The 2h engine is one of the most robust diesel engines ever made. This one has Great compression & very little blow by It's been serviced every 5000 km, with top shelf Penrite HPR diesel oil Toyota CT26 turbo only fitted 6 months ago, steam pipe turbo manifold with 15mm header flange plate Brand new alternator Radiator has just been reconditioned & cooling system flushed - new 5 year coolant used New Brake master cylinder New Brake pads Cold A/C Dual battery system Aux power to rear for fridge etc Pioneer sound system Overhead console Snorkel Rubber wheel arch flares Steel Bullbar (ARB?) Full alloy roof rack (not currently fitted) Steel rear bar with Hayman reece towbar built in (ARB) Comes with swing away spare wheel which could be re-fitted to rear bar Also comes with spare wheel mount for rear door which i was going to fit after i took the swinging one off No roadworthy atm, It needs a new combo switch to make high beam work, and new front crank seal fitted before it will pass roadworthy. You can chuck a double mattress in the back, go anywhere & just stop and have a camp. So cool. Plenty of power, plenty of extras, and plenty of potential too. Call or text XXXX-XXX-XXX to arrange a look.
Detailed Specifications
general
Make
TOYOTA
Family
LANDCRUISER
Variant
(4X4) 11 SEAT
Series
HJ75RV
Engine
DIESEL
CC
3980
Size
4.0L
Cylinders
D6
Country of Origin
JAPAN
Fuel Type
DIESEL
Vehicle Segment
SUV LARGE
suspension
Track Front
1415
Track Rear
1400
Brake Front
DC
Brake Rear
DR
Suspension Front
LIVE AXLE.
Suspension Rear
LIVE AXLE.
This vehicles specifications may differ from the above as it may have undergone modification, please check with the seller. The above specifications have been based on manufacturer standard specifications.
^ Repayment examples are based on a Chattel Mortgage commonly used by businesses. Excludes fees and government charges, subject to assessment and approvals. Australian Credit Licence 392426.
