ratdawg
cheers man, yeah, once i have applied the resin to the cloth, and it becomes hard, chop strand fiberglass will be applied from underneath for both reinforcement, an in the case that i sand through the cloth it will provide a backiing for the filler. |
ratdawg
sorry for the delay in the console construct - blame it on uni assignments lol. |
NISMOgemini
you should go find a console lid from another car thats similare in size, and cut it into the top section for some storage space |
ratdawg
Im not gunna have storage space - maybe - but because i am going to make a dash facia that houses a screen and head unit, i will probably have to remove the swirches i.e. air con. if i end up relocating them to the console, ill just modify the current console and re-fiberglass - shouldnt be too hard, and just make a fiberglass lid that is countersunk in the console - so as to keep the smooth finish that i am after. |
NISMOgemini
if u lay out the matting under it properly it wont crack.. i made a similare console for my brothers tarage except it had a 12" sub in it and never cracked at all |
ratdawg
I will remove the flooring whic is like vinyl, tape down a few layers of aluminum foil and then fiberglass the contours of the floor, ill let thi sharden and then this will be the bottom of the console, - its hard to explain, but will mean the conolse sits exactly to the shape of the floor, this will then be mounted through bolts / clips etc - wait and see the pics to get a better ides. |
ratdawg
Today i got on with the console, by reinforcing the resined outer fabric. I did this by placing chop strand mat (csm) along the fabric from underneath, this was then resined and left to dry. When dry, i did another layer of csm this time adding some rolled up catalogues for reinforcement. I will do probably a few more layers of csm just to make sure it its strong enough. |
ratdawg
Today i began construction of the dash facia which will connect to the end of the cosnole i am making. |
BND63
That looks great man. |
ratdawg
when thinking of ways to mount console, i decided that it would be best to smooth the whole floor, so today, i took out the vinyl flooring and gave the interior a clean out. |
ratdawg
I started to build the false mdf floor today, which will later be covered in fiberglass to make a shell, the mdf will be removed and replaced with insulation and deadener. |
ratdawg
Havent had much time because of gay assignments, but did a little more with smoothing the floor today. |
ratdawg
At the moment just gradually building up the dash facia using a milkshake mix. Just making it all level and so when it it positioned it is smooth and level with the rest of the dash. |
ratdawg
Ive pretty much finished smoothing the dash piece now - using multiple layers of milkshake and sanding between each coat. |
