Post ![]() |
i have a set of 300zx front cailpers im about to put on a car and on a look out for another set dwon the track just wondering if any one out there know if the 300zx front cailpers come off any other model skyline front are a bit diffrent and also how easy are they to come buy and also i have a set of rear skyline ones what models do they come off as i want to find out so i can keep my eye out for more down the track
iamhappy46
The 300ZX 4 pots are good but the 350Z 4 pot Brembos are better and they definitely well priced these days |
tas_ae71
Z32 (300zx) are the same as R32 GTS, factory disks are 280mm |
VHR32
Z32 (300zx) are the same as R32 GTS, factory disks are 280mm R32 GTR and r33gtst are larger and amost identical except the GTR takes a 32mm disk instead of 30mm. diameter is 296mm (?) R34 GTT are a bit larger again (i think they are 312mm but not 100%) s14/s15 have cast iron 4pots with 280mm disks All twin pot rear non brembo calipers seem the same from Z32>R34 GTT Also i THINK there was 28mm and 30mm disk version of the 300ZX front caliper, search there is tons of info out there. ^^ this is correct. The alloy 30mm wide Z32 300ZX calipers are the same as R32 GTSt, they use the same DBA909 280x30mm disc but do have a different Nissan p/n. Here is some info: http://importnut.net/300zxbrakeswap.htm |
iamhappy46
350Z is 324mm x 28mm though AND best of all, the Nissan Murano 4WD runs the same brakes which means they can be bought cheap from late model wreckers |
iamhappy46
350z however cant be bought for $100 HAHAHA. Murano can... although they are the 350Z Track spec brakes(single piston non brembo but still awesome stopping power) ![]() This is the Murano/350Z brakes on my Pulsar and is by far the best budget brake upgrade around. I was out-braking a Porsche 996 with these! |
