Post ![]() |
ANYONE KNOW MUCH ABOUT THIS STUFF? currently rebuilding an engine... a while ago a mate told me about boring an engine out...? changing the bottom end or somethin to bore it out to a bigger engine capacity?? anyone know much about it?? |
DC2R8D
QUOTE(wooley @ Mar 2 2009, 01:11 AM) [snapback]1283662488[/snapback] when u bore u ut goes from say 1600cc to 1700cc for example but ull need bigger piston imo stroke it, bore it 30 though, get 20 off head, stiffer valves and get the out let chambers ported on the head with extractor n a custom intake n a ecu ull b set ahhkk so its a pretty bloody expensive procedure! hahhaa how much u lookin at roughly for a DC2R?? any ideas? coz currently the car is in ma mech's shop needs to be sent away for engine bore to be reshaped!! :S no good really gonna cost a bit too so yee any info would be greatly appreciated! |
The DC2R B18C engine does not take much to weaken the block strength if you bore it out too much. Get the block inspected to see how much the bad bore needs to be machined and get all of the bores machined to that size. 40 thou is about the limit from memory without fitting a set of sleeves(expensive option) |
02GZM
If you change the bore size you will need to get a head gasket and pistons to suit. It's not worth boring to the point that you need sleaves if you arent going to do further work to the engine imo. A B20 conversion is definately the more cost effective solution as iamhappy26 said if it leads down that path. If you are planning on boring it out, talk to the guys at Toda if you're after a larger diameter metal head gasket. |
lil_bobby_260
Big issue with boring engines is clearance - dont want to weaken the metal between cylinders, or between the cylinders and water galleries etc. You can bore them out then have the cylinders sleeved with a tougher material but is expensive. |
