2013 Honda Civic Fuse Box Location - Where are the civic fuse blocks?
MrJobun
  • MrJobun
Post #1 post 31st January 2021 - 03:26 PM
Are you interested in searching for the fuse box location in your 2013 Honda Civic? Perhaps a fuse has blown, and you are unable to use your car's headlights, or the wipers have suddenly stopped working. There is no need to worry as we have got you covered.
The Honda Civic sedan has two fuse boxes, similar to any other sedan. One is situated in the engine bay near the brake fluid reservoir, while the other is located under the instrument panel on the driver’s side.
The fuse box is protected by a cover that you will need to open. It is fairly easy to open both boxes. All you need to do is push on the tabs found on the cover, and the lid comes free.
The interior fuse box is a bit different, but it is much easier to open. Simply, pull the cover under the dashboard to expose the fuse box. You can see the location in more detail in the pictures below.
