1jz Vacuume Lines Help - single turbo on 1jz, cant figure out where one line runs to
mattmeade91
  • mattmeade91
Post #1 post 2nd April 2012 - 06:31 PM
anyone know what to do with this vacuume line that runs into the back of the manifold? block it off?
its on my single turbo 1jz s14 and in the middle of hooking up everything into a catch can and back into the intake so i can get a roady.. just dont know where this 1 little hose should run into?
help
176OES
The large one on the turbo side of the motor plmbs back into the piping on the cold side of the turbo (pre-compressor). On my vehicle I just removed the piping right the way back to the plenum and stuck a small filter on the plenum where it joins back to
The small one on the plenum side, not sure. I removed a 1J from a half cut last weekend and can tell you I'm quite certain that I didnt need to disconnect it from the body... will check out the motor next time I am back to it to confirm for you
mattmeade91
QUOTE (176OES @ Apr 2 2012, 08:41 PM) *
yeah got all that sorted, its just that real small one under the idle choke hose hose that runs into the manifold.
thats a photo of a stock one i found
176OES
I've got to strip the turbo's off the motor to check those, when I do I'll take note and let you know ok smile.gif
Might be a week though
I've also posted this on SoarerCentral, someone there may be able to help
sleepercorty
off memory that small hose is for the factory bov so its not needed and you can just block it off at the intake, for rwc you will technically have to run the large hose for the idle air control back into the intake pipe to
176OES
warney
QUOTE (sleepercorty @ Apr 2 2012, 09:30 PM) *
he is on the money..... as ive just finished my single turbo setup.......
mattmeade91
QUOTE (warney @ Apr 2 2012, 09:44 PM) *
Thanks but yeah thats the first thing I did, blocked it off but once I did that it wouldn't idle?
Maybe the computer has to reset itself or something?
warney
QUOTE (mattmeade91 @ Apr 3 2012, 12:10 PM) *
Cold start isnt working then ! At warm is it ok ?? Yours make boost ok ?
mattmeade91
QUOTE (warney @ Apr 3 2012, 05:46 PM) *
Well yeah the old owner was driving it with it sucking air not blocked off, and boosts good nothing wrong there.. Might have to take it for a drive with it blocked off
