3rd February 2007 - 05:00 PM
Hey i dunno if anyone knows these but i looked everywhere to find these and had no luck.. so i thought id post em here ECU Diagnostic Explained: The ECU is in the passenger footwall, behind the plastic kick plate to the left of your feet. You'll have to remove the computer from the mounts in the footwall, as the led/leds you'll need to see are pointing towards the front of the car. Switch on the ignition but don't start engine, the led on the ECU will begin glowing turn the selector screw clockwise all the way. There are three types of factory ECU in Skylines. One type has two LEDs and five modes, the other type has one LED and two modes and the last type has no LEDs, the output is done with the engine check light in the instrument cluster. For two led ecus the led will flash once, pause, flash twice, pause... all the way up to five this is the diagnostic mode Mode 1 = one flash, mode 5 = five flashes. When you reach the right mode, turn the screw back counter-clockwise. Mode 3 is what most people use. For one led ecus wait a couple of seconds, and turn the screw back counter-clockwise, the ECU is now in mode 2 the engine check light on the dash will mirror the LED on the computer. The led will flash out a code or series of codes if there is more than one fault More recent ECU's have two LED's red is first digit, green is second digit, e.g. red 2x flash, green 1x flash = code 21. The ecus on most R32's have one LED, long flash = first digit, short flash = second digit, e.g. long, long, short = code 21. Codes: 11 Crankshaft position sensor 12 MAF sensor circuit 13 Coolant temperature circuit 14 Vehicle speed sensor circuit 21 Ignition circuit 31 ECU 34 Knock sensor 43 Throttle position circuit 45 Injector leak 51 Ignition circuit 54 Auto signal to ECU 55 All OK Turn the ignition off to put the ECU back to normal. There is also an O2 sensor test in real time available - do the above to get the ECU into mode 2 (single LED ECU) or mode 1 (2 LED ECU's) Start the engine. Warm the engine, and then run under no load at 2000 rpm for the test. Single LEDs: on = lean, off = rich Dual LED's: green LED on = lean, green LED off = rich This post has been edited by ezekiel10: Feb 3 2007, 05:07 PM |
the red krawler
... err, yeah |
