Bad Experience With Nt Tuners
Page 2 of 3
drift_ke70
i do believe they are on anictomatis (spelling) road near the prison
SP33D RAC3R
QUOTE(drift_ke70 @ Jan 12 2008, 07:34 PM) [snapback]1281806450[/snapback]
is that in darwin champ?
beohbe
Thanks for the info.....great that Premier hire it out.....though I thought they might as I'd heard of tuners coming up from Sydney (mainly MRT). Might get a few runs done later in the year to verify my tune is still as safe as I want it to be.....plus get the factory speed limiter shifted up a little bit.....damn Foz has one at 210 and it hits it on the straight at HV.
HASHIRIYA
i don't get ripped off from workman ship done in darwin (mind you i only use like a very few places), im also prepared to wait, its certain places down south that send stuff to me that is where i feel short changed
QUOTE(SP33D RAC3R @ Jan 12 2008, 03:23 PM) [snapback]1281806059[/snapback]
where is premier fuel??
sort behind hose power
drift_ke70
QUOTE(SP33D RAC3R @ Jan 12 2008, 06:42 PM) [snapback]1281806468[/snapback]
yeah mate sure is near the prison in berrimah
SP33D RAC3R
cheers...
what about good tuners that people know of?? any sucsess stories?
BU5HIDO
Got my 100,000k service and front mount installed the other day. Took 2 and a half days and cost me $2000. They didn't even get around to installing the other stuff I had. Everything was only ment to take 2 days and was quoted $2000 for everything. Just went there and picked my car up anyway, I'll get someone to install everything else later in the week... Never go back.
SIKUNIT
JSM?
BU5HIDO
Across the road....
taylz
Isn't the 100k km service "The BIG one" with WRXs and generally cost in excess of 1200 by itself anyway? - Timing belt replacement (amongst other things)
beohbe
QUOTE(taylz @ Jan 14 2008, 02:05 PM) [snapback]1281811638[/snapback]
Yup. Timing belt, all fluids, spark plugs yada yada
BU5HIDO
yeah so that leaves $800 for a bolt on FMIC install??????
MADcunz
'bolt on' normally doesnt mean that it 'bolts on' normally takes a few hours to get an intercooler setup. in saying that - what was the reason you got charged more then the quote?
RBNT
Timing belt on an EJ is a prick of a job.
Medic_01
well i'm heading into high tech on thursday to get the haltech installed.
and i've double checked... they do have the correct wiring diagram
beohbe
QUOTE(MADcunz @ Jan 14 2008, 03:04 PM) [snapback]1281811835[/snapback]
especially if the front bar needs trimming....which in 99.999999999% of FMIC's on WRX's is the case
MiNiTrUkR
good luck fletcher hopes it goes smooth this time
(p.s where did you get the monitor for your sunvisor?)
HASHIRIYA
QUOTE(RBNT @ Jan 14 2008, 05:05 PM) [snapback]1281812391[/snapback]
i watched someone do it who made it look piss easy
ITSSWAR
QUOTE(RBNT @ Jan 14 2008, 05:35 PM) [snapback]1281812391[/snapback]
Megz
Guys can you keep the names out of the thread??
While it's good to find out about bad service keep the names for PM or private conversations - would hate to see you guys get warnings or banned.
BU5HIDO
QUOTE(beohbe @ Jan 14 2008, 09:00 PM) [snapback]1281813650[/snapback]
$800/$60ph=13.33hrs labor to fit a front mount, thats after the discount! Ok ok he had to put my new alloy radiator in too (bolt on also) and I don't know if he cut the front bar cause its resting on the FMIC. I don't believe you should charge the customer if you cant figure something out.
I've moved on, found a new place to do all my install work.
VLCT WALKY
QUOTE(BU5HIDO @ Jan 15 2008, 02:31 PM) [snapback]1281815468[/snapback]
where's that?
SIKUNIT
QUOTE(BU5HIDO @ Jan 15 2008, 01:31 PM) [snapback]1281815468[/snapback]
Funny stuff....
POCOCK
is funny concidering he musn't of given it a go him self
Gassdup
Geez thats cheap for labour, Isnt the average around 80-90 per hour? Be careful about being critical of that place as you may find that you will end up back there after the other place's butcher your subie.
beohbe
Yeah, no that flash when you don't get what you paid for.....
As far as DIY goes.....
About a year ago I helped a mate fit a "bolt-on" FMIC to his Foz XT. A long way from being bolt on, came with poor instructions (the manufacturer was okay over the phone with advice though) and getting the bar right was a pain......trim, test fit, remove, trim, test fit, remove......finally get it all together and fire it up, damn CEL, so we had to check all the plumbing again. It was quite dark when we were satisfied with the fit and we'd started in the early morning.
RBNT
QUOTE(Gassdup @ Jan 15 2008, 03:10 PM) [snapback]1281815766[/snapback]
Im sure he will be fine Haydz.
VLCT WALKY
QUOTE(Gassdup @ Jan 15 2008, 03:40 PM) [snapback]1281815766[/snapback]
MADcunz
why does everone worry so much about fitment? get the angle grinder out - hack the shit out of it, then drill some holes and cable tie the sucker on. Quick and efficient wink.gif
RBNT
Ive seen one of your home made wiring jobs, did you use the grinder on that job too:)
MADcunz
my home made wiring jobs? nahhhh havent done any of them mate, i stick to bumper and intercooler fitting. bearing in mind that just because i owned a vehicle doesnt mean i carried out ALL the modifications myself!
BU5HIDO
QUOTE(VLCT WALKY @ Jan 15 2008, 02:06 PM) [snapback]1281815614[/snapback]
where's that?
PM'd
VLCT WALKY
Post #68
QUOTE(MADcunz @ Jan 15 2008, 06:50 PM) [snapback]1281816679[/snapback]
is that the werid ass computer board that everything went to, but fail to be earther properly or something along those lines?
MADcunz
Post #69
i dunno! im guessing thats what is being referred to.... obviously not much R&D went into that sad.gif the only prob i ever had with it though was when it wasnt earthing properly - despite its looks it was functional and reliable.
incubus
Post #70
QUOTE(MADcunz @ Jan 15 2008, 05:50 PM) [snapback]1281816679[/snapback]
Page 2 of 3
