MaDDoG
ummmmmmmmmm.......few things....firstly its a sc14 supercharger that would melt if you went to run 8psi into a 4.2 litre and ummmmmmm..... the OWNER says its not even tuned so i dont know where you get the kw rating you say |
MaDDoG
QUOTE(that_kid @ Nov 30 2005, 12:06 PM) ^^^^ is it a coincidence that u found that or did u go looking? [right][snapback]5654887[/snapback][/right] are you asking me? if so yes it was a coincidence as i normally check through ebay to see whats going and i remembered that as its unusual, also because he is using the same supercharger i used when i was making supercharger kits for the vn,vp,vr commodores etc |
calvin_spoon
QUOTE(MaDDoG @ Nov 29 2005, 11:53 PM) ummmmmmmmmm.......few things....firstly its a sc14 supercharger that would melt if you went to run 8psi into a 4.2 litre and ummmmmmm..... the OWNER says its not even tuned so i dont know where you get the kw rating you say http://cgi.ebay.com.au/supercharged-sovere...1QQcmdZViewItem [right][snapback]5652214[/snapback][/right] its an estimated rating that it should put out as i was told by jarret perfomance maryborough engine wont melt get real the stock compression ratio is 7.7:1 i think 8psi wont hurt it tuning not what im very good at QUOTE(black86 @ Nov 30 2005, 01:10 AM) sleeper.. heavy as tho hit the scales at 2.35t[right][snapback]5652569[/snapback][/right] |
calvin_spoon
QUOTE(defpony @ Nov 29 2005, 11:11 PM) i like, will look good when the exterior is tidied up. I bet you've created a few more rattles bumping 140db in a car like that. Show us what u got. [right][snapback]5651666[/snapback][/right] you bet ya (not many though very solid car) mostly get discbrake sheilds rattlingand exhaust sheilds QUOTE(trenty man @ Nov 30 2005, 10:11 AM) nice man... show us ya sound system!... please [right][snapback]5653451[/snapback][/right] will post pics once i take them unit consist of 2 12" audiopipe dual voice coil subs 2x 4x150w rms and powering front rear and mid speakers and an alpine dvd unit QUOTE(that_kid @ Nov 30 2005, 12:06 PM) ^^^^ is it a coincidence that u found that or did u go looking? fount it down melbourne paid $1100 to truck it up to maryborough qld[right][snapback]5654887[/snapback][/right] |
MaDDoG
QUOTE(calvin_spoon @ Nov 30 2005, 06:49 PM) its an estimated rating that it should put out as i was told by jarret perfomance maryborough engine wont melt get real the stock compression ratio is 7.7:1 i think 8psi wont hurt it tuning not what im very good at hit the scales at 2.35t [right][snapback]5657068[/snapback][/right] i am talking about the supercharger your using mate not the motor teflon coated rollers, once spun over 12,000 rpm the rollers expand, grinding into the housing of the charger itself because the teflon coating has melted off. Also running the charger on its side, the oil pick up on the roller shafts will not feed oil correctly, so if you were spinning the charger around 15,000rpm (speed required to create approx 8psi on a 4.2 litre) it would be in pieces. And i do know a few things about forced induction as i have supercharged about 35 commodores and turbo charged over a dozen 4 litre fords and been in the industry for 10 years. Jarret performance estimated that much power with a sc14 on it? |
calvin_spoon
QUOTE(DODelaney @ Nov 30 2005, 09:05 PM) prove all the work done and the transport receipt coz i call BS daniel [right][snapback]5657992[/snapback][/right] im not sure what you want me to prove but if u think ur intelligent call, toll vehicle logistics and ask for price from footscary melbourne to maryborough qld and with disablement fee will come to $1118 you want me to get you the number.....1300 660 616 my old trackin reference is calvinheid check it i dare ya as for engine work anyone mechanicaly minded will lookup the specs |
calvin_spoon
Engine: |
