17th April 2010 - 12:45 AM
Where is the switch for the fans on the ecotec v6? Vt thermo fans not working... im suspecting the switch but im unsure of where it is? the switch at the thermostat is only the temp gauge sensor not the fan switch... there is only one switch at the thermostat so where is the other one?? can anyone help us out?? |
familia
Hey mate from memory on the vz which will b similar if you turn your air con on the big thermo will spin and the smallier one is your engine thermo. |
familia
Given that the VZ has a different engine to the VT, surely they wouldn't be the same........right? :s Correct. The OP should start looking for the ECT sensor in the spot where I told him it was in the other thread. |
GILLICK
Correct. The OP should start looking for the ECT sensor in the spot where I told him it was in the other thread. It'd be all sorted if that was true but you didnt actually tell me where the fan switch is! the gauge sensor is at the thermo housing but the fan switch is elsewhere..... I was asking for help not for smartass comments! |
