Vx Commodore Missing
metallibanger05
  • metallibanger05
Post #1 post 11th August 2008 - 06:41 PM
i got extractors fitted to my vx v6, the car now missis under load around the 1500-2000rpm mark but only under load, i have a feeling its the o2 sensor on the passenger side header, has anyone dealt with this before, plugs and leads are only 10000ks old so it shouldnt be that, ive tried reseting the computer but it didnt work, all leads are on properly, thanks in advance, also will this do damage?
boost=shit
zzz
Void
check ur leads again, probly damged them.
that or u got loose header. but that would make a pssst noise under load
LOWGM
leads mate like anything else they may have come with a fault but i bet you pull them off and one has burnt through. i get misfires all the time in my blown 6, its cuz i run relocated msd ignition and custom leads which are a bit too long and they rub on headers. i had a 02 sensor not functioning at all and you wouldnt know
metallibanger05
QUOTE(LOWGM @ Aug 11 2008, 07:02 PM) [snapback]1282723331[/snapback]
true, im hopin its the o2 cause an exhaust shop fitted the so they can fix it, all the leads look good, is it worth changing them?
LOW COMMO
coilpack?
