 2 63.86 12 Jason Kelsey Honda S2000 Road 4 63.83 5 Jayson Mayo Nissan Slvia Road 6 63.62 1 Jeff Oldham Datsun 1600 Road 4 62.71 10 Jeffrey Grimes Mazda RX7 Race 2 83.27 4 Jeffrey Knibb Ford Focus XR5 Road 6 62.75 1 Jenny Mitropoulos Alfa Romeo Road 4 69.33 1 Jeremy Drice Toyota Starlet Road 4 63.50 6 Jim Ryan Alfa Romeo Race 1 65.98 9 John Hay Renault Feugo Road 4 69.53 1 John Needham Porsche 911 Race 2 John Ryan Alfa Romeo GTV Race 1 John Sim Honda S2000 Road 4 61.67 17 Johnny Mansfield Nissan 180SX Road 6 64.78 1 Jordan Trieger Holden Astra Road 6 68.02 1 Josh Coote Subaru WRX Road 6 62.11 2 Ken Percival Alfa Romeo GT Junior Road 4 62.66 12 Lea Medhurst Westfield Clubman Road 4 63.02 7 Luke Page Subaru WRX Race 1 62.06 17 Manuel Pena Alfa Romeo Road 4 65.03 2 Mark Craig Datsun/Mazda Race 2 62.26 15 Mark Jackson Alfetta Race 1 64.71 10 Mark Rayner Mitsubishi EVO9 Road 6 59.15 10 Matt Behan Datsun 1200 Road 6 62.58 1 Matthew Stoyakovich Renault Clio 182 CUP Road 4 66.09 1 Matthew Taylor Triumph TR7 Road 4 69.72 1 Mel Carson Alfa Romeo Road 4 67.83 1 Michael Broomhall Mazda 929 Race 2 67.05 8 Michael Francis Alfa Romeo Montreal Road 8 66.50 1 Michael Galvin VW Golf Gti Road 6 64.64 1 Michael Grimes Holden SLR Torana Race 2 64.93 9 Michael Howse Mazda RX7 Road 8 61.11 15 Michael Lew Alfa Romeo 2.0 Road 4 65.90 1 Michael Pankhurst Subaru WRX Road 6 68.33 1 Nathan Purcell Mazda 929 Road 8 65.72 1 Neville Munt Datsun 240Z Road 6 63.13 1 Nick Barry-Cotter PRS 82 Race 1 59.44 20 Noel Preston SAAB 9-3 Road 6 67.37 1 Paul Gillis DRB GT40 Road 8 58.52 17 Paul Ross Alfa Romeo Road 4 67.36 1 Paul Young Alfa Romeo Road 4 66.27 1 Peter Walsh Nissan 300ZX Road 8 57.56 20 Philip Rangley Renault Megane Road 6 65.08 1 Richard Anderson Alfa 75 Road 8 64.34 6 Robert Brooks Datsun 240Z Road 6 61.81 4 Ron (Kar Kui) Lo Subaru Liberty GT Road 6 67.81 1 Ross Grimes Holden LJ Torana Race 2 64.82 10 Sara Couper Toyota Celica Race 2 69.79 6 Scott Mackenzie Nissan 180SX Road 6 66.03 1 Scott Osborne BMW E36 M3 Road 6 59.09 12 Shane Dunstan Ford Focus STi70 Road 4 68.12 1 Sian Jackson Alfa Romeo Race 1 68.20 8 Simon Grant Nissan R32 Road 8 64.63 4 Stefan Knoeckel Mitsubishi Lancer EVO 6 Road 6 62.03 3 Stephen Kakavas Mitsubishi EVO9 Road 6 58.39 15 Steve Calverley Holden Road 6 63.93 1 Steve King Nissan Skyline Road 8 61.87 12 Steve Pickering Subaru WRX Road 6 65.35 1 Steven Davies Renault Clio Road 4 65.94 1 Stuart Borrows Nissan Skyline Road 8 62.35 10 Stuart Elphinston Holden Monaro Road 8 62.38 9 Stuart Jackson Nissan 180SX Road 6 67.45 1 Terry Cave Toyota Starlet Road 6 67.62 1 Troy Sinclair Toyota Sprinter Road 4 66.44 1 Warren Boylan Cobra Race 2 60.77 17 Zennon Damant Nissan Skyline R32 Road 8 62.47 8 Numbers are up folks ... so how are you doing ![]() http://www.queenslandraceway.com.au/sas-points.xls On a side note ... I couldn't finish cropping the photo's as I didn't think the missus' laptop would run out of charge ... doh ... Will hopefully finish everything this evening and have images up by tomorrow at the latest ![]() |
Rookie ROX
Post #117
QUOTE(jezza323 @ Feb 19 2007, 11:51 AM) [snapback]1280779285[/snapback] no squeel from mine either, only 1 week old atm though ![]() Hmmmm... Just to be clear, they ONLY squeal at very low speeds, as I said like creeping along at traffic lights, anything else they're beautiful. Concerns me if I'm the only one, but I always thought the downsides to them were excess dust and low speed squeal. Or am I the only one who uses them on a daily? ![]() Once again congrats to those who pulled off PBs ROCK ON R~R |
ZENNON
Post #118
QUOTE(Rookie ROX @ Feb 19 2007, 05:06 PM) [snapback]1280780480[/snapback] Hmmmm... Just to be clear, they ONLY squeal at very low speeds, as I said like creeping along at traffic lights, anything else they're beautiful. Concerns me if I'm the only one, but I always thought the downsides to them were excess dust and low speed squeal. Or am I the only one who uses them on a daily? ![]() Once again congrats to those who pulled off PBs ROCK ON R~R i use mine daily but only put the pads in last week - haven't noticed any squalling yet. (although i wouldn't really care if they do) ps WOW jezza!!!! 63 in a N/A starlet!!!! nice! |
Rookie ROX
Post #120
Must be me then |
Rookie ROX
Post #124
QUOTE(mosport @ Feb 19 2007, 07:42 PM) [snapback]1280781130[/snapback] do you guys get any brake fade running the ds2500's? do they stop OK cold ? are they road legal ? where can i buy them ? Thanks ![]() No fade, stop reasonably well cold, I happily live with them day in day out, they're the harshest pads you'd want for street driving, 3000 series or higher will just munch through your rotors. I purchased mine from V-Sports in Sydney, the official distributor is Competition Friction in ACT. Send emails to both, I noticed there is a difference in prices between everyone (oddly enough V-Sport was cheaper than Comp Friction) ROCK ON R~R |
Mase
Post #125
ha ha i got owned by some much lower powered cars with my 63.62!!! |
Rookie ROX
Post #127
Man 63.62 isn't a time to be laughed at, it's pretty impressive for a first time on the track! |
garlic_s5rx7
Post #128
QUOTE(jezza323 @ Feb 20 2007, 07:16 AM) [snapback]1280782451[/snapback] great to have some new cars out mase you can always improve the car but ive found most of my improvements have been from just cutting more laps. if you really wanna go quicker just come out as often as you can, and why wouldnt you want it...its great fun! ![]() here here... well said Jezza ive taken 5 secs off my lap time, no improvements to the car... (except a *good* wheel alignment) I might have to bring the 7 out for an april sprints... im missing out on too much fun |
GTRVspec95
Post #129
QUOTE(garlic_s5rx7 @ Feb 20 2007, 08:45 AM) [snapback]1280782566[/snapback] here here... well said Jezza ive taken 5 secs off my lap time, no improvements to the car... (except a *good* wheel alignment) I might have to bring the 7 out for an april sprints... im missing out on too much fun You think your missing out on fun ... ![]() In the conversation of brake pads ... I run Endless CC-R / CC-X pads ... Takes time to warm, squeakie bastards at slow speeds and brake dust galore ... Thou in saying that I haven't really given them a good flogging on the track IN OTHER NEWS ... Will have images up sometime today ![]() |
GTRVspec95
Post #133
https://www.boostcruising.com/forums/index....howtopic=192513 |
GTRVspec95
Post #134
QUOTE(Rookie ROX @ Feb 20 2007, 09:02 AM) [snapback]1280782601[/snapback] Team TPR and the Squeaky Brothers represent yo! ![]() ![]() ROCK ON R~R * squeak squeak * ![]() ![]() |
ThunderBolt
Post #135
QUOTE(Rookie ROX @ Feb 20 2007, 07:57 AM) [snapback]1280782484[/snapback] Man 63.62 isn't a time to be laughed at, it's pretty impressive for a first R~R Corrected. ![]() |
