2pac Mixing Ratios
carworlds
  • carworlds
  • Contributing Member!
Post #1 post 24th July 2011 - 12:39 AM
Hey guys, just started spraying a bit of 2pac on some replacement panels and wanted to see what ratios other people are using
ratios for
primer:hardener
base coat:hardener
clear coat: hardener
also what psi is everyone using when using a hvlp gun?
MrR32
QUOTE (carworlds @ Jul 24 2011, 06:39 PM) *
ratios for
primer:hardener
base coat:hardener
Mate to mix it prop you will need to get sum mixing sticks
nferno
Its all relative to the brand you are using. Directions should be on the tin.
QUOTE (nferno @ Jul 24 2011, 06:57 PM) *
This.
Different ratio's per brand and product.
1:1, 2:1, 3:1, 4:1..... You get the idea.
If you get it wrong it will not go off.
And for the pressure, it depends on alot of factors: How you spray, what you're spraying, amount of thinner etc. Different for every person/ job.
dunsy
download the correct data sheet for the products you have have.
It will tell you exactly the mixing ratios etc.
Will probably also tell you the recommended pressure to run in your gun.
bilz
Most primers are 4:1
Most 2k and clears are 2:1
And most base coats are 1:1
bilz
And about 1.5 bar for base coat and 2bar for clear
180sxy
The hell! dont people search anymore
oovro
Primer is 4:1 and 10% thinners
2k solid is 2:1 and depending on the brand it can be 1 part or 10% thinners
Base is 1:1 using thinners not hardner.
Clear is 2:1 and 5-10% reducer.
And generally around 17-19 psi on the gun.
I'd like to see an automotive spraypainter attempt to spray a 60ft yacht in marine coatings, a solid @ 40% summer thinners. wink.gif
dirty turbo
go to www.amcap.com.au they have some info on mixing and stuff like that for ppg,deltron,autothane products
oovro
QUOTE (wbtonner @ Jul 24 2011, 08:59 PM) *
I recently painted a 42 foot twin hull yacht in marine 2k. Whats the big deal?
QUOTE (oovro @ Jul 24 2011, 09:40 PM) *
I've seen car painters over the few years when I used to paint, talk their gun skills up, and when it came to the business end, promptly fuck it up pretty badly. I've painted a couple of cars, other than the tricks of the trade; certain masking techniques etc. it is alot easier to paint a car IMO and the products are easier to spray. wink.gif
What brand of paint did you use?
-Oh, and with a 60ft yacht, you have the extra 20ft of hull in length and 1-1.5m of extra height in the hull to paint.
oovro
Yeah but it's a single hull yacht. The one i painted was a twin hull. So really 84 foot of painting. Can't remember the brand name. The customer suppied it.
A.D kustoms
ppg base requires hardner 8:9:16 8 parts base 1 part hardner 16 parts thinner
QUOTE (oovro @ Jul 26 2011, 06:06 PM) *
Paint brands surprisingly make a BIG difference. If it was in Sterling or Awlgrip in a linear paint then my hats off to you.
oovro
QUOTE (A.D kustoms @ Jul 26 2011, 06:23 PM) *
I use PPG and have never put hardner in the base and only thin it 1:1. As do all the other painters i know.
