Vr 94 From V6 To V8
Commovr
  • Commovr
Post #1 post 3rd October 2008 - 02:59 PM
hey iam almost off my Green P's and i no this guy thats selling hes vn5l worked v8 plus manual gearbox motor good for 200kws plus
all iam asken is is it hard to put the motor into a vr 1994 auto and is it hard to change the car from auto to manual?
Cheers!
Current ride:
Nissan Silvia S13 1993 SR20DET
Previous rides:
2nd : VR Commodore 1993 Fully Shaved FBSS Air Bagged - LVNLOW
1ST : Subaru GX Liberty 1992 AWD
70YKA
no not hard at all.. just need the manual pedal box.. manual gearbox and all the engine wiring loom. and make sure u got the manual computer..
rozco
DET20
using a vr loom, its plug and play.
Commovr
so i can use my vr v6 loom for a vn v8 motor?
70YKA
haha no u c with a v8 theres 2 extra cylinders lol
rozco
DET20
No, i should have been a little clearer.
Purchase a VR 5L loom and it will plug into the harness in your engine bay.
Place the loom with the v6 where all holden v6's belong, at the dump.
Commovr
ok thanks mate
haha
BADEZ
im not sure if this is correct but ive heard its ether ur not allowed to put a newer motor in an older car or an older motor in a newer car dues to emissions or something like that but depends on how much the motor is and how much it would be to convert probably better to just buy a V8 vr-vs
DET20
QUOTE(BADEZ @ Oct 3 2008, 05:22 PM) [snapback]1282955889[/snapback]
Considering they are the same motor.... mamoru.gif and he is using the VR loom and computer mamoru.gif ...
Commovr
yeah but i was told its not that much to put the motor in and all?
DET20
Its not.
LOWGM
QUOTE(DET20 @ Oct 3 2008, 05:12 PM) [snapback]1282955827[/snapback]
thats not very nice
DET20
^^Shaowy^^
QUOTE(LOWGM @ Oct 3 2008, 05:31 PM) [snapback]1282955943[/snapback]
thats not very nice
No commodore slander gets past you
^88MSE^
wont you have to change the K Frame and cross member to a V8 one? And thats a big job!
DET20
Changing the crossmember is a piece of piss!
Commovr
just got a over the phone price
$600 for install of motor
$300 for manual gear box
thats a ruff pricing
Commovr
also just another thing
i was reading that the vr v6 has a 65 L fuel tank and the v8 has a 80 L tank is it worth changing to the 80 L tank and how much would that be to do so
or just leave it?
Cheers!
crumpet hunter
dont worry about the tank just keep puting fuel in your tank changing tanks is a waste of time
drx77
lol...
DioXidE
Will need:
V8 crossmember
engine
gearbox
loom
ecu
manual pedalbox
tailshaft
Its all a bolt in job, the wiring loom is all plug and play. You dont need to modify anything.
Near the fusebox there are 3 plugs which plug into the engine loom. The engine loom from the v8 will plug into here.
Last plug is in the kickpanel near the ecu. The v8 engine loom will also plug in where the v6 plug was.
All thats needed is put in the v8 crossmember and then engine gearbox obviously.
Plug in the loom
Turn key
zorak
Dioxide about time someone came into this with a sensible answer. I did this with a mate a coupla years back, easy conversion.
OP - Let us know what condition the V6 is in, I got a luxy that needs a V6 conversion.
You wouldnt happen to be the Dioxide I met on the LS1 cruise btw?
DioXidE
sure am zorak!!!
psi999
QUOTE(Commovr @ Oct 3 2008, 02:59 PM) [snapback]1282955195[/snapback]
Cheers!
Just buy a v8 commodore..... Its just not worth doing what you propose doing.
(effort and heartache required, not even considering the dollars).
DET20
If that was the case, then we would end up with a bunch of kids who have no idea on how to work on cars would we head_wall.gif
DioXidE
QUOTE(psi999 @ Oct 6 2008, 01:34 AM) [snapback]1282964478[/snapback]
There is no effort or headache required as its simply a plug and play conversion and it works out quite cheap...
In my case:
I have a VP Wagon
It was a v6... Sold all the running gear out of it for $1500
Bought a VR V8 Calais for $2500
Sold the VR Calais Rolling Shell for $1000
psi999
QUOTE(DioXidE @ Oct 6 2008, 08:29 AM) [snapback]1282964732[/snapback]
In my case:
I have a VP Wagon
I just read this and thought the worst.
I agree, its not a hugely hard conversion (esp for someone like yourself), but may be biting off more than he can chew when a v8 commodore would not be that much more expensive after selling a v6 = no stress.
Joyrid3r
dont forget if your running a/c you will have to re-route the piping and release gas....its not a hard job to change it over, but you are always better getting a complete v8 car, well thinking of resale value anyway.
