NiSlo
Post #77
Engine 3E-TE |
AmperSand
Post #79
QUOTE 1JZ-GTE 2491cc DOHC twin turbo I6 (or single turbo vvti). the 2JZ is basically a stroked 1JZ, although the 1JZ is known to have a superior head design with better flow, hence the existence of the 1.5JZ-GTE Negative. So many people crap on about that, but in reality, the 2jz has bigger ports and valves.. so wonder which one flows better? See many JZA80 supras, Aristos etc with 1jz heads on their factory 2jz's? I think not.. you ever wonder why? Its such an old wives tale, with absolutely no corroborating evidence to support it. Logically the 2jz having bigger ports/valves WILL flow more. |
Sciclone
Post #80
"About the 3S GE cracking under boost pressure. |
jposupra
Post #81
QUOTE also lets not forget the good ol 3tgte 3T-GTEU: 1.8L DOHC 160hp@6000 152nm@4800 compression ratio 7.8:1 (?) (7.3psi) stock(?) as somebody said earlier the 1g-gte motors aren't all that in a supra, but put them in something lighter such as a TA or RA series celica and you can have a weapon. ![]() |
eighty-eight
Post #82
7Ms main problem is the actual head gasket. |
Post #87
QUOTE(mz20_drifter @ Oct 6 2005, 05:31 PM) wat about da toyota crown's the 1989 model not sure on da name UZS131 Is the Toyota Crown prefix for the 1989 model *Looks at his* Ok not much light has been shed on the 1uzfe, I will attempt to get some info out..... Toyota/Lexus 1UZ-FE 4L (244 cubes) 4 valve quad-cam engine. It has a factory forged crank with chamfered oil holes and radiused journals, six bolt mains, reinforced lifter galley, and all aluminum construction. Pound for pound it was the most advanced V8 until it's successor--the 3UZ-FE--was introduced. Toyota spent an incredible amount of money developing the 1UZ which was their first DOHC production V8.They had so much confidence in their achievement that they used this engine exclusively in the new flagship Lexus LS400. One of design achievements was the compact design of the engine. Consider the heads sharing a single cam drive. It would have been much easier to seperate the cams on individual gears, but this would have sacrificed space. The anti-backlash "scissors gear" mechanism makes the head narrower and the overall width of the engine less. It might appear to be a low perf. set up: A single cam gear drives the intake cam, which in-turn drives the exhaust cam on an "anti backlash" gear. The only adjustment to make here is to check the lash and replace shims as necessary. The genius in this system is the simplicity. No rockers or followers. The cam rides directly on the shim that sits on a lightweight cup that presses down on the valve. It gets even better. The cup sits in a reinforced well; built to minimize movement. This technology is common in high revving race bike engines. The narrow valve angle provides good mileage and smooth power delivery. It also allows the head to be made narrower. Incorperating aluminum lifters and short valve stems, Toyota made the reciprocating parts of the valvetrain few and extremely light. The only parts that need to be serviced are the iron valve shims. Further demonstrating their command over the engineering program, the shims can be checked and replaced without removing the cams. The all aluminum construction makes the entire engine almost as light as a 2 liter iron mill. All of the accessories were mounted directly to the engine and the starter is in the middle of the V section to save space. The water cavity of the water pump system is integral to the block to allow a less protruding water pump. The long intake runners are crossflowed for high inertia airflow, yet extremely compact. The lightweight block has 2mm iron liners for good wear and heat transfer. Pistons are hypereutectic and have thermal expansion struts. Wrist pins are full floaters and the top rings are coated for long wear. Rods are factory forged units, as is the crank. All of the pieces were weight matched and balanced from the factory to reduce noise and vibration. The oil pan is 2 piece and adds rigidity to the bottom end of the engine. What would a discussion of the 1UZ-FE be without mentioning the 6-bolt main, steel cap, deep crank recess, bottom end. This contributes to a virtually indestructable assembly. The stock bottom end has been known to make almost 1000 bhp on mostly stock parts. With a completely stock assembly and compression ratio (10:1), the 1UZ has produced 600 bhp with 15 bs of boost. Im sure Ive missed something somewhere here, im sure `nigno will have something to add that ive missed too. There are plenty of performance parts available for these engines, 8 throttle body manifolds, ram setups, twin blowers etc etc. Tough as nails engine they are, glad to have one in my Crown. |
CSX 16
Post #88
QUOTE(Mookie @ Oct 6 2005, 11:15 AM) I was gunna say he missed the 1ggze the supercharged version of the 1ggte. Considering my celica with a stock 1ggte will beat a slightly modded (upped boost and wolf) 7mgte and it has an extra litre on me i'd say thats pretty good. i wouldn't say a 1ggte would go all that great in the car is came factory from but chuck em in a lighter car (celica) and they are to die for. This site shows a few different specs and also shows how power improved thru the generations http://www.geocities.com/MotorCity/Pit/997...ineEngines.html [right][snapback]5419713[/snapback][/right] Not sure what car you've got that 1ggte in but obviously (as I'm sure you already know) if your car was as heavy as the car you were racing (that had a mildly modded 7mgte) you would lose by a lot. If I had close to 200hp in my car it would be an absolute weapon because the car is so light. Doesn't prove anything about the engine ![]() QUOTE(Killswitch @ Oct 6 2005, 02:59 PM) Can someone shed some light on the 3S-GE motors for me? I've had a bit of ye-olde google and I've found out that there were 3 series of them? (correct me if I'm wrong...) and that they started out around 120kw(?) in the first series and in the last series found themselves close to 140kw(?) I also dug up a different variation that appeared in the Altezza RS200's? A 3S-GE 'BEAMS' that comes backed with a 6 speed box and cranking 154kw? How well do they respond to modifications, whats needed to get 200rwhp? Cheers! [right][snapback]5420456[/snapback][/right] They slowly got more power over the revisions...... and got exponentially more expensive. They are a great engine, very strong and you can get good power without opening the engine. The worst thing about them is they never came in a RWD format ![]() QUOTE(AmperSand @ Oct 6 2005, 07:03 PM) Negative. So many people crap on about that, but in reality, the 2jz has bigger ports and valves.. so wonder which one flows better? See many JZA80 supras, Aristos etc with 1jz heads on their factory 2jz's? I think not.. you ever wonder why? Its such an old wives tale, with absolutely no corroborating evidence to support it. Logically the 2jz having bigger ports/valves WILL flow more. [right][snapback]5421612[/snapback][/right] A lot of people have done it and made more power, I'm sure they wouldn't consider it to be an old wives tale. |
CSX 16
Post #90
QUOTE(Mookie @ Oct 7 2005, 02:39 PM) I left out my car has apod filter and a 3 inch exhaust but it's stock other than that. MY car is a SA63 celica (Same as the RA65) made from 1983 to 1985 (as far as i know) and the other car was an MA61. a 1984 model supra [right][snapback]5424518[/snapback][/right] So your car is about the same weight as a small roll of tissue paper ![]() |
eighty-eight
Post #94
i heard that the 1.5J is the poor mans 2J. |
trd_rolla
Post #97
Toyota's best engine to date, the 6AFC - 1.4L twin cam single carburettor motor making a neck snapping 59kw! |
ej20t-vw
Post #99
QUOTE(trd_rolla @ Oct 7 2005, 05:45 PM) Toyota's best engine to date, the 6AFC - 1.4L twin cam single carburettor motor making a neck snapping 59kw! [right][snapback]5425047[/snapback][/right] I disagree, the 2AC takes that trophy... 1.3L SOHC single carb, non-crossflow making a gut wrenching 49kw ![]() |
AmperSand
Post #100
QUOTE QUOTE(AmperSand @ Oct 6 2005, 07:03 PM) Negative. So many people crap on about that, but in reality, the 2jz has bigger ports and valves.. so wonder which one flows better? See many JZA80 supras, Aristos etc with 1jz heads on their factory 2jz's? I think not.. you ever wonder why? Its such an old wives tale, with absolutely no corroborating evidence to support it. Logically the 2jz having bigger ports/valves WILL flow more. A lot of people have done it and made more power, I'm sure they wouldn't consider it to be an old wives tale. By merely saying there are a lot of people out there that have done it that have made more power isnt really EVIDENCE. Got any flow test results between 2 standard heads? Do you know the reason people started to do this swap? Or do you just read random comments in forums hoping what people have said is correct? Reason its generally done is when people would like to go for the 3 litre option of a 2jz, instead of taking the expensive route of sourcing a WHOLE 2jzgte and having to redo, wiring loom, ecu, manifolds etc. They merely swap the block in, retaining the latter. I am yet to see anybody with a MKIV supra or anything with factory 2jz put a 1jz head on it. Its not like im not a fan of 1JZ's, I've owned one before and just bought another one recently (instead of buying a 2jz, and it was around the same price). So its not a biased comment, just seems your jumping in without much evidence. I dont have much either, apart from the fact the valves and ports in a 2jz head are bigger. Which tends to lean me more to the 2jz's favour for having a higher flowrate. |
Matyi
Post #102
QUOTE(drift_luva @ Nov 4 2005, 07:55 AM) whats in a toyota sera? [right][snapback]5539551[/snapback][/right] 4E-FE I think... Same as the locally delivered Starlet Life engine. These are a 1.3 litre twin cam 16 valve engine, but don't really make much power. It is fairly straightforward to swap in an import Starlet GT engine with 100kw (4E-FTE). See specs on the 4E-FTE engine above. |
Mookie
Post #103
http://www.geocities.com/MotorCity/Pit/997...ineEngines.html |
chris davey
Post #104
I agree with Ampersand. The 1.5JZ thing is bullshit. People do it when they blow the bottom end of their 1jz’s. And before anyone says “that can’t happen”. I have done it and did it with stock turbos so not every engine is going to handle 600-700hp as people would like to believe. |
