2006-2018 Toyota Camry Fuse Box Location - Camry fuse blocks explained here
MrJobun
  • MrJobun
Post #1 post 31st January 2021 - 03:38 PM
The Toyota Camry has two fuse box locations regardless of the model year. The location might differ slightly in each model, but the difference is marginal.
  • One is located in the engine compartment
  • Under the dashboard on the driver’s side
There are two fuse box styles, when it comes to the one found in a Toyota Camry’s engine bay. You can see the diagram below to find the one inside your car.
Opening this fuse box is as simple as pulling on the tabs, and the lid comes off.
To access the fuse box inside the cabin, you have to pull on a small latch.
The fuse boxes will have separate fuses for lights, the A/C, the ABS, the windows, the seats, and all the other systems that use electricity.
You can check the Toyota Camry Owner’s Manual for further details.
