Big Leak - Oil
gunnaboost
  • gunnaboost
Post #1 post 13th April 2016 - 12:04 AM
Xh ford leaks oil from sump plug but only leaks when up in the rev range from about 2500rpm no pcv it's gone missing but have a bolt where pcv is ment to be any advice
DONT PANIC
get yourself a catch can- sump needs to allow air to escape... called blow by gas- you are pressurizing the sump- don't sad.gif more bad things will happen
gunnaboost
QUOTE (DONT PANIC @ Apr 13 2016, 06:40 PM) *
Would I be able to stop it if I got a pcv and a new sump plug or would it be best if I get a catch can sump if so how much would I be looking at for 1
DONT PANIC
sump plug washer from autobahn- take the bolt out and put at least a filter on that or run a hose to a catch can- catch can $40
gunnaboost
I fixed the problem just toke the bolt out now no pressure but I have oil leaking out of crank sensor now grr lol
